Spare fuel
Submitted: Monday, Dec 08, 2003 at 13:17
ThreadID: 9027 Views:3865 Replies:4 FollowUps:7
G'Day all,
Could someone advise me on the current rules & reg's regarding carrying unleaded fuel in jerry cans, or the like, externally on trailers or vehicle towbar brackets, and if the reg's vary from state to state.
Regards,
Bazza.
Reply By: Well 55 - Monday, Dec 08, 2003 at 13:59
Bazza, most of the Off Road Campers you see getting around have factory jerry can holders on the draw bar or down each side, you would think they must be ok if they are built that way.
AnswerID: 39671
Follow Up By: Bazza - Monday, Dec 08, 2003 at 14:24
G'Day Well 55,
Thanks for your responce. I also thought the same as you, although it may be OK on trailers perhaps, but I recently heard that a particular manufactured "rear mounted swing bracket", the type that holds a spare wheel and jerry can, are now advising that it can only be used to hold water, not fuel. I may have got my info wrong, so I thought I'd ask.
Thanks again,
Regards,
Bazza.
FollowupID: 257337
Follow Up By: Well 55 - Monday, Dec 08, 2003 at 14:28
That sounds about right, I'd be worried about a someone running into the back of the vehicle with a full drum of fuel in between.
FollowupID: 257338
Follow Up By: Graham & Ann - Monday, Dec 08, 2003 at 17:30
Caravan makers now put jerry cans for petrol on the A frame which is considered 'within the vehicle'. where as jerry cans for water or desiel are often mounted on the rear bumper. with big stickers saying nor for use carrying petrol. different states = different laws its appears and lots of grey area. there may also be insurance considerations. 1999 Pathfinder
17ft Evernew 'All Roads' van
FollowupID: 257346
Reply By: flappan - Monday, Dec 08, 2003 at 14:46
As far as I'm aware the fuel containers must be within the lines of the vehicle.
Therefore, the wheel and jerry holders would be technically illegal. The ones on the trailers are within the lines of the trailer.
Up on the roof is obviously the other place, and within the lines of the vehicle.
AnswerID: 39672
Reply By: jamcage - Monday, Dec 08, 2003 at 15:51
Bazza
The following is an article which appears on the campertrailers group
Should shed some light on the topic for you
Jason
FUEL CANNED
There are basically three ways of carrying fuel into remote regions: fit a large-capacity
aftermarket tank to your vehicle; take along a 4WD mini-tanker; or carry fuel in jenny cans.
Most people should be aware that the ubiquitous, metal 'jerry can' was first developed for
Adult Hitler's Blitzkreig qualified (Lightning War) during WW 11, when mobile troops were
expected to rapidly outrun their supply train.
For this reason, the on-board, portable fuel container was developed. It became known as a
'jerry can' when the Allied forces realised that jerry' (the Germans) were onto a good thing,
and began 'souveniring' them wherever possible. Eventually, they copied it.
The key elements of the design are the space above the filler cap, which allows for expansion
of the fuel and fuel vapour, and the two-pronged cap, with airtight rubber seal under the lid.
WHAT CAN YOU USE?
Modern metal jerry cans have essentially the same design, with the inclusion of a safety
retaining pin. The plastic cans look similar, but have a screw top and a flexible plastic,
screw-on pouring spout, rather than the metal can's rigid aluminium or steel clip-on spout.
There is now an Australian Standard for the design and manufacture of such devices: AS2906
Fuel Containers/Portable/Plastics and Metal. If you are considering purchasing such containers,
do not buy one without the appropriate 'AS2906' sticker clearly on it.
Further, you should not use AS2906-marked containers for water, or use containers marked for
water to carry fuel. This is especially true for plastic containers, as those designed for
carrying fuel are formulated to be resistant to attack by petrochemicals.
They have significantly increased quantities of a chemical that taints the water and makes
it undrinkable. Conversely, plastic water containers are not suitable for the transportation
of petrochemicals such as petrol and diesel because they can allow vapour to pass through the
plastic.
WHAT IS DANGEROUS ?
The Australian Dangerous Goods Code (sixth edition) specifies that fuels are dangerous goods.
Petrol is more flammable and dangerous than diesel, which is classified as a 'combustible'
rather than a 'highly flammable' product. The ADGC goes on to say that the maximum permissible
quantity of petrol that can be carried by a recreational vehicle, including camper trailers &
caravans, for non-commercial purposes, is an aggregate total of 250 litres.
Theoretically, you can carry as much diesel as you like; however, there are some cautions here.
The 'aggregate quantity' referred to in ADGC(6) specifically excludes an approved fuel cell on
the vehicle from its calculations. Therefore, a larger-capacity, extended-range tank that is
approved for the purpose, is not required to be added to the aggregate quantity, nor is an
original, factory fitted fuel tank.
Generally, extended-range tanks are designed to comply with Australian Design Rules (ADRs);
however, some States have specific regulations that also must be complied with. Approved
installers will be aware of these additional regulations if applicable.
WHERE CAN YOU CARRY IT?
The other question that causes much debate around the campfire is where on the vehicle these
AS2906 fuel containers can be appropriately stowed. This is a greyer area, as some scenarios
are simply not explicitly covered by existing regulations.
Furthermore, where State legislation is not specific, (as is the case with diesel), other
general transport legislation, such as that covering operation of vehicles in a safe manner,
comes into play.
This legislation refers to the 'duty of care' each vehicle operator must execute in order not
to place passengers or other road users at risk.
This type of legislation covers modifications, safety issues and overloading, which is quite
possible if you are carrying, say, 12x20-litre fuel containers in addition to recovery gear,
camping gear and so on.
Have your vehicle and/or trailer weighed on a public weighbridge to ensure you are not
overloading. Especially cheek the ball weight if you are loading jerry cans on the A frame of a
trailer!
A further caution is that, like mixing drinks, mixing flammables is not recommended. Therefore,
do not store LPG and fuel in the same area or space.
All these suggestions are otherwise known as exercising commonsense.
BEFORE YOU GO TO COURT
The normal test, in legal terms, is based on the notion of the 'reasonable person'. A magistrate
(should) take a case on its merits and ask 'would a reasonable person have done/not done this'.
So, in the unlikely event of an accident, when insurers or victims are seeking to apportion
'blame', there is a very good reason for using AS2906-approved containers for carrying fuel,
and for loading and transporting those containers as safely as possible.
The other issue with carrying fuel in containers on or in your vehicle is, obviously, the
opinion of your insurer regarding such use. Take photographs of what and how you
propose to carry additional fuel, and request approval in writing to do so from your insurer.
There are certain scenarios where previously approved (or at least, not un-approved) situations
may no longer be valid. One of these is vehicles with jerry can holders on the bumpers or
exterior of the vehicle. Under current legislation, these would appear to be illegal for fuel
transportation under simple 'duty of care' provisions in transport legislation. In some States,
bumper bar legislation could make even the brackets to carry the jerry cans illegal.
SO, YOU'VE GOT A TRAILER ?
Some States (such as Queensland) question the reasonableness of rear-mounted, or side-mounted
jerry cans on trailers (including camper trailers and caravans) due to the potential hazard in
an accident.
It should be fair to say that carrying fuel, in approved AS2906 containers, securely fixed or
fastened inside the vehicle, would be less likely to cause legal problems than mounting the
containers on the outside. On the A-frame is, apparently, considered 'inside' the external
dimensions of a trailer. Of course, many trailers and probably all caravans, have a three-way
(LPG-powered) fridge, which normally has a pilot light. Although the pilot light should be
extinguished when travelling, storing fuel inside a vehicle so fitted would be considered
extremely dangerous. Any fuel or fuel-vapour leak could create an explosive situation
WHAT ABOUT ROOF-RACKS?
Fuel stored on an approved roof luggage rack should be okay, provided it is in approved
containers, is adequately constrained, and doesn't overload the vehicle's roof load limits or
those specified by the rack's manufacturer.
So the bottom line is: do everything you possibly can to limit the risk of rupture or leakage.
Use AS2906-approved containers and regularly check them for wear and tear. Pack them to prevent
chafing, preferably with a non-absorbent material, as this could, in turn, become a hazard in
the event of leakage.
If using rope to secure containers, you should use synthetic rope, which is guaranteed resistant
to petroleum products. Manilla rope and cotton-based cord are absorbent.
Alternatively, you could use ratcheting tie-down straps but, again, cheek that the synthetic
webbing is resistant to petroleum products.
WHAT IS THE LAW?
WESTERN AUSTRALIA
The WA Dangerous Goods Act 1988, and Dangerous Goods (Transport) (Road and Rail) Regulations
1999, contains the relevant regulations, both of which are based on the Australian Dangerous
Goods Code (ADGC), sixth edition.
The maximum permissible quantity is 250 litres of petrol, which should be carried in approved
containers in either the boot or on external brackets. It can be carried within the passenger
compartment, such as the back of a station wagon, in approved, properly restrained containers,
but this is not recommended.
Contact the Explosives and Dangerous Goods Division of the WA Department of Mineral and
Petroleum Resources for further into (08 9222 333)
QUEENSLAND
The Transport Operations (Road Use Management - Dangerous Goods) Regulation 1998 permits
carrying up to 250 litres of dangerous goods (fuel) for personal use. The responsibility for
filling a jerry can and ensuring it is an approved container lies with the person filling the
container.
Under the Transport Operations (Road Use Management) Act 1995 owners are prohibited from
modifying their vehicle, its parts or equipment, and from carrying dangerous goods
(irrespective of quantity or position), in an unsafe manner.
This includes carrying containers upright, ensuring they don't leak and are properly secured,
and do not overload the vehicle (especially if transported on roof-racks). A booklet titled Load
Restraint Guide (available from Commonwealth Government Bookshops) should be consulted
Write to: Greg Swann, Group Manager, Vehicle Safety and Industry Reform Section,
Queensland Transport, PO Box 673 Fortitude Valley QLD 4006.
SOUTH AUSTRALIA
In South Australia, petrol is covered by the Dangerous Substances Act and Regulations, which are
in turn based on the ADGC; therefore, the same 250- limit applies.
Diesel is unregulated, as elsewhere, but the Department for Administrative and Information
Services advises that petrol (and diesel) transportation would be covered by the general duty of
care provisions contained in Sections 11 and 12 of the Dangerous Substances Act.
The Road Traffic Act has provisions for duly of care relating to vehicle safety issues such as
overhanging loads and impact protection. They also state that, while carrying fuel in the
driver's vapour space (in a van or wagon), is much debated, it is up to each individual driver
to assess their own risk and duty of care provisions when deciding whether to fit a range tank
or carry fuel in jerry cans. Dangerous Substances Branch, Workplace Services (08) 8303 0447
VICTORIA
In Victoria, the relevant legislation is the Road Act 1995, which has been adopted from
the, (Dangerous Goods) Act -1995 and the Road Transport (Dangerous Goods) Regulations.
The Regulations reference the ADGC under which Regulation 1.10 exempts small quantities of fuel
from the rigours of the Dangerous Goods legislation. This refers, again, to petrol only. Diesel
is not considered dangerous goods.
They maintain it is the responsibility of the driver items, regardless of type, are firmly and
a fuel should be stored in AS2906 containers minimum requirement.
Write to: Victorian WorkCover Authority, Dangerous Goods Unit
GPO Box 4306 Melbourne Vic 3001
TASMANIA
The Tasmanian government refers these, issues to the Dangerous Goods (Road and Rail Transport)
Regulations 1998, which covers general safety and load restraint safety.
The filling of fuel containers is also covered by AS1940 - Storage and Handling of Combustible
and Flammable Liquids. They advise that a person can carry 250 litres of petrol for private use
(as per the ADOC), but the containers must meet AS2906 Fuel Containers/Portable/Plastics and
Metal.
Tasmanian Vehicle and Traffic (Vehicle Standards) that an object fitted to a vehicle must be
designed, built and maintained to minimise the likelihood of injury. As such, this would
prohibit the fitting of jerry cans containing dangerous or explosive substances to any vehicle
(car,4WD, caravan, trailer), especially given the likelihood of rear or side-impact collisions.
Owners of vehicles should check the 'fine print' of their insurance policies. If fuel is
transported in an unsafe manner and an accident leads to greater damage or injury than might
otherwise have been the case apportion blame to the driver and/or invalidate the policy.
Write to: The Department of Infrastructure, Energy and Resources,
GPO BOX 936 HOBART TAS 7001.
NEW SOUTH WALES
The NSW Environment Protection Authority (EPA) and WorkCover NSW are the competent authorities
for dangerous goods control in NSW. They' administer the Road and Rail Transport (Dangerous
Goods) Act 1997 and the Road Transport Reform (Dangerous Goods) (NSW) Regulations 1998.
Under these laws, jerry cans must be approved containers for the transport of Class 3 liquids
(petrol) (ie, AS2906) and the maximum permissible quantity is 250 litres. Diesel is not
considered a dangerous good, but a combustible, and must be carried in a safe manner.
Division 9.3.1 (1) (e) of the ADGC states that 'if the package (ie, jerry can) contains
dangerous goods of a kind that may lead to the formation of flammable, toxic or other harmful
atmospheres - the package must be stowed so that no harmful atmosphere will accumulate in the
cabin If the package leaks'.
The above would indicate that great care should be taken when storing jerry cans inside a 4WD's
luggage compartment, whether it is a separate boot or part of the passenger compartment. AS2906
containers are designed not to vent to the atmosphere, provided they are in good condition and
the seals/lids are functioning correctly.
Write to: NSW Environment Protection Authority
Dangerous Goods Office
59-61 Goulburn St, Sydney NSW 2000.
NORTHERN TERRITORY.
Only containers which comply with Northern Territory Dangerous Goods Regulation 217 can be used
to transport flammable, (petrol.) and combustible (diesel) fuels. Essentially, this covers
containers complying with AS1533/34 and AS1 940, but 'approved container' is also specified
which indicates that containers complying with AS2906 would also be acceptable.
The Northern Territory Dangerous Goods legislation is b ADGC, which specifies that not more
than 250 litres of petrol can be carried. No quantity is specified for diesel.
Information bulletins are available at www.nt.gov.au/cbb/wha or contact
The Department of Industries and Business, Work Health (08) 8999 511 8
AUSTRALIAN CAPITAL TERRITORY
The transport of fuel is covered under the Dangerous Goods Act. 1975, Dangerous, Goods
Regulations 1978, Road Transport Reform (Dangerous Goods) Act 1995 and Road Transport
(Dangerous Goods) Regulations. The latter takes its requirements from the ADGC.
The DGA (1975) Section, 12 and 14 require fuel to be carried in appropriate, containers
to prevent spillage or leakage, and make it an offence to carry fuel in a manner likely to
cause death/injury, or damage to property.
Section 37(1) of the RTR (DIG) Act1 1995 requires fuel be transported in a safe manner.
Sub Section (2) makes it an offence to do so where a person "ought to have known" that what
they were doing was unsafe or likely to cause damage to persons or property.
Contact: ACT WorkCover (Dangerous Goods) (02) 6207 6354.
AnswerID: 39676
Follow Up By: Bazza - Monday, Dec 08, 2003 at 16:31
G'Day jamcage,
Thanks for all the info! It's certainly not "black & white" rule, is it ? I would think that after reading between the lines, as long as common cense and adequent precausions are used, a rear "'Swing bracket" is permissable. As to if it's a safe idea or not, is another question. It seems to me that ... depending on what state your in, should an incident occur, the outcome would be determined by many authorities. It could be a nightmare.
Thanks again.
Regards,
Bazza.
FollowupID: 257345
Follow Up By: Rowler - Monday, Dec 08, 2003 at 19:25
Bloody Hell!
Did you have some spare time or what?
Well Done
Rowler
FollowupID: 257354
Follow Up By: joc45 - Monday, Dec 08, 2003 at 23:57
Whew!!
Jamcage, can you tell me if plastic jerry cans can be carried flat on their side on a roof rack (assuming a soft spacer such as carpet separates the can from the roof rack to avoid chafing)? ie, are the cans designed to be carried in any way other than upright when full?
Gerry
FollowupID: 257373
Follow Up By: jamcage - Tuesday, Dec 09, 2003 at 08:11
As I said in the leadup to the body of the post, I did not write the article. It was taken from the campertrailer group site.
For any further information re the jerry cans please join this group and ask.
I think the author of the article is one of the administrators of the group so someone there should know
Jason
FollowupID: 257382
Reply By: Willem - Tuesday, Dec 09, 2003 at 17:48
G'day,
My old truck runs on unleaded and the engine is old technology which sucks the juice. I have a 110-lt fuel tank and carry six jerries in the back of the G60 lying flat(2 plastic and 4 steel). Then if I need to go on a remote trip I can fit another 7 jerries with ease in my trailer. All jerries are secured and have either carpet or foam protecting against rubbing. I have been going bush for a long time and have always carried jerries inside the vehicle. I don't smoke so there is no danger from fumes igniting. I carry my gasbottle outside the truck.
Willem
Always going somewhere
AnswerID: 39760
