AnswerID: 41787 Submitted: Monday, Jan 05, 2004 at 07:57
HJ60
replied:
I've had trouble with my tacho on the diesel. It's located on the passenger side towards the top on the bellhousing above the flywheel teeth. it's bit of a pain to access.
The gearbox was removed before i aquired the vehicle and the wiring wasn't replaced in the correct position. it may be damaged.
I found i could access the wiring by removing the coverplates above the gearbox.
The tacho only comes on mostly when it rains.
Reply 1 of 4
