replacing speedo cable in HJ60
Submitted: Tuesday, Dec 02, 2003 at 19:13
greenant
My speedo needle bounces a lot at about 30 to 50 km/hr and I am thinking of changing the inner cable Has anyone changed the inner by taking it off the gearbox end and pulling out the old one and replacing it with a new one or do I have to replace the outer as
well by removing the lot off the vehicle. Changing the inner while on the car would be much easier any ideas please
Reply By: ToyMotor - Tuesday, Dec 02, 2003 at 21:36
My 60 was the same, I never fixed it, but I reckon you'd need to change the outer, as the bouncing is probably the inner "winding up" where the nylon sleeve is worn away in the outer. It's pretty easy to access the speedo end, by taking out the screws holding the instrument panel in, the panel comes out far enough to undo the cable. (I got it down to a fine art repairing the tacho about 4 times)
39226
Reply By: Well 55 - Wednesday, Dec 03, 2003 at 08:15
Yep you have gotta replace the lot, when you do make sure you put a new "O" ring at the gearbox end, so as not to get a oil leak latter on.
39255
Reply By: bill- Thursday, Dec 04, 2003 at 18:59
When you undo the cable from the speedo, tie a piece of string to the cable before you pull out the cable, then pull out the cable, tie string to new cable and gently pull new cable thru the rear of the heater assembly otherwise it's near impossible to find the cable once you put it thru the body and you save a lot of time
39429
