Wednesday, Nov 23, 2005 at 18:25
Brd.
First, I think you should correctly identify yourself if you are the major supplier/ distributor of this product.
Second, engine flushing products are not new, they go back about as far as the original internal combustion engine.
Third, This product also claims to improve compression by removing cylinder glaze. This means an abrasive compound is incorporated in your product. (omo?)
Fourth, whether petrol or diesel, all engines require compression pressure to function correctly. Piston rings are designed to do two things only. a/ to maintain a piston/cylinder seal, and b/ control oil bypass to the combustion chamber to control excess oil consumption. To claim that diesels require "less fouled piston rings" is quite erroneous, after all, petrol engines develop far higher bmep's than their diesel counterparts.
Finally, for all the engines that failed "just before doing a flush" Well it says it all.
Thanks for not trying to sell your product brd.
394281
