12 volt Air Compressor's
Submitted: Thursday, Apr 18, 2002 at 00:00
Robert
Has anyone used the cheaper 12 volt air compressor's priced at around $100 to $150 such as Truck Air or 4x4 Bushranger. The other brands such as Big Red and ARB units etc. are way over priced for what's in them and as I would only be using it for the occasional use I would consider one of the cheaper units provided they can actually pump up a 31" x 10.5" x 15" tyre and are reliable. I would interested in hearing comments from anyone who actually has used one of these units in regard to pumping up a totally flat tyre or re inflating low air pressures.
Reply By: Grinner - Thursday, Apr 18, 2002 at 00:00
Robert, check the May issue of 4x4 Australia Magazine, they have done a comparison of Air Compressors. Saying that, I have the Truck Air compressor, and find it resonable for the price. As an indication of inflation speed, my mate has a single cylinder Blue Tongue, and he can inflate 5 tyres in about the same time I can inflate 3. Grinner.
2913
Follow Up By: Ray - Wednesday, Apr 24, 2002 at 00:00
Hi Grinner,
Do you have the details of the comparison, I subscribe to 4WD Monthly so would rather not buy the 4x4 if someone can give me a brief overview of which was determined to be the better 12v compressor.
1210
Reply By: Goran - Thursday, Apr 18, 2002 at 00:00
Hi,Rob
Bushranger unit(about$150) should do the job.It can pump the tyre from flat and reinflate after sand driving.However i would consider any such unit as emergency only.I agree with you about the prices of heavy duty units but i dont think we have a choice.Cheaper units are not very reliable and tend to
cook themselfs when most needed.
I run liquid CO2 bottle on my roof rack capable of inflating about 26 tyres(265 75 R16) from flat to 32psi at the 10 sec.per tyre.No 12V compressor can mach that
2914
Reply By: Mark - Thursday, Apr 18, 2002 at 00:00
Hey Robert, like Gunner said, check out the review in 4x4. There was a new Bushranger unit tested for $250 which appeared to do the job.
2926
Reply By: Ray - Thursday, Apr 18, 2002 at 00:00
Hi Robert
I have 4WD for years and use a Truck Air. It works very
well after a slight modification. Cut the cigarette lighter plus off and add a hela plug or connect it direct to battery, Increases the efficinecy by 25% at least. No problem blowing up the 4 tyres after sand driving and much cheaper. Have had the unit for 4 years with no problems
2927
Reply By: Grant Taylor - Thursday, Apr 18, 2002 at 00:00
G'day Robert, if my memory serves me, Truckair's have a plastic piston whereas the more expensive pumps have a metal piston. When asked to do too much the plastic pistons can over heat and warp. The metal ones do not. If you only use it ocassionally and don't pump up everyone elses tyres at the same time then you should be fine. They are slower, though.
2937
