Re - Rated Snatch Points
Submitted: Tuesday, Dec 09, 2003 at 23:03
ThreadID: 9066 Views:2039 Replies:3 FollowUps:7
Hi All
I would like to fit rated snatch points to my 78 series troopy.
Does anyone know of a workshop in Melbourne that does this work.
ARB Northern said they did not do it.
It is a sad overlook by manufactures that they do not fit rated points during manufacture.
What do most of you use instead of rated hooks ?
Reply By: stevesub - Wednesday, Dec 10, 2003 at 09:03
On the rear. fit a tow bar, take out the coupling and use the pin in the receiver hitch.
On the front, this is a problem if you have the factory roo bar as the factory takes the snatch points off and uses the mounts for the bar. What we have done is to replace the bar mounting bolts with high tensile bolts and put a hook on the bar. Not entirely satisfactory in my mind but 3 clubs have said that it was OK and they have to snatch me if we get stuck. The idea of putting it on the bar was suggested by a 4x4 specailst and he said that's where he would mount it.
There is really no other place to put the hook unless you want to go way back under the chassis making it very difficult when stuck to get to the hook with your snatch strap.
Any other ideas anyone for the front. other than buying a new ARB, etc bar and putting a winch on.
AnswerID: 39817
Follow Up By: Member - Ross - Wednesday, Dec 10, 2003 at 10:39
It hasn't happened to me or to anyone I know, but it has been suggested the pin may bend under extreme loading.
I've just done some sums and a 16mm pin spanning 50mm has a significant chance of bending under a 1.5 Tonne loading.
Play it safe and remove the tow ball and use the hole for a shackle. I know the shackle is arse about in this case but if you use a hd shackle you won't have a problem.Fidei defensor
Rosco
FollowupID: 257467
Follow Up By: Member - Ross - Wednesday, Dec 10, 2003 at 10:48
P.S.
With the coupling in place the load on the pin is shear. Safe shear capacity of 16mm pin in this instance is 3200 Kg for mild steel and 8000 Kg for grade 8.8Fidei defensor
Rosco
FollowupID: 257468
Follow Up By: Troopie - Wednesday, Dec 10, 2003 at 12:00
So these posts have raised the same question in my mind. I haven't had my troopie for long and unfortunately don't have the book. It's a 2000 model 78 series non-turbo.
At the front, below the bull bar, are two substantial looking loops which I had assumed were recovery points. There are also what appear to be the usual tie downs nearby. Am I correct in assuming these larger loops are recovery points - as we all know what "assume" can do?
Maybe I should drop into a dealer?
Any responses welcome.
FollowupID: 257478
Follow Up By: Member - Ross - Wednesday, Dec 10, 2003 at 13:08
Troopie
Not familar with your truck but they sound like recovery points .... I'd check first though.Fidei defensor
Rosco
FollowupID: 257486
Follow Up By: John - Wednesday, Dec 10, 2003 at 20:56
Hi Troopie
The two forward loops are the tie down points, they are also removed when ARB bull bar is fitted.
The two to the rear which are thinner plate I understand are actually able to be used to tow with but not for snatching.
The other problem with these two are they above the botom line of the bull bar, which means the tow or if you snatched the snach strap would be impeded by the bottom of the bull bar.
The vehicle requires a rated manufactured/engineerd mounting system to bring any fitted hook below the bottom of the bull bar for a straight unimpeded pull.
I am also concerned about snatching on the tow bar by the pin method or any other attachment point, due to possible shock damage to the tow bar and then any possible problem of tow bar failure during normal towing.
Hayman Reece and Toyota do not rate their tow bars for this type of work, I have a 3500 kg rated tow bar a snatch strap can apply a lot more than this in load.
I have an ARB Bull bar with a Warne winch.
I do not think this problem is confined just to Troopies few other 4wd's seem to have rated points fitted.
As I said it is a real problem.
FollowupID: 257528
Follow Up By: Troopie - Thursday, Dec 11, 2003 at 15:32
Many Thanks John
Me-thinks there are a large number of people out there with the same mis-conceptions about the recovery points on the front of their vehicles....
Anyhow, I'm going to have a wander into a Toyota dealer - probably followed by a trip to a 4wd-shop I guess....
Thanks once again....
FollowupID: 257594
Reply By: maverick - Wednesday, Dec 10, 2003 at 18:12
The dealer will tell you they are recovery points - and Toyota will tell the dealer the same. They are suitable for towing and tieing down the vehicle. As for 12000kg generated during a 'snatch'. No dealer in their right mind will tell you that is ok. Remove and replace with 'rated' recovery hooks. I think approx $18 at ARB / ORE / TJM etc. Cheap for just that little bit of piece of mind. rgds
AnswerID: 39874
Follow Up By: Member - Ross - Wednesday, Dec 10, 2003 at 19:35
12000 kg .... 12 Tonnes, methinks thats a tad adventurous.
Say 2.5 Tonne + perhaps maybe even if we cheat a little... an extra 2 Tonne for suction and boggage etc ....... ????Fidei defensor
Rosco
FollowupID: 257523
Reply By: Hilly - Saturday, Dec 13, 2003 at 21:26
The loops are only shipping tie downs and although they will last one or two snatches ( I was unlucky enough to actually carry out 2 or 3 recoveries before I found this out) they aren't designed for those sorts of forces. The rated hooks also don't fit those holes. I was sold a rated kit which replaces those loops with some angle, approx 40 - 50 mm per side and 3 high tensile bolts and you can then bolt your hooks onto them. It was ridiculously expensive for 2 bits of angle and 6 bolts, about $80 I think, but I knew that I wasn't going to have any snatch problems after that.......
apart from the obvious ones of course...:-)
Hilly
AnswerID: 40149
