Non Crushable Radiator Hoses
Submitted: Saturday, Dec 27, 2003 at 14:43
ThreadID: 9343 Views:2620 Replies:6 FollowUps:2
G'Day All,
Wondering if any knows of a place, pref in Melbourne/Victoria, where I can get non crushable (wire insert) for a 75 series 1996-97 1HZ 4.2 diesel Troopy.
I would prefer to buy new hoses from some where, but any information that anyone has for either maiking my own or another way I can over come the problem, please let me know.
Happy Treking.
Jim
Reply By: donk - Saturday, Dec 27, 2003 at 14:57
What is the problem that you are trying to fix ?????????
Why do you want radiator hoses with extra reinforcing ?????????
Regards Don
AnswerID: 41159
Follow Up By: howesy - Saturday, Dec 27, 2003 at 19:55
Especially the long hoses can if soft , old or under heavy load (high revs and heat) can suck in and restrict water flow. This is usually only a problem on the bottom hose which gets high suction from the water pump. It is always something to check when you have tried everything and still cant solve the overheating. Get the revs up over 3000 and check that it dont gradually suck in.
FollowupID: 303725
Reply By: Member - Hugh (WA) - Saturday, Dec 27, 2003 at 19:54
Hi Jim,
The wire insert should be available ex auto shops like Repco, SuperCheap, etc. They may even have the exact hose you need (with reinforcing) for the suction hose. You can get reinforced hose in various lengths that is flexible which may work for you. If you do it yourself with std hose, the reinforcing wire only needs to go on the suction side (inlet to water pump) to stop it collapsing.
Have you tried a Toyota dealer?
Hugh
AnswerID: 41175
Reply By: howesy - Saturday, Dec 27, 2003 at 20:01
one of the problems associated with reinforced hoses is that the wire disintegrates over time from corrosion and can be a bother. see if you can find any with stainless steel inserts, you may pay more but you get what you pay for. good luck though stainless versions aren't the common go.
AnswerID: 41176
Reply By: trampanto - Saturday, Dec 27, 2003 at 21:12
G'Day All,
Yes the problem is hoses which are "collapsing". I've tried fitting new standard hoses, but the same problem occurs. I've also tried my local auto shops, all say they can not get the reinforced hoses.
I would prefer the stainless steel hoses, but will that cause any problems with the turbo system which is alloy?
Thanks Again
Jim
AnswerID: 41179
Follow Up By: Truckster (Vic) - Saturday, Dec 27, 2003 at 23:13
If your NEW stock hoses are sucking in, I would suggest you have other issues...
There are 1000's of 1HZ troopies on the road with stock hoses..
Stainless Steel, you talking Braided??
FollowupID: 303731
Reply By: Wil - Sunday, Dec 28, 2003 at 12:31
Hi Guys
Remembered reading the Overlander magazine about last year's Melbourne 4x4 show where you can buy a length of Hose with a coil inside & out for shaping to make your own hoses.
Guess you could contact them about it. Good luck
Wil
AnswerID: 41191
Reply By: Cumbo - Sunday, Dec 28, 2003 at 22:43
trampanto
I work one or two days a week with my next door neighbour mate who owns a radiator shop, "Charmhaven Radiators", sorry had to get the plug in.
The problem is not your hoses but the radiotor, or especially the build up in it.
In the top tank of the radiotor all the gunk within your cooling system builds up, especially if it has not been serviced. By build up I mean if you look at the top section of the radiotor the top tank is the section before the tubes star. In some radiotros half of the top tank can be a solid mass. This clogs the core and you may only have 50-75% of your flow through the radiotor
A flush of the radiotor in your case may not be good enough. Ive done a few in the last few weeks that had up to half of the tubes blocked. Start with a rod out. With these the bottom tank is removed and each tube of the core is rodded and cleared.
Like my mates opinion there should be no suction. The flow should be unobstructed through the core. The reduction in the hose is because the flow is obstructed. The pump is trying to drag more water than it is being given If you have a rod and flush and then have it flushed every twelve months you should have no problems, in fact he extends the warranty on cooling systems and radiotors if this is followed. Drop me a line if you need more info. A rod out and flush should cost about $80-00
CumboTD42
EFS
TX4400
Safari Snorkel
Rola Racks
Milford Barrier
Engel 39l
AnswerID: 41222
