Redarc <span class="highlight">battery</span> isolator ( dual <span class="highlight">battery</span> ) Failure
Submitted: Monday, Sep 12, 2011 at 18:18
Begaboy
Greetings guys - as the topic suggests - my REDARC duel
battery isolator has failed - left the car radio on over night by accident - by morning -
battery drained - not enough voltage to start car - so hit the momentary switch to get a jump from second
battery - No distinct click from isolator - closer inspection and i see the control module looks like it swolen ( and cold so must have swolen over night due to voltage drop ???? )
anyway question is , is the controller module ( little black box ) available for sale ? or do i have to buy the whole isolator again ??
thanks
BB
Reply By: Member Al (Sunshine Coast) - Monday, Sep 12, 2011 at 18:41
Hi BB, "Swollen" doesn't sound good!
How old is it? All those I have seen have a translucent box.
Anyway, you could give Redarc a call on 08 8322 4848. They seem top handle problems pretty
464821
Reply By: kev.h - Monday, Sep 12, 2011 at 19:10
Hi Begaboy
They all seem to swell a little with age I think its a heat thing the black ones are quite old as they have been opaque for a while now
The momentry switch should bypass the control unit so it is most likely the main solinoid the radio should not draw enough to overheat it
Have had one fail it was mounted on the engine have mounted the replacement on the inner guard away from any heat source and vibration
Cheers Kev
464826
Reply By: Member - Michael A (ACT) - Monday, Sep 12, 2011 at 20:30
Try contating Redarc directly (they are an Australian company( I have found the people there to be very helpful and are willing to answer any quetion that I have asked them. They are found at www.redarc.com.au
or Street Address
23 Brodie Road North
Lonsdale
South Australia, 5160
Australia
Mailing Address
P.O. Box 469
Morphett Vale
South Australia, 5162
Australia
Phone & Fax
Phone: (08) 8322 4848
Fax: (08) 8387 2889
464841
Reply By: Member - Stevo_62 - Tuesday, Sep 13, 2011 at 06:34
I recently brought an isolator at JAS Oceania for about $50 . Working fine .
464868
Follow Up By: Ray - Tuesday, Sep 13, 2011 at 08:56
All I have is an isolator.
Mine works fine also
738817
Reply By: Member - Troll 81 (QLD) - Tuesday, Sep 13, 2011 at 11:55
As others have said contact Redarc, I had problems with
mine they asked that I send it down and days later I received a new one in the mail. All it cost me was postage down.
464885
Reply By: Begaboy - Saturday, Sep 17, 2011 at 16:16
HI all - thanks for your replies -- sorry for the belated reply but have not been online for over a week !
will try call next week - time permitting
465279
