Cleaning polished alloy bullbar
Submitted: Monday, Dec 15, 2003 at 23:26
ThreadID: 9174 Views:14844 Replies:14 FollowUps:6
I tried using armorall wheel cleaner on my bullbar and it left streaks all over it. I now have to rub the crap out of it with mag wheel cleaner [cotton wool in yellow can] but its going to take hours. Anyone know any better way?
Reply By: Truckster (Vic) - Monday, Dec 15, 2003 at 23:47
Brasso has stuff called something like Silvo.. it works.
The other way is Mothers Brand of polish, all the harley hardheads use it back home.
There is no really easy way.. it will take work.
AnswerID: 40325
Reply By: mrdesmo - Tuesday, Dec 16, 2003 at 01:15
Yep, ditch the alloy and get a steel bar! First thing i did to my 80 when I bought it....looked like far too much hard work.
I used to use Autosol on the alloy crankcases of my Ducati's....comes up awesome, but a lot of elbow required....could get a mirror (almost) finish after a while.
AnswerID: 40330
Reply By: Willem - Tuesday, Dec 16, 2003 at 07:54
Soap and a Curly Girl...no, its a wire scourer!! It polishes a treat but there is no easy way.
Willem
Always going somewhere
AnswerID: 40338
Reply By: Robert - Tuesday, Dec 16, 2003 at 08:24
There’s no need to keep having to continually polish an alloy bullbar.
Just polish it the once and then spray it with a clear lacquer . You can buy this in a spray can from any place that sells automative paint, it’s a clear top coat used for sealing metalic paints.
If for any reason in the future you want to remove the clear coat, it’s easily removed using paint stripper.
AnswerID: 40339
Follow Up By: chrisfrd - Tuesday, Dec 16, 2003 at 11:28
Bloody good idea!
Cheaper than having it powder-coated!
FollowupID: 257964
Follow Up By: Truckster (Vic) - Tuesday, Dec 16, 2003 at 16:37
Problem with some laquers is that they turn yellow... And having a shiney polished bar wouldnt be the easiest thing to work with...
FollowupID: 257979
Follow Up By: Robert - Thursday, Dec 18, 2003 at 07:58
Just make sure you use automative lacquers and it isn't a problem.
FollowupID: 258106
Reply By: Well 55 - Tuesday, Dec 16, 2003 at 08:52
I just give my ARB steel bar a wipe over after every trip to remove the bugs and after 5 years still looks like new,
AnswerID: 40344
Reply By: Member - DOZER- Tuesday, Dec 16, 2003 at 10:25
Gday John
If you dont want to be tied down to cleaning this bar, a good way is to take it off and have it powdercoated. There are a few nice hamertone colours aswell as the straight finishes available.
Otherwise, hire a buffer and polish it up. This wont last that long, so try some Mr sheen to protect the finish :-)
Andrewwheredayathinkwer mike?
AnswerID: 40351
Follow Up By: Truckster (Vic) - Tuesday, Dec 16, 2003 at 16:38
Or Annodised!
FollowupID: 257980
Reply By: Member - Melissa - Tuesday, Dec 16, 2003 at 12:15
John,
You can buy alloy/aluminium polish from most auto stores (even Big W etc). Small pot for under $10 lasts for months. Idea is to rub it on, then rub off doing a small area at a time. I've been using this stuff for years and find it very effective - brings the bar back to mirror perfection and will also remove minor scratches and blemishes.
If your bullbar hasn't been done before it'll probably take a fair bit of elbow grease the first couple of times to get it back to mint condition but its worth the effort. A trick I use is to use very fine grade of steel wool (the non-soapy stuff from the supermarket is OK) to lightly rub in the polish but start on an inconspicuous spot first to make sure it doesn't adversely effect your particular bar and until you get your technique/pressure right. A metal polisher I know put me onto this trick and I've found it takes a lot of the hard work out of it.
:o) MelissaPetrol 4.5L GU Patrol &
Camprite TL8 offroad camper
http://members.westnet.com.au/flatdog
AnswerID: 40360
Reply By: Radar - Tuesday, Dec 16, 2003 at 12:35
John,
I used to be an interstate truck driver. I found the best way to clean alloy fuel tanks and bullbar was with an electric buffer and a number 2 car polish. Brings them up like new.
Regards,
Radar.
AnswerID: 40363
Reply By: Diesel Do - Tuesday, Dec 16, 2003 at 13:15
John,
Try the magic paste called "Gumption" - we buy it at the supermarket and have used it for years. Comes in a white plastic tub with a yellow top. Seems to be able to take anything off anything easily. We use it to clean the glass in our combustion heater, and anything else that has deep stains - like bird crap on the poly outdoor furniture. It hasn't scratched the glass or the plastic.
Alternatively, you could get some of that European 4wd cleaner called sprayonmud. Available from Mercedes, Porsche, Volvo, VW etc...
AnswerID: 40368
Reply By: jemima puddle duck - Tuesday, Dec 16, 2003 at 18:54
gday john.
with out sounding like a smarty.
go pay an alloy cleaner this time.
get it right up to scratch might cost you $100(ive no idea)
then in future it wont be nearly that hard to clean.you reckon your cute
richard(eskimo)
but im a lot cuter
AnswerID: 40410
Reply By: maverick - Tuesday, Dec 16, 2003 at 19:52
I've obviously been doing the wrong thing - had my alloy bar for 10 years (not quite straight now) and have never polished it. Please someone tell me why on earth you want to polish a bull bar. rgds
AnswerID: 40413
Follow Up By: macca - Tuesday, Dec 16, 2003 at 20:14
I'm with you Maverick. Had my alloy bar on the cruiser for 350K and just used soapy water when I washed the truck and glory be the alloy bar still looked like an alloy bar when I sold the dear old thing. Please !no offence meant
FollowupID: 257998
Follow Up By: Member - Melissa - Thursday, Dec 18, 2003 at 17:53
If you polish the duco, clean the wheels, black the tyres etc to get the vehicle looking smick, why wouldn't you polish the alloy bullbar??? Just my humble opinion...
FollowupID: 303148
Reply By: ToyMotor - Tuesday, Dec 16, 2003 at 22:42
This reminds me of Ted Bullpitt - "Yer not takin' the Cruiser!! I just Armoralled the bullbar!!!"
JMFAAH*
(For the acronymically challenged, "Just My Feeble Attempt At Humour")
AnswerID: 40430
Reply By: Cumbo - Wednesday, Dec 17, 2003 at 18:02
Was talking to a metal polisher in a factory bay up from me the other day asked him your question.
He said their was only one product he would use neamed Reflection
He dropped me in a tube today and we tried it on the GQ which I guarantee has not been touched since new.
WELLLL. Talk about bring up a shine. It will take a bit of elbow grease but the results from just one speck on a rag was amazing.
The product is Reflection Metal Polish "the polish that turns metal into mirrors"
Its in a 130 g tube and the manufaturer of the pack is Ferro Finishing Pty Ltd 3 Larkin Street PO Box 245) Riverwoos 2210 Sydney Tel 02-95341155
Sorry didn't get time to ask is it in any of the stores and NO I don't have any link to the company but rest assured I will be doing the rest of the bar because if I don't its going to look out of place.
Hope this helps
CumboTD42
EFS
TX4400
Safari Snorkel
Rola Racks
Milford Barrier
Engel 39l
AnswerID: 40487
Reply By: Michael - Tuesday, Dec 23, 2003 at 01:01
Thank god i bought a steel bar, a real bar is a steel bar............., Michael...
AnswerID: 40930
