Trailers and the Simpson
Submitted: Thursday, Dec 18, 2003 at 23:16
ThreadID: 9228 Views:2628 Replies:10 FollowUps:6
Learned Forumites - a perennial topic
I have searched the threads, and have found a multitude of comments, some well informed, and some ill informed. What I am interested in is comments from people who have actually towed a properly set up camper trailer across the Simpson, or who have travelled with someone who has. Friends have taken trailers, no problems, but others say "no way" (yes, the old arguments)
We have a properly set up unit, towed to Cape via OTL etc, done many off road trips, including steep terrain such as Bendethra etc (not via Moruya), and have a capable Patrol with Diff Lock on front, good suspension, diesel etc. ie, we're not novices, and aren't afraid of sand and dunes.
I want to take a tent, she wants the comforts of the mattress and the kitchen. We are at an impasse.
Is it possible? In addition to any general comments, would be very interested in the amount of fuel used by diesel vehicles towing. We are planning to travel in about July.
Hendo
Reply By: Member - Ross - Thursday, Dec 18, 2003 at 23:37
Hendo me old son.
Search harder. Not saying it's been done to death, but there was a most interesting discussion on this very subject only a short while back.
Can't give you the number but ... "Search and yea shall find".
You never know .. you may pick up a few extra tips on your peregrinations.
Cheers ... ;-]Fidei defensor
Rosco
AnswerID: 40600
Reply By: Geoff - Thursday, Dec 18, 2003 at 23:37
Hendo,
I have done it twice before, had no problems and minimised the impact on the environment unlike many who simply do not know how to drive in the conditions........ie vehicles (not towing) going too fast with tyre pressures far too high for the conditions; from what you say above I would not expect you to have any problems as an experienced sand driver provided you are prepared to run your tyres on car and trailer at appropriate pressures for the dunes.......ie from as low as 13 psi if you have to but generally around 16 psi dependant of course on tyre type and load. You need to take it easy (the Simpson is delicate country) and keep your weight down to essentials. Naturally a vehicle that is not towing is preferable in this delicate environment and you will get many pushing this view........an experienced sand driver however can do less damage with a trailer than many (who don't seem to care less about the environment) do without a trailer.
Cheers geoff
AnswerID: 40601
Follow Up By: Willem - Friday, Dec 19, 2003 at 00:11
I tend to agree with you Geoff. I have a trailer but am not an exponet of trailer useagse and I have not towed a trailer across the Simpson. Your sentiments seems pertinent to what you are saying. If you know what you are doing then you would have no trouble crossing the dunes towing a trailer. I have however, voiced my opinions against novices taking trailers over the dunes as inexperience accounts for a trampling of the dune track surfaces making it difficult for travellers who pass over those chewed out tracks.
So all of you who read this post and those of the archiverplease take note of what is said and follow the advice to the letter.
Willem
Always going somewhere
FollowupID: 303169
Reply By: V8troopie - Friday, Dec 19, 2003 at 00:29
Hendo, here is something you will have to consider when towing a trailer over sand dunes. By dunes I mean the larger, many humped kind, as I encountered on the Canning north of well 23. I am assuming there are similar ones in the Simpson desert though I have not been there (yet).
While you may be able to tow a trailer up and over these dunes you will have great difficulties backing down a dune with it. And you also will have problems unhitching it and trying to push it down. On a deeply rutted dune the only way is forward while towing a trailer.
Just with a car, should it run out of grunt partway up, its no problem to back down and try again with a longer run up/ different gear selection etc. A trailer will most likely jack knife then and give you lots of grief.
Forget winching up a large sand dune unless you like digging in a considerable size anchor lots of times at each dune.
The only way to cross a dune with a trailer, IMO, would be to walk it first, checking the lay of the track, the ruts and if there are obstacles requiring a stop, like another vehicle on the far side. Then you need sufficient grunt to easily get over it, no gear changing allowed unless you drive an automatic. If you think you can manually change gears while charging up a winding dune you are a better driver than me :-)
Walking every dune will get you very fit, I know, I've attempted the Canning once from well 9 to the Talawara track with an unsuitable vehicle (not enough ground clearance) and learned a healthy respect for the terrain out there -we got through back then but lost near 10kg each from shovelling sand :-)
Having said that, we did come across a Landrover club convoy at Durba Springs who were towing "trailers". These were rather special beasts and resembled a 200 litre drum on wheels. It was all custom built, using a similar suspension & wheels as their cars had ( presumably so they could use parts for spares) and they had a towball front and back of the trailers. They also carried solid tow 'rods' with a hitch on each end. In fact, they could link up several car and trailer combinations ( the cars also had front tow balls fitted) like a giant caterpillar and cross dunes with multi wheel drive.
I have also seen several abandoned trailers on the stock route, possibly by people who were not as thoroughly prepared as the above group.
You will have no problems at all towing the trailer in the valleys between the dunes.
I carried 150l diesel in two car tanks and another 120 in 6 jerry cans which got us from well 23 to Halls Creek via a detour through Balgo due a swamped track at weel 50, with 40 litres to spare. My troopie then still had the original 2H motor.
Klaus
AnswerID: 40607
Reply By: Member - DickyBeach - Friday, Dec 19, 2003 at 06:36
Hendo,
When you searched the threads I trust you came across 8436 and 7590 both relevant to your query.
The chopped up dunes are caused by cars hitting the dunes too fast, the car bounces, the rear wheels lift and, spinning, thump down on the sand and spew it out, causing ruts in the process.
By driving slowly with low tyre pressures there's no bounce and thus no chewing out and wrecking the dunes.
The CSR with its multi-humped dunes presented no problems to my LC and KK this year.
The reference to backing down and taking a longer run-up worries me as it implies speed - exactly the wrong approach; you'd be better off lowering your tyre pressures. I trust you have a compressor.
The broken trailers on the CSR were grossly inadequate, one with 2" x 2" angle iron frame TACK WELDED, another out of water pipe - totally inappropriate.
Have fun balancing out the usual cross section of replies.
DB
AnswerID: 40616
Follow Up By: Eric from Cape York Connections - Saturday, Dec 20, 2003 at 07:46
DB you are spot on .
Hendo read what DB writes he is spot on the quality of the trailer makes a big difference . We take trailers up the cape on tag alongs but only certain brands or certain specs we have to know.We have seen to many garden trailers on the side of the road /track that have fallen apart .
all the best
Eric
4x4 tag alongs to the cape and beyond.
www.capeyorkconnections.com.auCape York Connections
FollowupID: 303266
Reply By: Phil P - Friday, Dec 19, 2003 at 06:45
Hi Hendo,
I agree with your comments about getting informed comments/experience from people that have actually crossed the Simpson with a CT. I have spent many hours searching this very same question and have found more conflicting information than the discussion between what brand of Fridge to buy !
I am planning to cross the Simpson from Dalhousie to Birdsville next year with my CT, and with all the searches I have done on many forums the consensus is that it can be done quite easily if you have the correct tyre pressures (car & trailer).
Good question !
Phil P
AnswerID: 40617
Reply By: Rob from Cairns Offroad Training & Tours - Friday, Dec 19, 2003 at 09:16
We towed a tandem wheeled trailer across the Simpson from Birdsville to Mnt Dare in 2001 as backup for a film crew. Our vechicle was a Nissan 3.lt Patrol auto with 15 x 39 tyres run at 12 lb same as on the trailer. We had no problem tho a couple of the windy dunes took a couple of atempts Momentum was the key made much easier with the auto. Backing down a windy sand dune was interesting as it would have been impossible to go forward again without momentum. Our trailer was much heavier than a CT and I feel an experienced well prepared driver with a well setup CT should have no problems specially in an auto. Cheers Rob Cairns Offroad Training & Tours
AnswerID: 40625
Follow Up By: Phil P - Friday, Dec 19, 2003 at 18:26
Hi Rob,
Did you tackle "Big Red" with the tandem ?
Phil P
FollowupID: 303228
Follow Up By: Rob from Cairns Offroad Training & Tours - Friday, Dec 19, 2003 at 20:47
Big Red was no problem as you can get a good run at it and use momentum. There were many more difficult dunes than big red, short steep dunes with a windy approach were the most difficult as it was hard to maintain suficient momentum. We had to back down a few of those and try again. I feel using momentum is a better option than very slow speed with the risk of wheel spin. As soon as your wheels are spinning you go know where and damage the track for others. Cheers RobCairns Offroad Training & Tours
FollowupID: 303232
Follow Up By: Member - Peter [SA] - Friday, Dec 19, 2003 at 21:24
Excuse me for butting in on this thread, but I assume the Eastern side of Big Red was no problem. The Western side was quite a challenge when I was there.
FollowupID: 303238
Reply By: Moose - Friday, Dec 19, 2003 at 15:12
On this site look under the Topic Search area (left hand side) then go to All Trek Fuel Data and scroll down to 6 cyl to get an idea on fuel useage. Doesn't say whether they towed. Use your Cape York trip as a guide and add a bit for sand driving.
Another point - depends which way you plan to cross - W to E is much easier and which tracks you take. Those factors too will have a bearing on fuel consumption. However I can't imagine a diesel Patrol having a problem with range.
BTW - I know who's going to win the arguement as to what to take - have fun towing that trailer across the Simpson next July!
AnswerID: 40654
Reply By: Member - Peter- Friday, Dec 19, 2003 at 19:28
Hendo
I've towed a camper trailer across the simpson four times since the early 80's, we've crossed the simpson about 13 times in this period, every direction, all the tracks so am very familiar with the country.
Since then the tracks have on the hole become progressively rougher and on the whole conditions are harder now than when the exploration crews were still present in the desert.
It will vary from season to season and also with weather conditions and traffic volumes.
Keep the tyres down, keep the weight of fuel and water in the truck ie keep the trailer as light as possible, have a good quality off road coupling (no towballs, I use a pintle and ring), a tow hitch at the rear of the trailer, allow plenty of time so you don't have to rush, if the weather is hot try to travel early in the morning knocking off around midday as the sand becomes softer as it heats up and travel with a group if possible so that if you do have problems on a dune help is a snatch away. Believe me it is very hard work unhitching and skulldragging trailer in sand.
Again if it is hot be prepared to drive over dunes like the trailer isn't there (it will cop a hiding!)
Personally I'd reccomend against towing trailers across the simpson as NP suggest but if you are experienced give it a go.
AnswerID: 40678
Reply By: Jol - Sunday, Dec 21, 2003 at 19:40
G'Day,
Along with quite a few ppl I have towed a trailer wvery which way across the desertnI have an article at this address http://www.direct4wd.com.au/tours/trailers.htm
Cheers Jol Fleming
AnswerID: 40795
Reply By: Phil P - Wednesday, Dec 24, 2003 at 21:11
Hi Hendo,
Have you made a decision on wether you are takin the CT ?
I'm heading over the Simpson in Aug 2004, I still can't make my mind up !!
Phil P
AnswerID: 41063
Follow Up By: Hendo - Monday, Dec 29, 2003 at 07:15
At this stage the jury is still out, although I am swayed towards not taking the trailer - and I'd like to thank all the responses to my question, it has been very informative.
I tend to err on the side of caution, and for our first trip, I will probably not take the trailer. Reason for this is that you can have problems etc on any trip, both on and off the bitumen. When towing a trailer, the probability is increased that a problem will occur, and if it does it could be a bigger, more complicated problem.
In sum, I'll be a long way from anywhere if there is a problem!
So, I'll be taking out the rear seats, putting the load down low, and doing my first trip for many years without the trailer.
Hope that helps - what is your decision?
Hendo
FollowupID: 303764
