Copying of Natmap Raster maps
Submitted: Thursday, Dec 18, 2003 at 14:58
ThreadID: 9217 Views:2166 Replies:10 FollowUps:9
I have just purchased the Natmap Raster 250K mapsheets on CD from Explore Oz. As I don't want to take the originals with me on a trip, I decided to copy them. (I don't want to put them on the hard drive due to space constraints).
CD 1 copied fine but CD 2 won't. I have Roxio (Easy CD Creator platinum 5) and use windows XP. I have tried direct CD, Data CD & Disc Copier, all to no avail. The test works fine, but when trying to copy disc 2, I get the message "error from output device".
Any ideas please?
Reply By: Member -BJ (Sydney) - Thursday, Dec 18, 2003 at 15:47
Dave, try copying to hard drive then to disk, if it works delete from hard drive. You will have to load the raster viewer to your hard to view the maps on the cd's.Regards Bob
Where to next
AnswerID: 40547
Follow Up By: Dave - Thursday, Dec 18, 2003 at 16:13
Thanks Bob,
I have already tried puting it on the hard drive - it still won't copy & comes up with the same message. I don't like the thought of having to carry the originals on a trip into the hot areas.
FollowupID: 303128
Follow Up By: Member -Bob & Lex (Sydney) - Thursday, Dec 18, 2003 at 17:30
Like chris said maybe the disk is damaged Mine copied easily , even copyed them to my Ipac as SWMBO got sick of nurseing the laptop.Regards Bob
Where to next
FollowupID: 303146
Follow Up By: Member - Errol (WA) - Thursday, Dec 18, 2003 at 21:58
Bob & lex Got the same prob with my laptop , the war offic dos,nt want to nurse it eather . Could you send me the details of your Ipac please , as im, thinking of going that way myself . Nobody around here knows much about them , or witch one would be sutable . Thanks in abvance .Why go overseas when you can ExplorOz
ERROL
FollowupID: 303159
Follow Up By: Member -Bob & Lex (Sydney) - Friday, Dec 19, 2003 at 16:46
Errol, The Ipac option is expensive when you add ozi CE version for Ipac & SF or CD storage cards for your maps. I'm lucky mine is for bussiness so can right it off. check out post 9182 in the follow ups for a remote screen option for $300 which looks great & screen is 7in, Ipac screen is 80mm high & 60mm wide + maps are slow to load in moving map as oposed to laptop speed. If you do need more info on Ipacs check out the ozi ce site @ yahoo groups. By the time i payed for the Ipac, expansion pac ,storage cards , power & data leads it was about $1800.00Regards Bob
Where to next
FollowupID: 303220
Reply By: chrisfrd - Thursday, Dec 18, 2003 at 16:52
Hrm...
They are either copy protected or the 2nd disk is damaged.
Try to copy the maps off the CD, then reburn the directory.
It this doesn't work, report the disk under warranty.
AnswerID: 40560
Reply By: Member - Bob - Thursday, Dec 18, 2003 at 17:28
Which version is it Dave - the latest Oct 2003 one?Bob
AnswerID: 40562
Follow Up By: Dave - Thursday, Dec 18, 2003 at 18:36
G'Day Bob,
It is the Nov 2002 one.
FollowupID: 303150
Follow Up By: ExplorOz Team - David - Thursday, Dec 18, 2003 at 18:59
Dave did you buy the discounted version as we only have the 2003 units available. We did offer the last older one at a special price being the last disk we had. In any case this should not be the problem.Regards
Always working, not enough travelling ;-)
FollowupID: 303153
Reply By: ExplorOz Team - David - Thursday, Dec 18, 2003 at 18:15
Another thought - As the system is telling you error on OUTPUT device this means the drive you are copying to not from, what size CD are you writing to - Is it big enough to hold all the data - ie. You are not trying to write 700MB to a 650MB media!Regards
AnswerID: 40563
Reply By: Member -Bob & Lex (Sydney) - Thursday, Dec 18, 2003 at 18:26
Dave , I just copied mine again & it worked fine but mine are series 2 so maybe the disk is rs.
ps If anyone has updated to the new Rasters i would like to know if it is worth while.
Regards Bob
Where to next
AnswerID: 40567
Follow Up By: ExplorOz Team - David - Thursday, Dec 18, 2003 at 18:48
Yes but if the supplied disk was RS how can he copy the data from the CD to the HDD. I have been emailing Dave direct and he has been able to load the CD onto his HDD. Then when he goes to take the copy from the HDD to a blank CD he gets this error.
This means there is nothing wrong with the original CD! It is not even in the machine when the error come up.
If there is fault we will of course swap it, but he can take the data from the CD to the HDD it fails when he is writing back to a blank CD.
This is why I am wondering about the size of the disk he is writing to and the size of the original CD. Series 2 - Disk 2 is smaller in size than new one.Regards
FollowupID: 303151
Reply By: Goran - Thursday, Dec 18, 2003 at 21:29
There is known conflict between Easy CD creator and XP. Go to Kazaa lite and download Nero 6 ultra. If you can read what is on the cd you will be able to burn it.
AnswerID: 40579
Follow Up By: cokeaddict - Thursday, Dec 18, 2003 at 22:37
The only conflict between easy cd platinumand win XP is if you install easy cd platinum without the upgrade.
BUT REMEMBER, WHEN U DOWNLOAD THE UPGRADE. MAKE SURE U UNINSTALL THE ORIGINAL FIRST, THEN RE INSTALL IT, and at the end of the install when it askes you to reboot...SAY NO..and start installing the upgrade, then re boot and your problem is solved.....if this sounds complicated, you are welcome to email me ...i will try to simplify it for anyone interested.. cokeaddict@optusnet.com.au
regards Angelo I love it when you talk DIRTY !
FollowupID: 303162
Reply By: Goran - Thursday, Dec 18, 2003 at 21:30
It could be bad disk quallity as well.
AnswerID: 40580
Reply By: Member - Bob - Thursday, Dec 18, 2003 at 22:14
Dave,
I'll send you a copy. Just give me a postal address.Bob
AnswerID: 40588
Reply By: Dave - Thursday, Dec 18, 2003 at 23:05
Bob, that is very kind of you - Thank you very much. Before I impose, I will try and burn a copy on another computer tomorrow. It will be interesting what happens. I will keep you informed.
AnswerID: 40596
Reply By: Dave - Friday, Dec 19, 2003 at 12:58
Thanks everyone for your help.
I have easily copied the disc on another computer using Nero software.
AnswerID: 40647
Follow Up By: Member - Rohan K - Monday, Dec 22, 2003 at 12:34
Nero's the way to go Dave, but you'll now need to have it loaded onto your PC to read the new CD.Smile, you're on ExplorOz
Rohan (Sydney - on the QLD side of the Harbour Bridge)
FollowupID: 303377
