Tuesday, May 11, 2010 at 09:25
righto - heres a cutn paste from a while back - if the directions look dodgey then follow your nose from the map
Hunts
pinnacles
After Seeing these
Pinnacles onmy previos trip to Queen Victoria Springs I decided to go for a look
I took off from kalgoorlie and headed n/e along yarria road past
kanowna belle
Mine and then the Hills which make a good playground. Just after the hills it is east onto the
Kurnalpi pinjin road until (all 51j) e 437829 n 6626541 where there is a
grid and you turnleft following the fenceline until e437476 n6628665 where you come to yowie
rockhole and turn r through an open
gate onto an old telegraph line. e4445588 gilgarna
rock and
rockhole kso until e445591 n 6644036 where there is an open
gate but you head left (n) if you go straight on you rejoin the
Kurnalpi pinjin road. e443803 n 6620269 there is a tank alongside the track and looking to your left is Hunts Pinnicles you drive accross the samphire salt pan to get to it e442633 n6649896. They are a series of steep hills grouped together that tower above the flat soroundings with breakaway formations at there base and caves higher up with a cairn atop the highest pinnicle. This trip is easily do able as a day trip from kalgoorlie or can be part of a longer trip to Queen victoria Springs
hers a
pic from the telegraph line which gos to old pinjun (
well worth a look in itself.
the pinnacles are maybe a bit less impressive than they sound but are an interesting diversion in a pretty flat area
id scan some pics if i was
home. You can see them off in the distance from gilgarna
rockhole and i new i had to have a gander
686324
