AnswerID: 39063 Submitted: Monday, Dec 01, 2003 at 15:05
Member - Bradley
replied:
Hi Savvas, if you have a lsd then you should always use an lsd oil preferably high quality stuff. The holden additive you refer to is a gm part which from my previous experience working at holden is used to help keep the cone and seat faces free from build up . Half of the people at the dealership hadn't seen it or used it , which is a worry as it is stated in the service book !! I have previously used it in my jack and have no shudder or sticking in the diff centre and really good lsd action still ( 120k).
My new rodeo work ute had a virtually fully locked diff from new which the ignorant dealers could'nt fix. At 8k i changed the oil and had it tested , apart from being filthy it had a viscosity range that our lab could'nt identify, their best guess was a blend of different oil types was used. Not Happy Jan. filled the diff with some of our fully synthetic 75-140 LSD oil and within 10 ks the diff was fully operational and quiet as a mouse. Demanded some quality control answers from holden but surprise surprise , still waiting........
My advice is to use the additive if you are using lower quality mineral oil, but don't add it unless you have to with synthetic LSD oil. Anyway, how often do you change the diff oil , You might as well use the best stuff you can get, spread the cost over 40k or more , it is stuff all. Cheers BradMoo... everyone knows what a Jackaroo looks like :-)
Reply 3 of 4
