Victorians - Bit of a Blitz
Submitted: Saturday, Dec 20, 2003 at 15:04
Truckster (Vic)
Ensure your tyres are completely covered by your guards or flares.
VIC pol targeting $150 AND 3 licence points.
Rear mudflaps max 300mm from ground and covering tyre width.
Reply By: Member - Eskimo - Saturday, Dec 20, 2003 at 16:40
since when were rear mudflaps put into the ADRs'?Wow! am I cute
If yer ain't fishing, Yer ain't livin
Richard
40733
Follow Up By: Truckster (Vic) - Saturday, Dec 20, 2003 at 21:17
I know to get a car engineered you have to have the rear flaps on and within the specs, mate failed his engineers cause of this...
I think its being anal myself, just after more $
303320
Reply By: Shaker - Saturday, Dec 20, 2003 at 19:57
Not sure about ADR's, but I am pretty sure they have always been a RWC item for tray bodied vehicles.
40738
Reply By: Member - Toonfish - Saturday, Dec 20, 2003 at 23:07
y the 3 demerit points what a scam!
does this apply to all unrwc cars too?
welcome to the tax state1999 NISSAN NAVARA DUALCAB
DIESEL 3.2 & SPRINGY CARLTON TOY
2 awestruck kids (dads driving!)
40751
Reply By: Coops (Pilbara) - Sunday, Dec 21, 2003 at 09:18
Demerit points for this - Come on !
I don't mind fines but demerits hurt real bad.
Let's get serious with these guys.
What about a national protest or will apathy rule yet again ?
40759
Follow Up By: Truckster (Vic) - Sunday, Dec 21, 2003 at 20:45
Apathy will win again.
Mass protests achieve nothing these days, there are that many of them, that they are ignored.
303351
Reply By: lindsay - Sunday, Dec 21, 2003 at 09:28
A.D.R. 42/03 clause 15.2 to 15.2.6 refers to the wheel gaurds.
15.2.5 says Notwithstanding the requirements specified above the wheelgaurd including the mudflap (if fitted) need not be less than 230 mm from the ground for other than off road vehicles, or 300 mm in the case of off road vehicles designed for off road operation.
Did you also know that if you hot wire your cigarette lighter it then fails to comply with the A.R.D. As it says that they must only operate when the engine switch is on accessory or the engine on position.
The A.D.R. s make interesting reading.
40760
Follow Up By: Mad Dog Morgan (Vic) - Sunday, Dec 21, 2003 at 10:08
>Did you also know that if you hot wire your cigarette lighter it then fails to comply with the A.R.D. As it says that they must only operate when the engine switch is on accessory or the engine on position..
That's fair enough but if the lighter part is not in the socket then it's not a lighter, is it. I've added two so called lighter sockets with permanent 12 volts but they are only used for powering equipment, not lighting fags.I may be mad but I'm not crazy
Hooroo
Ray
303332
Reply By: Member - Eskimo - Sunday, Dec 21, 2003 at 12:27
Reply By: Steve L - Monday, Dec 22, 2003 at 08:31
I know you're all getting a bit stroppy about demerit points for the mudguards, but - hey, if you're legal and your tyres are covered you're not in any trouble. If your tyres aren't covered then maybe the extra points will convince you to abide by the law/rules. (Everyone else has to). ;-)
And yeah - only in Victoria! The Tax State!
40824
Follow Up By: Truckster (Vic) - Monday, Dec 22, 2003 at 21:19
So the fact that I think they are in the flairs, and the cop says they are 1mm outside the BIGGEST flairs you can get..
what do you do then?
303411
Follow Up By: Steve L - Tuesday, Dec 23, 2003 at 07:49
As Jarrod states in your other thread on this:
"Tyres and
wheels are to be covered to the outer edge, and from above the axle. That means hanging a piece of string from the edge of the guard, it will not hit the tyre or wheel all the way to the axle"
If the string doesn't touch then you're right - if it does then the police are right and you need narrower tyres or bigger flares (if you can find or make them).
Simple. Although they often seem to be simply money making, rules are rules....
303473
Follow Up By: Bonz (Vic) - Tuesday, Dec 23, 2003 at 16:39
Just run a 2mm bead of silicon around your flare, that should take care of the 1mm overhang and give you 1000 micrometres of safety marginLaterally Literal
Seriously Cerebral
303523
Reply By: Andrew - Monday, Dec 22, 2003 at 17:06
Is It only me who hates having stones and garbage thrown at me by clowns driving around with the
wheels hanging out of the guards or driving on jacked up suspensions without fitting mudflaps. I don't care if they destroy their own bodywork but I like
mine the way it is.
If it takes the threat of 3 points to make them fix it, that fine (sic) by me.
regards
A
40859
Follow Up By: Mad Dog Morgan (Vic) - Monday, Dec 22, 2003 at 19:58
I never have anything thrown up at me but I do tend to leave a lot of comfort space in front of me. Only one broken windscreen in 30 yrs driving but yeah not nice being plastered with rubbish and other junk.I may be mad but I'm not crazy
Hooroo
Ray
303402
