Snail Trail on maps?
Submitted: Monday, Oct 09, 2023 at 10:19
Member - Gene V
Howdy all,
For some reason when im on a trip my maps aren't leaving a snail trail. I have it set to snail trail in settings but my trip leaves no line as I go.
Appreciate any advice.
Reply By: Member - Duncan2H - Monday, Oct 09, 2023 at 13:31
Is it possible that its just the colour of your snail trail thats causing issues.. it can be difficult to see at times. I found "maroon" works best.
644589
Reply By: ExplorOz - David & Michelle - Monday, Oct 09, 2023 at 15:29
If the trail is not showing on the map have a look in the Map Layers tool and scroll down and ensure Snail Trail is turned on.
Map Layers Tool
Ensure Snail Trail is visible on map
644590
Reply By: Member - Gene V - Monday, Oct 09, 2023 at 19:34
Thanks for the replies guys. Snail trail is definitely turned on and I've tried different colours but still nothing showing.. ?????
644592
Follow Up By: Member - Dick L - Tuesday, Oct 10, 2023 at 10:11
What device and Operating System are you using?
Does it have a GPS?
Is the satellite symbol in the top left corner of the map screen green?
Do you have Offline Maps selected? For when you have no internet signal.
924728
Reply By: Member - Gene V - Tuesday, Oct 10, 2023 at 12:42
Thanks mate. I use a Samsung Galaxy tablet in the car. It tracks fine across the map.. so no GPS issues.. just no snail trail.
I have the offline maps selected and they work fine.
Still no snail trail unfortunately...
644595
Follow Up By: TrevorDavid - Tuesday, Oct 10, 2023 at 13:17
Gene
Clear your tablets cache & then reboot it.
TrevorDavid
924730
Follow Up By: Member - Dick L - Tuesday, Oct 10, 2023 at 14:39
I have never had a reason to use Snail Trail. So, I just tried it on my Samsung Tablet, and it worked fine. If TrevorDavid advice doesn't work, as a last resort delete the App and completely re-install. I know a pain having to download everything again.
924731
