Spirit of Tasmania - restrictions
Submitted: Thursday, Feb 02, 2012 at 20:39
ThreadID: 91621 Views:12012 Replies:9 FollowUps:11
We are booked shortly to travel with our car and caravan to Tasmania. We have been getting somewhat confusing reports on restrictions the carrier, Spirit of Tasmania, places on the following items:
1. Gas cylinders (e.g 9kg) mounted on a caravan: we understand from the carrier's web site that these can remain in place, provided that they are disconnected from the caravan's plumbing for the voyage duration, have effective shut-off valves and meet usual compliance specs. However, some people believe these cylinders will need to be removed from the caravan and carried separately on the ship, to be collected at the end of the voyage. Which is correct?
2. Fuel jerrycans: must be empty and dry of fuel, or filled with water. If they even smell of fuel (i.e. have been used recently), must they be filled with water?
3. Fuel in generators is OK. Is this true?
4. More a quarantine question than a transit one: we carry assorted timber offcuts in the caravan boot for all those odd uses - such as placing under axle stands, the jockey wheel, or for placing under the wheels to level a parked caravan. Does Tassie qurantine need to inspect and/or confiscate these?
Any recent experience/advice would be welcome. Thanks.
Mike & Helen
Reply By: Zebra400 - Thursday, Feb 02, 2012 at 21:00
Mike & Helen
Been to Tassie many times. Always good to check current rules. On there site they say the following:
Q. Can I take gas bottles or hazardous liquids on board?
A. Gas bottles are permitted on board. However, if they are not connected to a motorhome or campervan, they must be declared at check-in. They will be placed on a trolley for the voyage. You will be issued with a receipt, which must be handed in on arrival when collecting the gas bottle. Gas bottles do not need to be emptied.
For conditions relating to the carriage of hazardous liquids including cleaning spirits, please refer to our Carriage of Dangerous Goods Policy.
BTW, dont forget that you cant take fruit & veg (as well as other items) into Tassie.
Laurie
AnswerID: 476698
Reply By: Member - Rod N (QLD) - Thursday, Feb 02, 2012 at 21:01
The web site says "isolated". Ours were left connected in situ. In fact they were not even checked. The spare loose gas bottle and canisters were transported in a special trailer.
The van in front of us had their jerry "sniffed" with a probe. Don't know about fumes.
No. Same as jerrys.
4. More a quarantine question than a transit one: we carry assorted timber offcuts in the caravan boot for all those odd uses - such as placing under axle stands, the jockey wheel, or for placing under the wheels to level a parked caravan. Does Tassie quarantine need to inspect and/or confiscate these?
Only fresh fruit and vegetables.
If you have ang questions either go to the web site or ring them. I rang to inquire about fuel in genny. They are very helpful.
AnswerID: 476699
Reply By: Member - reggy 2 (VIC) - Thursday, Feb 02, 2012 at 21:09
HI Mike/Helen
We took our van over a couple years ago ,just turned off the gas bottles on the van, if the Jerry cans have been used for diesel there might be any problem, the generator just empty the tank, we did not take J/cans as there is plenty of fuel places,we did not have any problems with our wood planks .
There is an issue with the:::::::::::::: pine tree you are not allowed to bring back
sorry can't think of name at present.
You still have issue's with quarantine fruit veggies ect.
Cheers reggy2
AnswerID: 476702
Follow Up By: Member - Wyknot (Qld) - Thursday, Feb 02, 2012 at 22:30
Do you mean houn pine
FollowupID: 751860
Reply By: Motherhen - Thursday, Feb 02, 2012 at 23:19
Hi Mike and Helen
So long as they are CONNECTED (as normal) and shut off, and are in date code they are fine. Loose cylinders are taken and transported separately. We chose to leave our camping stove at home to avoid delays waiting to recover a gas cylinder.
2. Fuel jerry cans: must be empty and dry of fuel, or filled with water. If they even smell of fuel (i.e. have been used recently), must they be filled with water?
If they have been used - fill with water. We did this for one and the other was new and unused so OK dry.
As empty as practical - but of course not filled with water :O
Either leave at home or declare at quarantine inspection and be prepared to lose them. As Australia has strict quarantine on entry to the country to keep out wood borers and the like, probably OK. Check out Tasmanian quarantine requirements here: What can you bring into Tasmania?
For links to the useful sections on the Spirit of Tasmania website, I have got this together as their search does not help (and i have made them aware of the frailties of their search):Spirit of Tasmania
Have a fabulous trip; Tasmania is wonderful and the locals so friendly and welcoming to visitors.
AnswerID: 476711
Follow Up By: newbies - Friday, Feb 03, 2012 at 10:23
Thanks to all for the good advice. One further question: we carry one of those cheap small single burner portable cannister gas stoves as well. These one-use gas cannisters are available in the big dept stores, camping stores etc, and are usually sold in packs of 4. Are these likely to be removed and carried on the ship separately, for collection after disembarkation in Devonport?
FollowupID: 751903
Follow Up By: Motherhen - Friday, Feb 03, 2012 at 10:34
Hi Mike and Helen, Yes it will have to travel separately with the loose gas bottles. Easier to buy a new one when you get to Tasmania and not bother with waiting for collection.
Mh
FollowupID: 751904
Follow Up By: Member - Rod N (QLD) - Friday, Feb 03, 2012 at 11:55
We went thru quarantine last week, and just around the corner was the pick-up point for the gas cylinders, both a 4kg and a pack of canisters. No waiting.
FollowupID: 751911
Follow Up By: Member - Tony (ACT) - Friday, Feb 03, 2012 at 15:18
Thats a bonus last time we went it was a s**t fight with people stopping to pick up their bottles.
FollowupID: 751922
Reply By: Member - Tony (ACT) - Friday, Feb 03, 2012 at 07:02
One thing that has'nt been mentioned is the vehicle has to be free of mud/loose dirt etc.
When we went over a couple of years ago, two 4WD's in front of us had to pull over to the side after leaving the ferry and hose off dirt and mud from underneath. It was a day crossing and dark by the time we arrived, they were not impressed, but should have cleaned the vehicles before boarding.
AnswerID: 476723
Follow Up By: baz&pud (Tassie) - Friday, Feb 03, 2012 at 09:43
Interesting you bring this one up Tony, we arrived home last September and the underneath of the Cruiser was caked with mud.
We new we would have to wash it down, but better to do it in Devonport than in our own drive way, and as we all know you have to wash the mud off just in case there are sum seeds, weeds or what ever that are not currently in Tasmania.
When washed down where does all the water, seeds, weeds go into the Mersey River, it's almost a waste of time.
Baz
FollowupID: 751893
Follow Up By: Member - Tony (ACT) - Friday, Feb 03, 2012 at 15:14
I that case I would go to a car wash, let them worry about it. Proir to our drive out to Mt Mccoll we had to wash down at the parks Depot and that was straight onto the ground. When we came back to return the key I washed down again in the same spot.
FollowupID: 751921
Follow Up By: Inflataduck - Friday, Feb 03, 2012 at 20:49
after sitting in the queue to get back on the ferry customs made us go & wash the truck before they would allow us entry
FollowupID: 751945
Reply By: Kris and Kev - Friday, Feb 03, 2012 at 09:33
We took our camper trailer last year and found they do a very thorough inspection of your vehicle and van! We did not take our jerry cans because there are not that many isolated and long drives. Spent 2 months travelling and never needed extra fuel.
Had two external gas bottles on the camper, one piped in. Both were allowed to stay, both were full, however saw others taking only their spare bottle off, but it was not a big issue, they just picked it up when arrived on the island. Was asked how much fuel in our generator and I said just a little and that was OK. Had a tool box on the top of our cruiser, carries chainsaw, oil, spares etc, but they did not look in it, just asked what was in it. (After we got off I realised I had a 5 litre fuel container in it and it was full!)
Remember, you cannot get access to your vehicle once the ship is under way.
AnswerID: 476742
Reply By: Sigmund - Friday, Feb 03, 2012 at 12:14
Last time I went over preserved meats were also confiscated.
The mud is unwelcome there because it can carry cinnamon fungus.
Clean wood, even green wood, no trouble. Folk bring back bootloads of Huon Pine, Tassie Myrtle, Blackwood, Sassafras etc.
AnswerID: 476764
Reply By: Holden4th - Saturday, Feb 04, 2012 at 09:36
I can't see any need for taking jerry cans unless you needed them for your trip on the mainland. If you drive more than 100 kms without seeing a servo I would be very surprised.
AnswerID: 476830
Follow Up By: newbies - Saturday, Feb 04, 2012 at 11:57
Point of clarification: I'm taking my jerry cans becuase we are two thirds of ouir way travelling around the country - home is Perth. Therefore, there is no easy storage option for us in Melbourne for things that might cause some inconveneince getting on or off the ferry. I do not expect to have to use them at all in Tassie, apart (perhaps) from one small petrol jerry for the generator, if needed.
BTW, is there street or off-street parking for cars with caravans near the ferry embarkation point in Melbourne (i.e. before they open the gates for the pre-boarding inspections)?
Mike
FollowupID: 751996
Follow Up By: Nomadic Navara - Sunday, Feb 05, 2012 at 18:05
The day and time of departure would have been a help for those answering.
We spied some good parking along the waterfront at St Kilda suitable for an evening departure. However we were travelling on the weekend. When we got there every man and his dog was at the beach and no parking.
I would suggest you get to Melbourne a couple of days early. Do a dummy run to see how long it will take to get to the terminal. If you can find some parking in the back streets within walking distance you can go up to an observation platform and observe the circus you are about to join as a performer.
I would suggest you don't arrive too early for departure. They load vans last, if you are there too early you will be hanging around on the pier without facilities for far too long. I aim to arrive around half an hour before departure. If you have a morning departure, factor in peak hour traffic.
FollowupID: 752188
Follow Up By: newbies - Monday, Feb 13, 2012 at 20:54
Follow-up comment for Spirit of Tasmania boarding: There was a relatively superficial inspection pre-boarding. I was asked about loose gas cannisters and volunteered the throw-away cannisters for the little portable stove, which were removed and carried separately on the ship. The authorities asked to look inside the engine bay (of most cars), but am not sure why. I was asked about two visible petrol jerry cans, which I had filled with water - they took my word on it. I volunteered I had 3 empty diesel jerry cans in the boot, but I was not asked to show them. There was a very quick look inside the caravan, but not under the bed or in any cupboards. I was not asked whether I had a generator, even though mine was pretty obvious, being locked inside a large aluminium checkerplate box on the draw bar. In any case, prior to boarding, I had siphoned the generator tank empty.
At Devonport, the quarantine inspection was also fairly painless, and much faster than I expected. All in all, a good outcome.
Mike
FollowupID: 752942
Reply By: Member - Barry P (VIC) - Saturday, Feb 04, 2012 at 19:53
went on ferry about 6 years ago .just before the ship arrived in devenport was looking at the stern deck where the trailer was that was holding all the loose gas bottles and here was the deckhand leaning on the trailer merrily smoking his head off.maybe they have never heard of worksafe on the ship.after this went and opened a stubbie in case it was the last before the big bang bye barry
AnswerID: 476880
