Winch Alternatives
Submitted: Tuesday, Sep 02, 2014 at 20:20
Ken Rd
I have had multiple vehicles all with Warn
winches and never once have I used one in anger - Old Telegraph, High Country, Canning!! Have always concentrated on having the very best vehicle and tyres and not getting too stuck!
I am now thinking of a new Landcruiser 200 which will spend a little less time in the rough and more time on tarmac - do I need a winch mounted on a steel bar or is there a smart "portable" option other than hand operated? That is the question....
Warn certainly have portables but they are 40-50 kgs - maybe the answer but any other suggestions appreciated. One clear advantage of a portable is the ability to pull both ways....
Ideas????
Rob
Reply By: Member - KBAD - Tuesday, Sep 02, 2014 at 21:54
Rob i have had exactly the opposite worked on cattle stations a long time never had a vehicle fitted with a winch got stuck numerous times long lonely walks back once over a day and a half, other times stuck for a few days slowly extracting ourselves out, always wanted a winch. Finally bought one put it on the wagon used it the very next day, I know it might be years before i need it again, i will service it and look after it until then because the day you do need it, it makes all the drama worthwhile. Thought about having one that i can swap around even drew up plans for one but in the end stayed with the front mounted one, (plans were a tow hitch receiver mounted front and back winch on portable cradle with a tow ball tongue) not that you still can't get stuck even with a winch but it beats most other ways of getting unstuck. Have used a hand winch to pull a vehicle out, but in forty plus degree heat and ninety percent humidity, in the middle of the wet, not my favourite way of spending the day.
538537
Reply By: Mick O - Tuesday, Sep 02, 2014 at 22:16
Rob, my theory about a winch is always put yourself in a position that avoids you having to use the thing in the first place. In the five 4x4 vehicles I've owned in 34 years I've used my winch twice. Once to pull myself out of a bog...see below
Start digging boys!!!
Oh Shit!
It works
What you do when there isn't a tree around
and the other time to pull anpother EO member out (backwards) from a bog somehwere deep in the
Great Sandy Desert.
Heh Heh
Click me - Sorry Petey :-)
Better to have and not need than need and not have. Warne??,
check out this thread and don't spend a million.
Winches - When to support and when to walk
Cheers Mick
538538
Follow Up By: Crusier 91 - Thursday, Sep 04, 2014 at 09:25
I'm wondering whether a exhaust jack would of been easier for the above purpose?
I have a 12000 pound winch at the front of the 80 series, only ever used it to pull stumps out of the garden and 2 recoveries, a Triton from a slippery slope with the help of Max Trax and a 3 ton 100 series out of quick sand, having said that, I required 2 other 4wd's attached behind me to act as anchors.
I have every recovery item with the exception of a sand anchor, which is on the list.
I consider all my recovery gear as insurance and a more relaxing get away knowing I'm prepared.
Having said that, always travel with another vehicle if possible.
823107
Reply By: Robin Miller - Wednesday, Sep 03, 2014 at 08:12
Very hard to beat a winch , but if you don't go where they are needed or don't travel alone then I guess it doesn't matter as much.
But we do and I couldn't imagine travelling without one.
Already this year we have extracted a 200 series and our neighour abandoned his 200 and took the chopper
home from the Canning.
Nothing provides traction like a set of chains in HC so consider that.
(and Maxtrax for dessert)
Our winch installation on our GU was without a heavy steel bar and added 28kg only in nett weight.
Our winch can pull backwards , and the GU is lighter than a 200 series and can easily fit lockers.
Overall our GU 4800 can go further than a 200 series and with less weight winch is more effective on it - so a lot depends on how good your installation is.
538544
Follow Up By: Willy W - Wednesday, Sep 03, 2014 at 18:01
Robin, can you tell us about the circumstances around the fella taking a chopper out of the CSR and leaving his car behind?
823078
Follow Up By: Robin Miller - Wednesday, Sep 03, 2014 at 19:10
Fascinating story that was Willy , and all the circumstances surrounding us meeting our new neighbour.
Its thread 103923 and as the thread unfolds you will see how we got independant confirmation of the events.
He is a good neighbour now - just a litle enthusiastic at times !
823083
Follow Up By: River Swaggie - Thursday, Sep 04, 2014 at 12:03
Hi Micko
Always wanted to try the tyre thingy down at a beach recovery.. Might get there one day.. Lol
823120
Follow Up By: Member - Boobook - Thursday, Sep 04, 2014 at 12:13
Never let a chance go by hey Robin? Somehow only you can turn a "which winch" thread into "A 4800 petrol GU beats a diesel 200 in so many ways" discussion lol.
Go for it Robin. LOL.
823121
Follow Up By: Robin Miller - Thursday, Sep 04, 2014 at 18:31
Yea BooBook - I will be wishing I had a 200 series soon as we will be exploring in the Simpson and I'm getting nervous because the plan calls for fuel consumption of 30lt/100k or less - I have already started biting my finger nails as there will be no support cars with petrol.
If I don't make it can you tell them to bury me next to my Gu.
Hi Swaggie I think you follow up is in the wrong place.
823138
Follow Up By: Member - Boobook - Thursday, Sep 04, 2014 at 18:48
LOL you can always fire up the EPIRP.
Anyway, I have no doubt that your planning would be meticulous and you 'll have at least one Jerry left over at the end of the trip.
If you have to get towed that last 80km by a 200 don't forget the photos.
Have a good trip and get another jerry for fathers day.
823140
Reply By: Malcolm 02 - Wednesday, Sep 03, 2014 at 10:23
When Living on Groote Eylandt (1993 - 2004) my wife and I would prefer
camping by ourselves (less compromises required), so for safety I decided that I needed a winch. The 4WD I had then had a bull bar already fitted that wasn't winch compatible so I bought a Tirfor style winch with a pulley in case extra pulling power was required. Needed it 3 times in that period and found that it took 15 - 20 minutes to get out, use and pack up again, which I estimate would be about 5 - 10 minutes longer than a bar mounted winch recovery would have taken. To me the important part was to not bury the winch under your gear so you cant get at it easily.
I made up a box open at one end so I could open the rear door and slide out the winch, handle, rope and shackle, straps, etc. without disturbing the rest of the
camping gear. Those with draws wouldn't need to do that.
For those that ask me about wether they should have a winch my answer has always been that you may never need to use it in anger, but it will give you confidence to go
places that you would otherwise not because the risk of getting stuck is too high.
Hope my experience is of benefit to you.
Mal
538551
Reply By: FatGaz - Wednesday, Sep 03, 2014 at 14:25
I have seen portable or boat
winches advertised.
Would something like that do the job??
They usually come with a towball mount and should also be able to hook onto a front recovery point.
I have never used one, so would like someone with more knowledge give an opinion.
I think they are only 5000lb rated.
538565
Follow Up By: gbc - Wednesday, Sep 03, 2014 at 17:47
No. For a start boat
winches are rated differently to 4wd
winches. 5000lb is the weight of the boat which is floating then dragged up a small incline onto the trailer. Sneaky buggers eh.
Electric
winches are rated at best possible line pull for ten odd wraps - everything goes downhill from there.
Hand
winches used for rigging (tirfors etc)are rated at a measly 1.6 t., however that is dead lift with a safety factor. You can comfortably pick your car up with one. Not recommended with a boat winch.
823077
Follow Up By: Sigmund - Thursday, Sep 04, 2014 at 08:58
A portable winch can be a good option. Works at the rear as
well as the front and doesn't hang permanently right at the wagon's front. Doesn't take a bath on every
river crossing. Google winch cradle. BYO winch.
823106
Reply By: pop2jocem - Thursday, Sep 04, 2014 at 09:30
I think the principle of having what I have heard referred to as a "multi mount" style of winch whereby you can store the unit out of the elements and attach it front or rear as required is great in theory but presents some, maybe not insurmountable, problems. Mainly the weight that is needed to be lugged into place when needed. 30 or so kg for a reasonable capacity winch. A considerable weight saving if synthetic rope is used of course. Not that hard to do for two reasonably fit people and doable for one on a nice flat firm surface. Unfortunately we seldom get bogged on such a surface. Usually slippery uneven sand, mud or rocks.
If I could work out such a system I might be tempted to build one that doesn't see me wearing a back brace for whatever is left of my life.
Then there is the problem of what to attach the other end of the rope to. Never seen one of those ground anchors used in person but they also don't look like a particularly light weight bit of kit and a nice sturdy tree or
rock is not always available.
The good old "bury the spare wheel" option is possible a la Mick O but not always practical in some ground types.
Pop
538589
