Towing Capacities
Submitted: Thursday, Dec 18, 2003 at 23:30
ThreadID: 9229 Views:1832 Replies:4 FollowUps:3
Gentlemen
To set the record straight on the sometimes irksome issue of towing capacities, I offer the following for your consideration. All obtained from the manufacturers specifications, rather than the waffling of armchair experts.
Cruiser .. Rated Capacity ... 3500 kg Towball weight ... N/A
Patrol ... Rated Capacity ... 3500 Kg reduced to a maximum of GVM (3000 kg) with a towball weight of 200 kg.
Defender ... Rated Capacity ... 3500 kg with a Towball weight of 250 kg
Thankyou ..... ;-}Fidei defensor
Rosco
Reply By: Willem - Thursday, Dec 18, 2003 at 23:58
Anything can tow anything if it can get it rolling.
But is the driver up to that capacity?????????
Hmmmmmm.........................
Willem
Always going somewhere
AnswerID: 40603
Reply By: Truckster (Vic) - Friday, Dec 19, 2003 at 00:41
Nissan chnged the GQ rating not so long ago. NFI what it was or is!
AnswerID: 40608
Reply By: Member -Bob & Lex (Sydney) - Friday, Dec 19, 2003 at 17:20
Ross GVM does not affect towing capasity as that comes under Gross Combined Mass( GCM ) so you only win by ball weight. :) :) :) Regards Bob
Where to next
AnswerID: 40663
Follow Up By: Member - Ross - Friday, Dec 19, 2003 at 19:31
As I said cobber ... only reproducing manufacturer's figures.
But on your other note, I always thought there was something a tad strange about my anatomy ... didn't know it was so obvious though.
Have a great ChrissyFidei defensor
Rosco
FollowupID: 303230
Reply By: Alex H - Friday, Dec 19, 2003 at 20:58
Bearing in mind most states have laws that over-rule (sorry, bad pun) the manufacturers stated towing capacities. from memory, in WA it says that the weight of the trailer must not be more than 1.5 times the tare of the towing vehicle.
Incidentally, preTD5 Defenders have a rated capacity of 4000kg
Alex.
AnswerID: 40685
Follow Up By: howesy - Friday, Dec 19, 2003 at 22:26
Spot on. Manufacturers towing capacities make good fiction novels because it's what can be legally towed in your state that matters.
FollowupID: 303243
Follow Up By: Member - Ross - Saturday, Dec 20, 2003 at 16:21
Quite correct, but the allowable tow ball load was somewhat less.Fidei defensor
Rosco
FollowupID: 303309
