KT Cables 200w vs 2 x Renogy 100w?
Submitted: Monday, Nov 29, 2021 at 04:38
ThreadID: 142922 Views:9069 Replies:8 FollowUps:16
Hey all,
Recent lurker, 1st time poster here :) .
I'm upgrading the solar on a camper I've just bought, and bought one of these 200w panels on special ($299 to $209), on a whim. 10yr warranty, oz company.
https://www.anacondastores.com/camping-hiking/power-cooling/solar/kt-cables-200-watt-solar-panel/BP90174214-black
I can't find any reviews or otherwise about them online. I'd buy at least 1 more, if they're quality. They look good on paper, but I'm too much of a noob to even know where to start in assessing them (and the solar setup parts haven't arrived to test yet).
Or - I could go for 2 of these, for less (and if better, return KT Cables):https://www.amazon.com/Renogy-Monocrystalline-Solar-Compact-Design/dp/B07GF5JY35/ref=pd_rhf_dp_s_pd_crcbs_1/132-8081882-4141957?pd_rd_w=ekSpj&pf_rd_p=31346ea4-6dbc-4ac4-b4f3-cbf5f8cab4b9&pf_rd_r=2QHGP2X7FFZEWD5MWCSF&pd_rd_r=3bff7e81-e56e-4655-8635-c0f4a3c7cf9d&pd_rd_wg=KiVtG&pd_rd_i=B09J34TQGJ&psc=1
Any ideas or insights?
Reply By: Member - McLaren3030 - Monday, Nov 29, 2021 at 07:46
Hi Morgus,
From the reviews I have read, Renogy have a good reputation, and are quite reasonably priced. Can’t say the same for the other brand.
There is a formular for calculating the wattage of a solar panel, I think it is 100 watts per square metre, but I could be wrong, someone will correct me.
AnswerID: 638722
Reply By: RMD - Monday, Nov 29, 2021 at 07:48
Morgs
Going on size alone I wouldn't expect any more than 160 watts, on a good day, out of that panel.
Macca's comment above is on the right track although the sun radiance is around 1000w /sq metre. and at about 17% efficiency a panel size of yours and a bit less for the actual cell area, means under 170watts in ideal conditions. UNLESS the panel is extremely high in efficiency and the latest tech etc etc, then it may be more than 17 or 18 % output.
AnswerID: 638723
Follow Up By: Morgs B - Monday, Nov 29, 2021 at 18:10
Thanks for this, so to be clear - given that most panels are about the same efficiency at ~18-19% efficiency, then isn't this is as good as it gets?
If so, isn't *any* panel going to be pretty much the same? I.e. any 200w rated is going to actually give ~175w?
FollowupID: 917394
Reply By: Bob Y. - Qld - Monday, Nov 29, 2021 at 08:55
Jorge,
I’d suggest you check out the large selection of panels at Springers Solar. They have a variety of sizes, both reasonable & more expensive larger units.
Springers Solar
AnswerID: 638726
Reply By: Member - Bigfish - Monday, Nov 29, 2021 at 16:51
I,ve got 2 x 200watt Renogy panels. Over decades I,ve had many different brands. I rate the Renogy right up there and using a Victron MPPT solar reg I often get 11+ amps out of a 200 watt Renogy. My mates have since bought them and they too are very happy.
AnswerID: 638728
Reply By: qldcamper - Monday, Nov 29, 2021 at 18:06
Much the same surface area but dont expect much more than 150 watts.
The advantage of the 2 by 100 watt panels is that you can run them in series with a decent MPPT regulator.
AnswerID: 638729
Follow Up By: Morgs B - Monday, Nov 29, 2021 at 18:08
You're saying the Renogy is much the same surface area as the KT Cables?
FollowupID: 917392
Follow Up By: qldcamper - Monday, Nov 29, 2021 at 18:10
Surface area wise yes, quality is hit and miss on all brands.
FollowupID: 917393
Follow Up By: Member - Bigfish - Monday, Nov 29, 2021 at 19:02
As I replied. I have 3 x 200watt Renogy panels and quite often get 11+ amps output with a Victron MPPT. Mates have them as well and we all swear by them for price and performance. Anaconda, supercheep, bcf, etc.etc. are normally overpriced cheap shite.
FollowupID: 917395
Follow Up By: Frank P (NSW) - Monday, Nov 29, 2021 at 22:36
11 amps each or 11 amps combined? I'd be expecting 11 amps each.
FollowupID: 917401
Follow Up By: Member - Bigfish - Tuesday, Nov 30, 2021 at 07:19
11+ amps EACH.
FollowupID: 917407
Follow Up By: Morgs B - Tuesday, Nov 30, 2021 at 21:13
Can you clarify (if this is what you meant) why running 2 x 100w panels in series might be better than a 200w panel?
FollowupID: 917417
Follow Up By: qldcamper - Wednesday, Dec 01, 2021 at 03:12
Starts to charge in lower light conditions and also less voltage drop in the cabling between the panels and reg, but you must have a MPPT reg that is rated for the higher input voltage such as a Victron 75/15.
FollowupID: 917422
Reply By: qldcamper - Monday, Nov 29, 2021 at 18:14
Ask to see the rating spec lable on the back of the panel, if there is no reference to output power steer clear.
AnswerID: 638730
Follow Up By: Morgs B - Monday, Nov 29, 2021 at 23:12
Yeah, noone said they were missing.
For good measure, from (and on back of panels): https://ktcables.com.au/2021/03/18/200w-monocrystalline-12v-solar-panel/
Technical Specifications:
Maximum Power (Pmax): 200Wp
Power Tolerance: +3%
Maximum Power Voltage (Vmp): 19.6V
Maximum Power Current (Imp): 10.20A
Rated Voltage: 12V
Open Circuit Voltage (Voc): 23.2V
Short Circuit Current (Isc): 11.27A
Operating Temperature: -40 °C to +85 ° C
Product Application: Class A
Maximum System Voltage: 1000V DC
Product Weight: 11.50Kg
Dimensions (mm): (L) x 670(W) x 35(D)
FollowupID: 917403
Reply By: Darklight - Monday, Nov 29, 2021 at 21:16
The specs on the Renogy are a bit more detailed, which gives a bit more confidence. But for me the primary choice would be if it's more convenient to mount one panel vs two.
Nominal power outputs are stated under Standard Test Conditions, which are 1000W/m2 of light, at a panel temperature of 25C. Reality is always a bit different, particularly the panel temperature so you need to derate the output to allow for this.
Typically a panel will run between 22C and 35C over the ambient temperature, and will lose 0.37% of power output per degree C the panel is above 25C. So expect between 8% and 13% power loss due to temperature.
This info is on the Renogy spec sheet, but not the other one.
AnswerID: 638732
Follow Up By: Morgs B - Monday, Nov 29, 2021 at 23:15
Right, that's good info, thanks.
FollowupID: 917404
Reply By: qldcamper - Thursday, Dec 02, 2021 at 08:33
Just seen an add for Renogy 200 watt panels for $189.00
Over all surface area a touch over 1 square metre.
So that means a cell efficiency of over 20% for less than $1 per watt.
Me thinks it is a good example of juggling figures.
AnswerID: 638752
Follow Up By: Member - Bigfish - Saturday, Dec 04, 2021 at 18:31
Does it really matter considering for under $200 you will have a genuine 10+ per panel?. Heaps of so called 200 watt panels out there that struggle to give 7 amps output.
FollowupID: 917526
Follow Up By: qldcamper - Sunday, Dec 05, 2021 at 08:30
Yes I would say it really matters.
It is false advertising and they seem to be getting away with it.
How do you engineer a system if you cant rely on the figures supplied by the supplier before purchase.
Would you be happy if you just forked out for a 6Kw system on your home and it couldnt produce 80% of the goods, or found you only 10 eggs in the dozen package.
FollowupID: 917527
Follow Up By: Member - Bigfish - Sunday, Dec 05, 2021 at 09:03
Very little advertising on any product is 100% accurate. Fuel usage, vehicle tow weights, electrical consumption on appliances, quality of a new home, contents of food packaging, many warranties etc.etc. Renogy advertised a 200 watt panel as putting out...Short Circuit Current (Isc): 9.66A
Optimum Operating Current (Imp): 8.85A
Isn't this the info the vast majority of us want? As I said, mine put out around 11 a/h in ideal conditions. Around 9-10a/h usually. I cannot see any false advertising and consider these panels good bang for your buck. Few of my mates have them and are also very happy. I,ve had cheaper and dearer panels but these are excellent value.
FollowupID: 917528
Follow Up By: qldcamper - Sunday, Dec 05, 2021 at 10:04
Sad world when everyone just accepts their bulshit.
Panels dont produce what they should, fridges draw a bit more than stated, batteries that dont quiet store their rated capacity.
To meet customers expectstions you have to double advertised capacities then it is too expensive.
People argue the price down then when it doesnt do what they want they take you to consumer courts.
These days I only install what the customer buys elswhere, cant be bothered dealing with people who gather their facts from misinformed forum experts.
Did one yesterday that that the junction box fell apart as soon as the box was opened and the owner chose to proceed with the installation even after I told him the supplier would not honour warranty if we patched it up. But the product was recomended by someone on a 4wd forum.
FollowupID: 917529
Follow Up By: Member - Bigfish - Sunday, Dec 05, 2021 at 10:16
The thing is that you don't have to accept their bullshite. I never buy anything without a lot of research. I mean a lot too. If people only researched a lot more their would be less seemingly ridiculous questions and replies on forums, farcebook and other social media. Misinformed forum experts...that would be everyone who posts on a forum...someone will always find a fault with a statement or fact you have written.
As I said...the best way to ensure you get good advice is to do heaps of research...not just farcebook, google, forums but to actually talk to people who have purchased the product...not always possible but great if you can.
FollowupID: 917530
Follow Up By: RMD - Sunday, Dec 05, 2021 at 10:43
Bigfish - QLD.
The renogy panels while quite good and stated at 8.55 amps is conservative if you get 11 amp flow sometimes. In theory @ 14v the panel should be delivering 14 amps if really 200w. Most people don't/can't run their system at the peak power voltage, but achieve close to it with an MPPT reg .
I have one quality panel of 80w and it delivers 6 amps cc but less in reality, 5 + when in system operation, therefore, a similar 200 watt panel should deliver 13 + amps in theory. Most times the output is not near the stated with any panel. I have two used, 36v oc panels, total 500w claimed, in series on a system and the MPPT reg has registered 470watts just once. Not sure why it got that high. Mostly/daily it nears 320w Max from a 12.3v level in good conditions, so a lot less than all the figures.
Not sure that QLD needs to double everything though, but as long as people work out the stated figures and claims and then expect it to be at least 30% less in reality and work on that level most are happy with their gear. "Nothing is ever as it seems".
FollowupID: 917531
