Squeaky Hi lux
Submitted: Wednesday, Dec 24, 2003 at 22:23
Brett
My 2002 3 ltr Turbo has a loud squeak coming from the Right hand front hub. The noise dissapears when I disengage the free wheeling hub. Should I be immediately concerned. I will book the car into Toyota on the 5th Jan.
Brett
Reply By: howesy - Wednesday, Dec 24, 2003 at 22:35
Yes it is a matter of concern.
No don't do it. take it anywhere except toyota. unless of course you have money to burn.
41070
Follow Up By: chrisfrd - Monday, Dec 29, 2003 at 12:08
Why not? It should be under the new car warranty!
303769
Reply By: KG - Thursday, Dec 25, 2003 at 22:41
might be a reindeer jammed up in the guard?
41095
Reply By: GrantM - Friday, Dec 26, 2003 at 10:53
Brett,
Had exactly the same problem with my 2002 petrol Hilux. Turned out that a spring had dislodged in the hub and was causing the squeak. Toyota fixed it in the following service, no parts needed.
Hope that helps.
41113
Follow Up By: Brett - Friday, Dec 26, 2003 at 23:11
Thanks Grant, I will suggest that to the Service guy. I can detect no other fault with the vehicle and it drives just the same so I hope all will be OK even though it is a company vehicle.
Brett
303697
