inverters
Submitted: Tuesday, Dec 16, 2003 at 19:52
ThreadID: 9184 Views:2292 Replies:4 FollowUps:2
Gday. I'm interested to know if you can buy an inverter that converts 240V to 12 V. We have 2 x 12 Volt flourescent lights which I hope to be able to run off 240 Volt with the appropriate inverter (if it exists?) I went to Dick Smiths and they didn't seem to have one. Can anyone advise me please?
Reply By: timj - Tuesday, Dec 16, 2003 at 20:08
You don't want an inverter but rather a 12 volt power supply. They should be available from Dick Smiths or Jaycar. I don't know what sort of issues you might have running a flouro straight off a power supply though so perhaps just get a 12 volt battery that you can recharge using a normal car battery charger.
AnswerID: 40415
Follow Up By: Steven - Tuesday, Dec 16, 2003 at 22:37
Thanks timj,
I'm onto it.
Steve
FollowupID: 258013
Reply By: Rob H - Tuesday, Dec 16, 2003 at 21:40
Hi Steven
You are after a rectifier, not an inverter. But I'm with Tim. A 12v power supply seems a much better idea. I picked up a Projecta 17ah single cell jump starter from Repco for $100 after researching back up power on this forum. You then have the advantage of being able to jump start the car if your battery goes flat, so long as you don't run the fluoro's for too long. Most of the fluoro's I've come across are 9 or 12 watt, so only use 1 amp per hour off a 12v battery. With the 17ah jump starter, you could run the lights for a good few hours, and still have enough juice to jump start the car in the morning, then charge the unit up again while travelling ready for the next night.
Hope this helps
Rob
AnswerID: 40427
Follow Up By: Steven - Tuesday, Dec 16, 2003 at 22:39
Thanks Rob,
That sounds like what I'm after. I appreciate your help.
FollowupID: 258014
Reply By: volvofh12 - Wednesday, Dec 17, 2003 at 01:47
BIAS boting warehouse sells the kind of invertor your talking about/after for under $100 dollars. www.biasboating.com.au
AnswerID: 40440
Reply By: Member - NOBBY - Wednesday, Dec 17, 2003 at 18:44
I have just been to Springers (Brisbane 3889 8898) and they sell a Waeco Set up you are looking for. Model no. n4213 and ranges from 100 - 140 $. They also do phone orders etc. It converts 240 into 12v.Jack at sleep
AnswerID: 40490
