landcruiser stud pattterns
Submitted: Sunday, Dec 07, 2003 at 21:31
ThreadID: 9015 Views:27874 Replies:3 FollowUps:0
I was wondering if any one can give me some info on stud patterns,eg. are landcruiser rims interchangeable between different models .I'm driveing an HJ47,regards Stephen.
Reply By: Member - Eric- Sunday, Dec 07, 2003 at 21:42
all the early stuff , is interchangable , in 93 the landcruiser changed to a 16 inch wheel , so early wheels will fit the stud patterd , but not over the disc and calipers on a petrol mod. , the Cruiser changed its 6 pattern for a 5 pattern in 1998 with its 100 series Venus Bay
AnswerID: 39626
Reply By: Member - DOZER- Monday, Dec 08, 2003 at 10:23
Gday
There are heaps of differences along the models, most of the stud patterns will fit to yours but the offset of the rims see them hit the steering linkage on the front diff.
All 100 and 80 series landcruiser wheels wont fit straight on. This includes the prado. The 4runner wheels 1985 or later wont fit either, but early solid front end forrunner wheels 84 or earlier will, so will all hiluxes, 40's 55'70/3/5/8 models.
Now, if you were to space out these wont fit wheels with spacers, they will fit, but now you are illegal.....
Andrew wheredayathinkwer mike?
AnswerID: 39655
Reply By: Phil G - Monday, Dec 08, 2003 at 20:25
Need the correct backspaced rims which is about 65mm on your '47.
All 40, 55, 60, 70, 73 and 75 series and early Hilux have the same backspacing.
80 series and 90/120 series (Prado) won't fit because of offset.
78,79 and 100 series are 5 stud, and come in two different offsets.
Most popular alternative rim size is the 15x7, mostly in the white spoke - very cheap to buy.
All Nissan, Mitsubishi and Jackaroo/Rodeo have too much backspacing for your 47 series, and the wheels will sit inboard too far. All the 6 stud spacings are the same.
AnswerID: 39687
