New UHF radio has low transmitting signal volume
Submitted: Sunday, Aug 21, 2011 at 10:59
Member - Bentaxle
Hi I just recently installed a GME TX3540
UHF radio and have found that the transmitting signal volume is low but the receiving signal volume is normal and has to be turned down. In both cases the signal is clear with no interference. Any clues?
Mike
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
Reply By: Member - Stephen L (Clare SA) - Sunday, Aug 21, 2011 at 11:09
Hi Mike
You have no problems with your new radio. You will find that this will be the problem you and everyone will get when a new 80 channel radio communicates with an older 40 channel radio.
They on the other had will have the opposite to you and have to turn their volume up on the old 40 channel radios.
463147
Follow Up By: Member - Bentaxle - Sunday, Aug 21, 2011 at 14:28
Thanks for the info Stephen, our Club members will probably curse us on our next Club outing, but looks like it will e an ongoing problem untill there are no more 40ch radios
736990
Reply By: Drew - Karratha - Sunday, Aug 21, 2011 at 22:08
If you are only communicating with people using the 'old' 40 channels I think you can turn it to wideband (40 channel) instead of narrowband, which the 80 channels are... I am looking at buying one and found the instruction manual on the internet - it shows you how to do it there (I was concerned about the compatability between the 40 and 80 channel UHF's).
Drew
Ps - My total knowledge on this is after about an hour on the internet - so apologies if this is incorrect....
463207
Follow Up By: Dust-Devil - Sunday, Aug 21, 2011 at 23:45
Drew
For one hour on the internet you aren't doing to bad dude.
Spot on the money!
DD
737042
Reply By: ChrisGU - Monday, Aug 22, 2011 at 09:19
Anyone know how fast the trucks are moving to the 80 channel system?
Just wondering how fast the take-up to 80 is and whether I should be upgrading sooner than later, or if I'll be right for a while yet with the old one.
463230
