Childara Rockholes
Submitted: Sunday, Aug 28, 2011 at 08:18
ted
Does any body know if the track from Googs Lake to
the rock-holes is doable with a camper trailer in tow.
Any comments please
Reply By: Member - Stephen L (Clare SA) - Sunday, Aug 28, 2011 at 09:31
Hi Ted
The track in is so typical of any outback single tracks,there are many good wide open sections and many sections where it is tight. There are a few fine
camping sites along the way closer to the northern side of the lake. If you wanted to you could set
camp up at you chosen location and drive out to see it. There is no
camping out there. Most importantly is make sure that you shut the
Dingo fence correctly when going in and out.
Make sure that you give the owner a phone call first as this is on private property. His name is Alistair Angas from Hillriver Station here in
Clare and can be contacted on 08 - 88422 859, who will in turn will inform his manager out there that you will be out there, or else give the manager a call.
Image Could Not Be Found
463687
Follow Up By: ted - Sunday, Aug 28, 2011 at 10:30
Thanks for the info will give him a call.
Ted
737528
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Aug 28, 2011 at 10:35
Hi Ted
There are also a couple of other rock outcrops to see out there in the Nation
Park side and you should also see them as
737529
