Hi all,
I've done a bit of a search and spent some time understanding not only how the CDL works but the mechanism that operates it.
I read through virtually all the posts on this 10 page thread on IH8mud about a bloke with CDL problems. Although there was no resolution in the end.
http://
forum.ih8mud.com/80-series-tech/536038-80-series-auto-diff-lock-always-wtf-10.html
Firstly I'll explain the set up in my vehicle before going over the symptoms as its probably not your ordinary rig.
It's actually a '94 75 series fitted with an 80 series auto transmission. (I'm paraplegic and can't drive manual anymore.). It's the earlier model auto with kick down cable. I've also fitted a Detroit 'no slip' locker to the rear and a Detroit 'trutrak' LSD to the front.
I bought it with the auto trannie in it but did the diffs myself. I've also had the transmission fully rebuilt. The previous owner hooked up a toggle type switch to activate the CDL and an LED to indicate that it is engaged.
I've virtually rebuilt this vehicle from the ground up as we plan to travel the world with it in the not to distant future. If your interested in our built and travel plans here's a link to our blog.
Http://lostabound.wordpress.com
Ok so on the weekend we took it out for our first bit of 4wding and camping after 9 months of building it. We took it up a very steep, loose and long
hill climb.
On a few occasions when we had all four wheels spinning in 4L we began to hear a grinding type noise and also noticed the CDL light flickering.
The vehicle also seemed to struggle more for traction as this noise was occurring.
From what I understand the CDL actuator operates a set of gears that engage a shift fork which locks the centre diff out. When the shift fork is in position it activates the limiting switch illuminating the CDL light. This is what I gathered from flicking some tech publication about the CDL.
Can't get the
pic up but here's a link to what I read.
http://
forum.ih8mud.com/attachment.php?attachmentid=391707&stc=1&d=1264812570
So if the CDL actuator is intermittently operating while the vehicle is in drive and the wheels spinning I'm imagining that the shift fork will be slipping back and
forth trying to engage/disengage the CDL causing the grinding noise as the gears clash and the further loss of traction.
I'm hoping its an electrical problem maybe in the relays or wiring between the switch, relay or CDL actuator.
As I said before this has been converted from an 80 series so who knows how the previous owner had wired it all up.
I haven't had a chance yet to look at anything being Christmas and all but hoping to follow the wiring diagrams and
check all the electrics first.
I'm also a little worried because it will be hard to reproduce as it only occurred under heavy load with all four wheels struggling for traction.
Any suggestions would be much appreciated.
Thanks.
