Subaru Outback off-road capabilities?
Submitted: Monday, Aug 27, 2012 at 15:04
Pengoc
I have a chance to get a Subaru Outback for a good price, I think it is around a 2000 model year. However the front and rear overhang worries me when going over something a little steep.
I don't do much off road driving and certainly cant justify a proper 4WD. The times I do go out wont be to serious 4WD tracks either, just those suitable for AWD vehicles.
More specifically in the near future I want to go out to
Lake Torrens on the
Merna Mora station track. I went last year in a Ford Explorer which handled it with ease.
I have included a screen grab from some video we took on the track coming out of a creek bed. Is it likely the Subaru would get over something like this? It doesn't look like much in the video I must admit.
Reply By: Top End Az - Monday, Aug 27, 2012 at 16:17
Hi Pengoc
I don't have a Subie, but have spent my younger years in them and ground clearance was always the main issue in terms of the car bellying out in soft sandy tracks, not so much the overhangs.
I had a 2004 RAV 4 which was an AWD and would face similar issues to the Outback, being a soft roader. Ground clearance was limited but it never really stopped us from going where we wanted to keeping in mind we never tried to do the Cape, a desert crossing or the GRR in it, just drive to the cars capabilities. but we certainly got into many spots where you couldn't get a Camry into.
The main thing is to take it a bit easier than you would in a large 4WD wagon, and fit a decent A/T tyre with a good tread pattern as this will help traction no end and add some
puncture resistance. My towbar stopped any potential damage on the rear overhang.
Living in the Top End, it never ceases to amaze me where I see X-
Trails, RAV 4's, Kia Sportages as many people just don't have the means to buy an expensive 4WD. Driving a bit slower offroad, careful wheel placement and some good judgement will get you into many
places you wouldn't have otherwise thought.
Hope some of this helps.
493719
Reply By: Member - Scott M (NSW) - Monday, Aug 27, 2012 at 17:25
We had a group on a trip in May through the Corner, Innaminka,
Birdsville (via
Cordillo Downs) and down to Maree etc - 2 Tojo LC's, a Jackeroo and a Subie Outback.
As others said - main issues were ground clearance and fuel range... otherwise it went pretty
well. Bottomed out a few times on the C-D road and out to
the dig tree.....
Plastic sump guards etc etc. - it handled it mostly
well, however I wouldn't put much stock on pristine sumps and guards if you did this all the time ..... a little bit of beef in the
suspension would have helped a lot.
493728
Reply By: Pengoc - Monday, Aug 27, 2012 at 18:59
Thanks everyone for the useful replies.
My other thoughts were to get a Forester, which I have heard is a bit better off-road than the Outback. Although it is still limited in it's ground clearance.
The main reason for the Outback is I might have the chance to get one from my father at a price which I can afford. I've driven one too and they are fantastic on the road.
The Ford Escape we were driving in the photo had A/T tyres fitted which made a huge difference. I don't know what the ground clearance was like however.
I've sent an email to Merna Morna asking if they get Outbacks going through this track ever. That should be a big help determining if we get this vehicle.
It's amazing to see videos of what some people put these Outbacks through:
http://www.youtube.com/watch?v=QJLdVr4gjGo&feature=relmfu
493740
Reply By: Member - Des Lexic - Monday, Aug 27, 2012 at 21:13
Pen, We have a 2000 Subie and the approach and departure angles are a problem.Our front under bumper has a bit of a crack where we tried to climb a
sand dune that didn't look all that steep. It is absolutely terrific on dirt roads and handles them really
I've heard of them doing the Simpson but with lift kits and larger tyres. The lower profile tyres keeps them a little too low.
What are you expecting to pay for it as our daughter is eying off ours at the moment. LOL
They are a great car and although we have only done 100k in it, only has needed tyres battery and fuel.
Des
493751
Reply By: Member - PJR (NSW) - Monday, Aug 27, 2012 at 21:41
Last year on our way through
Birdsville on the way to the Gulf we stuck our nose into the Simpson as far as Big Red. The normal road was closed and there was a detour down a very sandy track to the border and then back up to Big Red after the
lake was passed.
We were following a Subaru Outback. He was having a devil of a time with clearance. The sand was a bother but the clearance in the middle of the track between the wheel ruts was a real problem. We saw the rear doing an excellent grading job. He gave up about half way to Big Red where there was an easy area to turn around in. On our way back we found a couple of plastic panels that he could have dropped. There were no other cars seen that evening.
I read above where they could be raised but I would make sure the CV joints aren't overworked as can happen with the 100 series IFS models can if you do not drop the diff with the right kit.
These are two thing I would consider. I do not know if I would take it to some
places we go in the High Country. But then again we are looking at it in a different light. We have a Toyo 100 GLX with the 4.2 TD engine and it is set up as a self sufficient tourer capable of just about anything we could come across as solo travellers.
If you need clearance then
check on the lifting issue as it is quite bad. The review I just read was not glowing but it did say "Better to drive than an SUV, and able give a decent account of itself when it’s slippy and a bit bumpy. Nice engines, great chassis and lots of kit for the money." I do not think that "it’s slippy and a bit bumpy" says it will go to a lot of off road
places.
493755
