90 Ltr water tank
Submitted: Monday, Dec 22, 2003 at 20:42
ThreadID: 9284 Views:2287 Replies:8 FollowUps:6
Hello All,
My newly purchased GQ has a water tank fixed under the drivers side of vehicle. It seems to be a great addition for many reasons. My concern is, I spoke to the previous owners asking if they used any additives to keep the water drinkable . Their reply was NO. They told me they have never put anything except water in it from day 1.
I have sampled the water in the tank and it seems ok ( well I'm still alive) But I am wondering if there is anything that should be added to keep the water clean and pure. Its a checker plate constructed tank...Any feed back would be great.I love it when you talk DIRTY !
Reply By: Member - Ross - Monday, Dec 22, 2003 at 21:02
Does it have a drain plug ??
In any event you could wack in 100ml of pool chlorine or similar (White King or any laundry bleach) + a full tank and leave for a few days ... that'll kill any bugs for sure. Don't drink it though ... empty tank and flush thoroughly.
Fidei defensor
Rosco
AnswerID: 40889
Follow Up By: cokeaddict - Monday, Dec 22, 2003 at 21:10
Hi Ross,
Yes it has a drain plug mate.
Ok I will try that, but my concern is....the tank has the dividers built in, I am assuming they are an absorbing material. to stop the water from splashing around and unbalancing the car in tight situations. I am concerned that the chlorine will attach itself to the dividers. Maybe it might needa few flushes instead of 1..what do you think Mate?I love it when you talk DIRTY !
FollowupID: 303409
Follow Up By: Member - Ross - Monday, Dec 22, 2003 at 23:38
Cobber
I reckon the baffles are most likely aluminium also. That would be the most likely scenario when it was fabricated. Would be the easiest way to build it when you think about it.
Diluted chlorine shouldn't be a problem, but maybe you'd be safer getting a pack of water purifying tabs from the camping shop. You can get them for larger volumes. But I'd still give it a good flush cause the water tastes like crap .... well I think it does ... not that I'm an expert on that sort of thing. Most tabs are chlorine based anyway .. the other answer is just a cheaper solution.
Drop the plug on a slope and give it a good flush and I reckon you'll be as right as rain.
Fidei defensor
Rosco
FollowupID: 303463
Reply By: Member - Raymond - Monday, Dec 22, 2003 at 21:37
Hi Cokeaddict
I have an 80 lt stainless steel under the GU. The baffles are also stainless and how they work is they have hole in the bottom and top of each baffle to let the water through but slowly to stop the sloshing. I drain it every few months and just refill with Melbourne water. Not problems
Raywanderin' in retirement. victor 2010
AnswerID: 40898
Follow Up By: cokeaddict - Monday, Dec 22, 2003 at 21:43
Hello Raymond,
Thats the word i was looking for.."sloshing" Thanks for the advice Ray.
I feel better now knowing i dont need a degree in science just to drink water from it.
Merry Xmas to you and your family mate AngeloI love it when you talk DIRTY !
FollowupID: 303414
Reply By: Willem - Monday, Dec 22, 2003 at 21:39
I wouldn't worry about it mate. Don't put anything in the tank except water. But don't fill from a plastic/rubber garden hose as you may get a tainted rubber taste. If in doubt boil the water before drinking. But as you say, you have tasted the water and you are still alive and not running to the toot every 5 minutes...so there shouldn't be a problem. Just drain the tank regularly.
Cheers,Willem
Always going somewhere
AnswerID: 40899
Follow Up By: cokeaddict - Monday, Dec 22, 2003 at 21:47
Thanks Willem,
Nice to know we have all the experts right here. Will do just that mate.
Safe driving whereever you go. AngeloI love it when you talk DIRTY !
FollowupID: 303416
Reply By: Member - Nigel (QLD) - Monday, Dec 22, 2003 at 21:47
you could use a few Milton steralising tablets (in the baby section at the supermarket). These tablets kill all the bugs and can be used as a water treatment for drinking water, so safe enough without excessive flushing.
AnswerID: 40904
Reply By: Desertfox - Monday, Dec 22, 2003 at 22:08
Hi Cokaaddict
There are several issues about safe drinking water. As long as you fill up chlorinated tap water it will stay fresh for at least a few days if nort weeks. If the water is not treated it might be unsafe to start but even if it is safe it will go off within a few days (specially in hot weather) A organic slime can build up in your tank. If you are lucky it will small and taste bad and you would find out. But it could also be that you just get sick of it and this is no fun at all in very unplaesant if it happens in the middle of nowhere.
There are products on the market based on silver ions. This products get rid of any bugs and conserve the water for up to six months. The best of it is that it doesn't taste and it is said that silver ions help yur digesting system as well.
Here the link to the product I always used on my trips to the Sahara where good drinking water is just not available at all (not even in cities I would dare to drink it of the tap !!)
http://www.katadyn.com/site/int/home/outdoor_products/micropur/
If you don't mind the chlorine taste this is even a cheaper way to go.
In Australia it might not be a big problem since tap water is safe and mostly treated. But if I go bush I would not like to get sick because dunnies are far apart.
Ulrich
AnswerID: 40906
Follow Up By: Member - Pluto - Tuesday, Dec 23, 2003 at 08:10
Hi Cokaddict & Ulrich
Although I don't know about the tablets you mention, Katadyn Filters have been available over the counter in Australia for many years. Two Outlets I know of are Bushcraft in Wollongong and Main Peak in Perth. That means they should be widely available in between.
Although I have never carried these I have had a couple of trips where I wished I had.
Best of luck with keeping your tank happy and healthy.
PlutoGet out there & have Fun!!!
FollowupID: 303477
Reply By: Member - Bob - Monday, Dec 22, 2003 at 22:28
If you put clean water in there will be no dramas. When I say clean I mean no cryptosporodium, giardia or blastocystis. Because clean water has no nutrients in it nothing will grow. Because there is no light no algae etc will survive. The most toxic thing you are likely to ingest is the chlorine in the bleach! Don't add anything. Just drink it (Freddy). The water in our tanks is cleaner than any treated water you may find. And that includes the leaves, bird bleep etc that land on the roof.Bob
AnswerID: 40909
Follow Up By: Member - Bob - Monday, Dec 22, 2003 at 22:30
Mind you, our avian friends with diarrhoea are encouraged to 'sorf'.Bob
FollowupID: 303454
Reply By: Member - DOZER- Tuesday, Dec 23, 2003 at 08:18
With my caravan tank, i put a little bicarb soda with a tank full of water and leave it for a day or so b4 draining, flushing, and then refilling with drinking water.
Works for me.
If you are still worried, there is some water purifying products with silver in them you can use in the tank aswell.
Andrewwheredayathinkwer mike?
AnswerID: 40942
Reply By: cokeaddict - Tuesday, Dec 23, 2003 at 10:02
Thankyou to every one for your feedback. I have taken all into consideration and i now feel much better knowing that my water is safe to drink. Besides..if i die from drinking it....i have you all to thank..... :-)
Hope you all have a great Xmas
Hoping that the new year brings good furtune to you all...yes even you Toyota boys.....oh what the heck...its Christmas.
Cheers Angelo I love it when you talk DIRTY !
AnswerID: 40948
