cav fuel filter adapter
Submitted: Monday, Dec 29, 2003 at 18:22
ThreadID: 9366 Views:3686 Replies:4 FollowUps:6
im going to replace my fuel filters on my troopy 1998 model (4.2 diesel). is it worth fitting cav fuel filters and if so does anyone know where i can pick up the adaptors in brisbane . regards and happy new year
Glenno.
Reply By: Member - Karl - Monday, Dec 29, 2003 at 19:37
Mate, it deffently worth it. Replacement cartridges costs approx $8 compared to Toyota Original filters. Unfortunately I don't know where you get them in Brissy. You could try a mail order.
KarlEveryone is entitled to have an opinion - just make sure that yours is correct.
AnswerID: 41258
Reply By: chrisfrd - Monday, Dec 29, 2003 at 20:19
YUP!
Most Enzed hose shops have them.
Otherwise you can deal with 4WD systems. I'd go to Enzed first.
AnswerID: 41259
Follow Up By: glenno - Tuesday, Dec 30, 2003 at 10:00
thanks guys i will try enzed
FollowupID: 303829
Reply By: Member - Ken - Monday, Dec 29, 2003 at 22:38
Glenno
What exactly do you mean by 'adaptors'.
Ken Robinson
AnswerID: 41270
Follow Up By: chrisfrd - Tuesday, Dec 30, 2003 at 10:45
Ken,
Instead of using the standard Tojo/Nisso filter, you can purchase a Bosch/LUCAS (same company!) CAV filter, as used by CAT and most earth moving machinery to filter fuel. These filters are spin-on to your standard primer pump/filter base, by use of an adapter.
When fitted, you can see the fuel and water droplets (if any) and keep a check on the filter. Typically, you can replace filters every few months to keep dirt and other bleep that you pick up from the servo's tanks.
A replacement filter is a steal at $8-11 and they are more environmentally friendly as you aren't throwing a large steel can away, that can't be recycled as it is soaked in diesel and can't go into the council's recycling programs.
These filters aren't fiddly either. My Patrol 3.0 filter is exactly the same as the 2.8 and 4.2 in the GQ. You need to remove the whole assembly from the truck, by unbolting the primer/filter assembly, then remove the hoses (supply and feed sides) then use a vice to hold the assemby, whilst twisting the bleep out of the whole thing to get the filter off. No matter how good you are, you will be covered in fuel. It takes me about 30 minutes to change a Nissan filter, or 2 minutes to change a Bosch unit.
Also, the Nissan filters are $34.00 each, compared to the box of 10 CAV filters that I purchased two months ago for $45.00 ($4.50 per filter!)
Don't worry about flow and contamination screening properties either. They filter down to about 10u (Nissan states that their filters do about 10-12u) and have a flow of around 80LpH, which is much better than the Nissan unit.
FollowupID: 303833
Follow Up By: Member - Ken - Tuesday, Dec 30, 2003 at 15:47
Chris
Thanks for the info Chris, however when I asked about the 'adaptors' I didn't give you my full situation. (sorry about that)
I have a troopy and now have a set of CAV filters that came with the top 'Housing/filter body' or whatever you call it/them.
Now I am figuring out how to to mount them where the factory fitted originals were.
From this post I am guessing there is some sort of adaptor thing that goes between the factory fitted original housing/mount and the CAV filter.
Am I correct in making this assumption.
regards
Ken Robinson
FollowupID: 303870
Follow Up By: chrisfrd - Wednesday, Dec 31, 2003 at 10:36
Exactly correct.
You need the adapter plate for the Tojo filter/primer unit. It will not just spin on, as you would have found.
You can replace the whole assemby with a Bosch unit, but that's expensive.. I think I got my adapter from Enzed too.
FollowupID: 303956
Follow Up By: Coops (Pilbara) - Thursday, Jan 01, 2004 at 04:31
chrisfrd
Who did ya go to to get the bulk buy discount please?
FollowupID: 304004
Reply By: Coops (Pilbara) - Thursday, Jan 01, 2004 at 04:30
Don Kyatt stores sell em as do 4WD Systems
AnswerID: 41461
Follow Up By: glenno - Saturday, Jan 03, 2004 at 15:20
thankyou i will try don kyatt in brisbane regards glenno
FollowupID: 304117
