Coromal Offroad vans - Towing
Submitted: Tuesday, Jan 24, 2012 at 21:20
Outnabout..
We are contemplating buying a 2nd hand 511 or 535. The 511 is single wheel and the 535 tandem. It will be used for touring and some dirt road travel in outback Queensland. I am just seeking other owners thoughts on the suitability and durability of the Coromal indepentant leaf
suspension. I don'tbelieve they have shockers so I ws also wondering do they need them or if anyone has retrofitted them and how difficult ws it to do.
Thanks in advnce.
David
Reply By: Member - Dalb (SA) - Tuesday, Jan 24, 2012 at 21:32
G'day Outnabout,
I have towed my off-road 535 tandem on many dirt roads inc Gibb R Rd,
Cape Leveque,
Oodnadatta Track, Finke etc with no
suspension problems or damage - just drive to the conditions and you will be OK.
The Coromal
suspension has not changed for many years, because it does not need to in my experience.
Cheers, Dalb
475936
Reply By: John B - Tuesday, Jan 24, 2012 at 22:38
I have a 2009 Coromal excell 511 we tow it on our Nissan X Trail but before we used a Subaru Outback, I never have any problems anywhere and believe the
suspension is A1 Have not been on many rough roads and but never had any problems inside i.e. cupboards. every time we pull up nothing has moved.
We are now selling it for an upgrade. something my wife is not pleaded about.
475940
Reply By: Ian & Sue - Tuesday, Jan 24, 2012 at 23:05
We had a Coromal Pioneer Corvair 541, bought it new in 2008 towed it all over the place including up to the top of
Cape York and numerous trips through the
Pilbara and
Kimberley dirt roads. Never had any problems with it and recently sold it. The people that bought it said they thought it had never been off the black top - we did tell them were it had been.
Sue
Karratha WA
475942
Reply By: Ian & Sue - Tuesday, Jan 24, 2012 at 23:06
Sorry missed a bit - we didn't change anything on the
suspension but alway drove to the road conditions.
475943
Reply By: Member - Joe F (WA) - Wednesday, Jan 25, 2012 at 01:07
Image Could Not Be FoundG'day David
We have a Off Road Pioneer 542 ~ Coromal Corvair ~ and have since buying it new in 2006 travelled some 43000K's admittedly much of these kilometres were simply cruising on the bitumen, but we are not affraid to venture off road with the van either. My adage is ~ if the Cruiser can get in there without trouble, so will the van.
No issues with the
suspension set up, but I do run wheel spacers on all four
wheels just to get a little more clearance between the inner face of the tyres and the wheel arch/mud gaurds on the van ~ no shock absorbers either ~ its an odd set up but it seems to work ok.
475950
Reply By: Member - john y - Wednesday, Jan 25, 2012 at 10:20
G'Day I have a single axle Coromal Pioneer 511 off road which has been off road withouy any
suspension issues.The only issue has been dust ingress which was resolved by having the joins resealed around the wheel wells and under the door step, the dealer did this no problem.I do not tow on dirt roads with the roof pressure hatch open as I believe that this can actually allow dust ingress from oncoming traffic or when your own speed has to be varied.This is my opinion only as others have responded to previous posts and said they don't have any issues.
Good Luck and safe travelling.
475965
Reply By: Member - Kevin S (QLD) - Wednesday, Jan 25, 2012 at 10:37
This has been a very useful and informative thread. We take delivery of a Coromal Magnum off road 520 in about a month. Previously we had a conventional Sekka 535 pop top. Very happy with it but have wondered, as I have read camper trailer manufacturers claims about their shock absorber assisted suspensions, if Coromal had missed something by not putting shockers on their off road vans. I have been fairly certain that the
suspension would operate satisfactorily off road from my experience with the previous van on rough pavement, and the experiences of friends who had the off road version of our van, but it is nice to be reassured.
Thanks all,
Kevin
475966
Reply By: palmy - Wednesday, Jan 25, 2012 at 13:29
We have a brand new Coromal Transforma (single axle version) which has the same off road version of their
suspension. I've only travelled about 2000km with it so far, but have had some bad swaying on the highways. Given what everyone else has said, it has confirmed that I believe we're packing too much gear at the rear of the van so will test this theory next trip.
I don't use any sway control devices or WDH setup.
475974
Follow Up By: Horacehighroller - Wednesday, Jan 25, 2012 at 18:21
My opinion is that everyone towing anything greater than a 6x4 trailer should use a WDH.
Even if it tows OK normally (which your's apparently does NOT), when you are faced with an emergency you will realy want some extra weight on the front
wheels of your tow vehicle - imho.
751015
Follow Up By: palmy - Wednesday, Jan 25, 2012 at 23:32
Don't agree if a WDH only covers an underlying problem, I.e. us not packing the van correctly!!!
751046
Follow Up By: Horacehighroller - Friday, Jan 27, 2012 at 17:35
It doesn't matter how you pack the van.
Any towball weight reduces the weight on the front tyres. A WDH helps to counter that loss and can put some extra weight on the steer to help with the extra 1 - 1.5tonnes that are following behind.
751147
Follow Up By: landseka - Saturday, Jan 28, 2012 at 17:48
Of course it matters how you pack the van.
No WDH will make a van that is way too light on the drawbar tow safely.
As Palmy said, he MUST pack to get somewhere near the recommended 10% ball weight and then the WDH can do it's job.
Cheers Neil
751227
Reply By: ozjohn0 - Saturday, Jan 28, 2012 at 09:51
No comments on the pro's and cons of the
suspension sytem used by Coromal. Only two questions.
1. Why has the relatively cheap Knee
Suspension from
Melbourne Caravan & Trailer Supplies only been chosen by Coromal, but is available to all manufacturers that chosen not to use it.
2. Would you drive your car without shock absorbers?
OJ
476174
