Do I really need a bucket and a rope?
Submitted: Sunday, Aug 28, 2011 at 04:24
Richard Arkle
Planning to do the CSR mid Sept to mid oct in my ex Britz troopie and I have read that I need a bucket and a rope to get
water from the wells.
I carry just about everything else, and have used nearly all of it, but do I really need a bucket and rope? Lots of wells have pumps, I am very conscious about overloading.
Thanks R
Reply By: feathery - Sunday, Aug 28, 2011 at 06:47
If you trust that all pumps are working than no but it is a big change you take
463674
Reply By: Wayne (NSW) - Sunday, Aug 28, 2011 at 07:10
Richard,
A little more research is required. The only
hand pump on the CSR is at
Georgia Bore.
A good length of rope and a plastic bucket is not going to break the Troopie but the lack of
water will break you.
Wayne
463676
Reply By: Member - Bucky - Sunday, Aug 28, 2011 at 07:11
R
You must be on some kind of death wish, mid October ?
Better check with local Police at Billiluna, and at Wilunu.
Bloody hell mate, we came back down in mid september and it was mid to low 40's then.
You will need a bucket to transfer the
water from the
Well Buckets to your
water containers/
water Jerry cans, and also at Gorgia
Bore.
Step back from the
well, a bit, and have a "bush shower", try and do that without a bucket, if won't happen.
In the overall scheem of things, what is the weight of a bucket, and 20 feet of rope, if the
well bucket, and hand winching system is broken ?
Bucky
463677
Follow Up By: Member - Bucky - Sunday, Aug 28, 2011 at 07:17
And don't forger to drop your tyre pressures down to 15 psi, for std tubeless or tubed rims, and check with other members of this
forum about low pressures on split rims, and do the dunes easy.
737516
Reply By: olcoolone - Sunday, Aug 28, 2011 at 10:12
A 10lt stainless steel bucket and rope is essential for remote out back travelling, good for collecting
water, catching fluids from the vehicle, carrying stuff around the
camp area, heating
water on the fire and putting out fires..... the rope is good for tying things down!
Maybe you should get rid of some of the stuff you don't need or ever use.....
463695
camp area, heating
463696
Follow Up By: Member - Hillel K (VIC) - Sunday, Aug 28, 2011 at 16:35
Hi there where do you get a stainless steel bucket from?
thanks
737569
Reply By: Members Pa & Ma. - Sunday, Aug 28, 2011 at 11:06
Hi Richard,
Absolutely!, most important!!!!!! It must be a metal bucket too! a plastic one only floats on top.You should take a funnel for
water only too.
You can also use the rope for opening the
well doors so you can stand back a bit snakes like to get in under the lids & some live in the wells. Like the huge King brown at
well 46. when we were there ages ago.
I know, like us, we can only take our hols at a certain time of the year. We're heading to the
Mitchell Falls & I'm not going to take the humidity too
well but this is when we get hols.
I'd be more worried about your vehicle overheating than the bucket which you'll need if it does!
You don't say weather your travelling North to South or visa versa.
We went South to North but were told that it's easier to come from the North because of better approaches to the sand hills. That sand is going to be hot which makes climbing the dunes more difficult.
You may have to climb the worst ones first thing in the morning when the sand is cool. even if you have to wait it's better than breaking down.
Good luck, I trust you have at least some of the emergency communication devices?
Take care,safe travels.
Bye for now Ma.
463698
Follow Up By: Members - Bow & Nan - Monday, Aug 29, 2011 at 07:57
Image Could Not Be Found
Found this waiting for me under a
well door.
737630
Reply By: Big Woody - Sunday, Aug 28, 2011 at 18:21
Hi Richard,
I carry a good quality canvas shower which doubles as a collapsible bucket for dropping down wells.
It holds about 12 litres and hardly takes any room at all.
I like carrying things that have multiple uses to keep the weight down and conserve space.
BW
463728
Follow Up By: Members Pa & Ma. - Monday, Aug 29, 2011 at 11:03
Hi Bow & Nan,
Good photo! The one down
Well 46 (I think it was 46) was the longest,skinniest King Brown we've ever seen & we've seen several. Fortunately we'd been warned.
He wasn't in a photogenic mood either. We added another note of warning to the many others around the
well & warned the few people we passed. It must've been living there for years!
Because we'd been warned we used our bucket rope to lift the doors from a distance.
Safe travels, Take care.
Bye, Ma.
737642
Reply By: ExplorOz - David & Michelle - Sunday, Aug 28, 2011 at 21:27
Richard,
If space is a premium and
mine is I take one of these with me. In fact i have used one of these on may occasions. It is a
Folding Bucket and works great in
well water extraction - you just put a rock in it send it down pull it up a-full of
water, fold up put away.
David
463752
Reply By: Member - Dunworkin (WA) - Sunday, Aug 28, 2011 at 21:59
When we did the CSR a few years back we got to Georgie
Bore and the pump was broken, the guys spent some time fixing it so there was
water for others who may require it.
I would definitely add the bucket and rope, We used our bucket to drain the sub
tank on the Patrol as the pump had packed up, we had to transfer it manually, glad we had the bucket.
D
463755
