Re - Using Lap Top with GPS
Submitted: Tuesday, Dec 16, 2003 at 16:09
ThreadID: 9182 Views:2123 Replies:5 FollowUps:13
Hi All
I have a Meridian Gold GPS and Discover Aus Streets and Tracks.
Can I link the GPS to the lap top with this software for moving map display on the lap top or do I need additinal software ?.
I have looked at the help menus and can't see any info on Dis Aus about this.
Maybe i am just not looking at the right area, any help appreciated.
I have the data/power cable.
Reply By: Member - Bob - Tuesday, Dec 16, 2003 at 17:15
John,
nothing extra is needed. Just go to GPS settings under Options and make sure your laptop can see the GPS, then under GPS Log hit Start.
You may need to switch on NMEA on the GPS and adjust Baud rate.
AnswerID: 40398
Reply By: petprass - Tuesday, Dec 16, 2003 at 17:32
That's right - as Bob said you have everything you need. The help menu is strangely silent about this function. I also didn't know that DAST had this function at first - I was actually going to buy other software that is available.
When I first set it up I had the NMEA in the wrong setting. I think it has to be set at V2.1GSA.
AnswerID: 40402
Follow Up By: John - Tuesday, Dec 16, 2003 at 17:59
Hi Peter
Default settings appear to be 2.1GSA and 4800 Baud Rate.
Would you agree ?
FollowupID: 257988
Follow Up By: petprass - Wednesday, Dec 17, 2003 at 14:25
Yes that is right.
FollowupID: 258054
Reply By: John - Tuesday, Dec 16, 2003 at 17:57
Thanks Guys I knew it had to be simple, right under my nose.
As you said the menu is not real clear about this feature.
Only problem is I have to take it outside to get a fix on enough satelites for it to work and it's as hot as hell out there.
Many Thanks.
AnswerID: 40407
Reply By: Member - JohnR - Tuesday, Dec 16, 2003 at 20:57
Hi John, I have a Meridian too, but a Platinum. Do you have a special need to have a bigger screen. You can load your Streets and Tracks maps straight into the SD cards the Meridians are designed for leaving the laptops off until you need them. You get more menus with an SD card in, even the small one I have.
Is there a need for that computer on, I had mine on last week and was useful, but without the GPS. Now I wouldn't bother if I had the appropriate maps loaded!!
Yes, I need do glasses on to read it when I need to, so they are on the nose low down!
Regards John
AnswerID: 40423
Follow Up By: John - Wednesday, Dec 17, 2003 at 00:01
Hi John
Thanks for the reply, I have been using it as a stand alone and uploaded the maps I need.
But the screen is a bit on the small side and I would like to try it with a bigger screen to see how much better it is.
The small screen is difficult to read when you are on your own in the car and you are trying to watch the track as well as navigate, this is a real consideration when you are in a convoy with Toonfish and Diamond and Toonie has the only paper map and needs lessons on how to read it, Remember he is the trip leader any wonder we kept getting lost.
FollowupID: 258023
Follow Up By: Member - Bob - Wednesday, Dec 17, 2003 at 08:14
John,
I sould warn you that once you've seen it on the big screen you will never go back. I find the big problem with hand held is that you can't see enough of the surrounding map to 'place' yourself. When you hit 'out' a few times all the detail disappears. With a screen mounted on the dash the driver and all occupants can see the moving map display continuously. It really adds an extra dimension to travel. "Are we there yet?" need never be asked again.Bob
FollowupID: 258033
Follow Up By: John - Wednesday, Dec 17, 2003 at 13:18
You are spot on with what you say about placing yourself, that the main problem I have had for the same reasons.
I fear you may be right about the never going back situation.
FollowupID: 258049
Follow Up By: DaveMc - Wednesday, Dec 17, 2003 at 14:21
I agree Bob...
Jumping on the bandwagon here, but I recently bought a GPS Mouse ($99 on ebay). Just a GPS receiver that plugs into a usb port on the laptop. IT'S GREAT! I reckon that the etrex will gather dust unless we do some long distance bush walking.
We LOVE the big screen view, and combined with OZI, we have a feature-packed in-car navigation system with scrolling maps for under $250! (Yeah, yeah, if you have the laptop already)
If any of you are considering one of these usb GPS mice, and are worried that they might be dodgy, they work great. With a magnet on the bottom, it rides on the roof. 8-10 birds in view no problem.
FollowupID: 258052
Follow Up By: petprass - Wednesday, Dec 17, 2003 at 14:30
Bob,
"With a screen mounted on the dash the driver and all occupants can see the moving map display continuously."
Do you have a remote LCD screen for your moving map? If so, how did you fix it to the dash and how does it handle rough conditions.
I don't use the laptop as it is too large and cumbersome - the navigator says I can have it on my lap!! (don't blame her really)
FollowupID: 258055
Follow Up By: DaveMc - Wednesday, Dec 17, 2003 at 15:05
Hi Peter,
Go to post id: 8526 and there's a picture of a pretty good looking laptop mounting system. And down in the replies I think our Bob says that he has a 15" monitor in his wagon!
I think the novelty is wearing off for my navigator as well. Fortunately it's a pretty small laptop, and creating some shelf arrangement shouldn't be too bad.
FollowupID: 258057
Follow Up By: petprass - Wednesday, Dec 17, 2003 at 15:23
Thanks Dave,
I think the best solution if you want to go large screen is the remote screen. Those brackets/stands are a fairly invasive.
FollowupID: 258059
Follow Up By: DaveMc - Wednesday, Dec 17, 2003 at 15:41
Yep, that would be a great way to go.
Take a look at link text
It even has a touch screen feature! Maybe after Christmas...
FollowupID: 258061
Follow Up By: petprass - Wednesday, Dec 17, 2003 at 16:48
If I was certain that it could be fitted easily, securely and could be removed easily when not in use - I would buy it right now.
FollowupID: 258071
Follow Up By: Member - Bob - Wednesday, Dec 17, 2003 at 18:20
I use a Samsung 15" display. I removed the four screws on the back that attached it to the desk stand and attached an aluminium flange that I made. This attaches to an aluminium bracket that stands out from the radio area of the dash and up from the transmission tunnel. When I tried it out the mass of the monitor caused too much flex in the mount so I used mini ocky straps from each corner of the screen to the rear view mirror above and to the transmission tunnel below. While it may sound a bit complex, it didn't interfere with vision at all and works an absolute treat. It is easily removed and stored in an aluminium case from BigW, or simply throw a towel over it when camped in the bush. Cost $540. There are cheaper smaller displays that may be more practical.Bob
FollowupID: 258078
Follow Up By: Member - JohnR - Wednesday, Dec 17, 2003 at 23:00
I guess folks I will evaluate it all when I do more tripping, but getting dust into my good laptop is not too attractive even though mine is a small one for carrying. The Navigator does not like carrying it much either. The small screen sounds good to mount somewhere when I get some more cash about!
Actually I like the thought of the GPS Mouse that DaveMc suggests as a backup to what I have. Not much more than the combo lead/computer and 12v to the GPS and may be tidier
I have thought some of the mounting systems a bit obtrusive particularly in case of possible impact with the navigator or driver. Some vehicles don't have a lot of dash room when you start mounting large screens too, though my internal mirror is now only used for monitoring the fridge temps.
Am glad you guys think the moving image is not another distraction to the driver. lol
FollowupID: 258094
Reply By: paulp - Monday, Jan 12, 2004 at 20:05
I navigated my way across the USA and all around it when I worked there a few years ago with a Garmin GPS and a laptop. Would never use anything else. What to people think of the DiscoverAus software? Is it worth the cash? Does it only work with Magellan or will it work with other NMEA compatible GPS?
What I'm looking for is:
a) Trip planning & route choices
b) On and off road
c) Moving map with progress against the planned trip
d) Built in Australian maps - I'm not the slightest bit interested in going out and buying more maps!
Paul
AnswerID: 42713
