Roaming ISPs???
Submitted: Tuesday, Dec 23, 2003 at 11:08
Member - Jack
Hello all ...
I am preparing to take a lengthy trip (as far around Oz as possible) and should be on the road for close to 9 months. I am wondering if anyone has any ideas/suggestions regarding ISPs for such a trip. I have an Internet Ready Toshiba laptop, mobile phone, and a Sat phone with the necessary "add ons" to enable me to receive and send email.
All I need is an ISP to whom I can dial up from remote locations without having my trip ended due to excesslive phone costs because I am up north and the ISP is somewhere down south.
Thanks in advance . and merry Christmas and safe travelling to all.
JackNo trees were harmed in the making or sending of this message.
However a great number of electrons were terribly inconvenienced.
Reply By: RussellV - Tuesday, Dec 23, 2003 at 11:26
I think from memory Telstra can give you a national number for dial up accounts ie. a single number that works throughout Australia. From there you just hook into your normal bigpond account. Be worthwhile giving them a call in any case. There is another piece of software called GRIC which is intended for global roaming and it will identify and pick the nearest ISP to whatever city you are in around the world. I'm not sure that it works locally in Australia though.
40955
Follow Up By: Penguin - Tuesday, Dec 23, 2003 at 11:32
Russell's right. Bigpong uses the same access number across Australia - (0198)308-888. Beware though, some hotels etc may treat it as a mobile call because of the 019 prefix. IT'S NOT!! It's a local call cost from anywhere in Australia.
303490
Follow Up By: Member - DickyBeach - Tuesday, Dec 23, 2003 at 11:39
Jack,
I note you wanted a number to use with a mobile and David's offered one.
In my odyssey this winter I used 0198 30 30 30 from hotel rooms and, as per Russell's comments above, was charged by hotels only as a local call.
Have a great trip!
Db
303491
Follow Up By: ROLANDE - Wednesday, Dec 24, 2003 at 01:49
jack,
Just for comparison, IPRIMUS have an australia wide number as
well, 0198380000 and have had less trouble than bigpond lately
Rolande
303579
Reply By: ExplorOz Team - David - Tuesday, Dec 23, 2003 at 11:28
Are you with Telstra?
If you are they have a number that you can ring from your mobile (only) and it will connect you directly to the Internet. This is the service that I use when we travel. There is no addtional fess (other than what they charge for the call). You can use the number 24hours a day however as usual cheaper after 7PM etc etc.
If you want to have a go the number you can use from your mobile is - 0418707638 - no user id or password is required so on your dialup settings just make the call the system will
logon without user and password (It can do this because it is billing you for the call to the number from your Telstra mobile).
The call rates are OK however as the calls are from mobile the data rates are not fantastic but it works and it does not require any additional setup.Regards
Always working, not enough travelling ;-)
40956
Follow Up By: ExplorOz Team - David - Tuesday, Dec 23, 2003 at 11:29
Oh and I mean is your mobile with Telstra not your ISP service! The ISP service is irrevelant using this service.Regards
303489
Follow Up By: Member - Jack - Tuesday, Dec 23, 2003 at 15:19
Hi David:
My mobile is not (yet) with Telstra, and my Internet connection is ADSL. I will probably need to get a dial up connection, which is not a problem.
Many thanks .. these responses are exactly what I was after.
303515
Reply By: Peter - Tuesday, Dec 23, 2003 at 12:56
Another thing to think of is GSM connection is 9600 BPS and CDMA 14.4k
With Telstra Mobile Internet, you choose when and where to browse the web.
All you need is a data-enabled mobile phone linked to a PC or PDA (Personal Digital Assistant). When you're in the areas covered by Telstra's mobile network you can jump online anytime
Telstra Mobile Internet Accelerator assists with faster web surfing at no extra cost. And it doesn't require any special software. The Accelerator reduces download times by compressing web pages - including heavy graphics and animations - before they are sent to the Mobile Internet server. The text is delivered first, so you can start reading and move on quickly if it's not what you were after - without waiting for the graphics to download.
By activating the Accelerator, web pages will appear up to three times†* faster than they would without it.
Calls to and from 0418 707 638/639 from GSM or #777 from CDMA are charged at 22c Flagfall then 16.5c per 30 seconds 7am-7pm, Mon-Fri and 8.25c per 30 seconds all other times, charged per second.
Calls to and from GPRS are charged at 22c Session Fee; plus 2.2c per kilobyte (or part thereof). There are also a variety of GPRS monthly packs to suit your requirements
Have A look
http://www.telstra.com.au/mobile/products/wireless/mobileinternet.htm#accelerator for more info
You could also see if an audio coupler would suit and dial from standard phones.
40960
Follow Up By: KiwiAngler - Tuesday, Dec 23, 2003 at 15:34
How do you get 14.4k. I use Telstra CDMA and only get 115.2kbs? Any help appreciated
303516
Follow Up By: KiwiAngler - Tuesday, Dec 23, 2003 at 15:36
ooops 115.2bps :-)
303517
Follow Up By: Peter - Friday, Jan 02, 2004 at 11:50
Try by making a data call instead of a normal telephone call
304057
Reply By: Viola - Tuesday, Dec 23, 2003 at 20:12
Darling you can get a two way satellite internet connection with Bigpond and it beats the hell out of dialup
I had a small problem with it at first but as soon as I bought a full sine wave inverter ducky all my problems dissapeared like my wrinkles with vanishing cream
40991
Follow Up By: Member - Jack - Wednesday, Dec 24, 2003 at 13:42
Sounds almost too good to be true ....
I would need to buy my vanishing cream in bulk ...thanks for the info though. This sounds like an option worth exploring.
Jack
303601
Reply By: Member - Timothy - Wednesday, Dec 24, 2003 at 08:27
Quite a few of the smaller ISPs provide nationwide numbers.
I've been with our local startup Penrith Netcom www.pnc.com.au
since they were just 2 guys in a shed. They are now quite a big operation
and provide a 0198 number which is a local call from anywhere.
The first few times I used it in hotels and motels
I would just log in for a few minutes
and then check with the desk how much I owed.
It's always been a local call, so now happily surf for hours if needed.
not sure how it goes via a mobile phone though
something I have never tried
timothyDefender Extreme
41018
Reply By: bluehealer - Wednesday, Dec 24, 2003 at 16:30
look at pocketmail.com.au keyboard like gadjet that you hold up to the phone to recieve and send emails quickly ,
41054
