Sunday, Nov 27, 2011 at 10:57
There are quite a few differeing
views on this particular issue, and some people are very strident on their position.
The truth is you can " get away" with a variety of different arrangements that may be less than technicaly ideal.
Firtsly, the most impotant issue is isolating the cranking battery so that it does not get flattenend when the other batteries get run down in
camp.
Lots of people get carried away, with discussion about relativly monor issues and forget that this is the main finction of whatever battery isolation you are using.
with that in mind.
lots of people use and many manufactuers detail, the method of simply connecting the second and third batteries in parallel, using an anderson plug to connect the camper or portable battery box, that the third battery is in.
There are technical issues with that that make it less than ideal, but for thousands it is functional.
What is important in any multi battery situation is to supervise and maintain the batteries.
Most of us will be using some for of sealed battery so watering the batteries is less of an issue these days, but we do need to pay some attention to the individual batteries, by seperating them and charging them individually with a good modern charger and checking the voltages at rest after.
this way we will detect any failure in one battery that may drag another down.
the idea situation of course is to have some sort of seperate battery management for each additional battery.
As far as there being "no detectable voltage drop" in the post above......Um sorry there will be voltage drop, perhaps not under the circumstances that you measured it.
In fact unless you are running stonking great 25mm2 pluss battery cable all the way to the battery in your camper, there will be heaps of it at times.
But as long as the voltage drop is not excessive, it will do little more than slow down charging at times of the highest charge current....it can be argued that this is not a bad thing in some situations.
As the batteries fill with charge the charge current will taper off and the voltage drop with it.
In fact the voltage drop that will be present in lighter but still adequate cable will sequence the charge between the second and third battery ( for good or bad).
Given a similar state of discharge, the battery closest to the alternator will get a larger portion of the charge untill its voltage rises and the third battery will then get a larger share.
Most people never discuss or consider the above..but its there.
As far as the whole dissimilar batteries argument......the problems with dissimilar batteries are greatest when batteries are permanently and closely coupled, such as in paralell battery banks where one or more batteries are used in place of one larger battery.
When we have batteries in different locations, seperated by significant distances of wire and with differing loads and states of charge, they will always even if completly identical charge at differeing rates.
But as long as the batteries are in good health sooner or later given enough charge time they will all reach the same charge point dictated by the nominated charging voltage.
remember, possibly the most common reason for battery failure in campers is repeatedly not providig sufficient charge to stop the battery being hammered into its lower limit day after day..
471078
Follow Up By: Member - Frank P (NSW) - Sunday, Nov 27, 2011 at 11:54
Good post, Bantam.
Having two 12V-12V smart chargers such as I mentioned addresses all the issues you raise.
- It is your ideal situation of separate and independent battery management systems for each additional battery;
- It compensates for voltage drop in the cabling. The smart chargers will adjust themselves to compensate as that happens;
- The chargers are galvanic isolators (I think that's the term), so each battery is isolated from all others at all times. Also, when the engine is off the both the Anderson on the back of the vehicle and the one on the trailer are dead (safety, anti-vandalism). You can easily do a switchable bypass so you can have a live Anderson on the vehicle while camped if you want;
- You can have dissimilar batteries without a worry, as they are all isolated from each other and with good smart chargers you can program or set them to suit the batteries they are charging. eg my second vehicle battery is calcium-calcium and needs 15.4 volts for absorption, but my Karavan battery pack is AGM and needs 14.4. The chargers are set to suit.
The downside is the $$$. It's expensive. But so are good batteries.
745606
