Tagalong Tent
Submitted: Tuesday, Nov 29, 2011 at 09:55
Retro72
Hi All,
I have the RV5 plus the peak side walls, I note that a tagalong tent is now an added option to increase the living space. Can someone please confirm if this 'tagalong' tent comes with flooring? I'm trying to understand the differences between having two RV5's with the peaked side walls in the middle or having one RV5, peaked side walls and the tagalong tent (cheaper option)
thanks all,
Reply By: Member - Brenton H (SA) - Tuesday, Nov 29, 2011 at 11:17
By the looks of the picture it does...but sure way to find out is ring them and ask.
471278
Follow Up By: Member - Brenton H (SA) - Tuesday, Nov 29, 2011 at 11:18
Forgot to ask...do those side panels take long to put up.
745830
Follow Up By: Retro72 - Tuesday, Nov 29, 2011 at 11:23
um, yeah they take a little time zipping up and across the top. but they certainly are an asset when the tent is full off beds with no room for clothing and alike.
thanks
745831
Follow Up By: ExplorOz - David & Michelle - Tuesday, Nov 29, 2011 at 14:12
Geez Brenton, has your wife seen your sig? "Accessories for the 4WD or jewellery for the wife?".... can't believe that you don't know the answer to that already! It is so much easier to get everything YOU want, when you give her things FIRST.
Michelle
745855
Reply By: ExplorOz - David & Michelle - Tuesday, Nov 29, 2011 at 14:10
As an RV5 tent owner with kids that are growing bigger, this sounds interesting. Please show me more.. Anyone got a link?
Michelle
471289
Follow Up By: ExplorOz - David & Michelle - Tuesday, Nov 29, 2011 at 15:27
Thanks but I'm confused - the pic looks like two RVs together with the annexe and side panels setup in between. We already have an RV5 with the sidepanels to make the "outdoor" room under the annexe so what do you get exactly for the $559?
745862
Follow Up By: ExplorOz - David & Michelle - Tuesday, Nov 29, 2011 at 15:31
sorry, I should say we also have the front panel, so we are able to make a second room but I like the idea of having the second "bedroom" if you like hang out the other side. Maybe this is in place of having the side panels and front panel - and if so, that's a very cheap option. Do you reckon it would be strong enough without any internal frame though? A wind might put extra pressure on the rest of the tent if it can't hold its own? ummm...
745864
Reply By: Member - michael H (NSW) - Tuesday, Nov 29, 2011 at 14:19
Tagalong has a floor but no internal frame and needs an RV5 to hold it up or if you want you could put two RV5's together with an awning connector.
If you have the deluxe front you can even extend that out and join using same awning connector.
We love them so versatile and Quick
Cheers Michael
471290
Follow Up By: miloaussieguy - Thursday, Dec 08, 2011 at 01:53
hi Retro72, can you let me know how these tents are?
im looking at getting an RV 5..
and what do you do about power when
camping?
ie for laptops and frigde/cooler
thanks
milo
746686
Follow Up By: miloaussieguy - Thursday, Dec 08, 2011 at 01:54
camping?
thanks
milo
746687
