Navman MY 75T With Hemma 4WD Tracks
Submitted: Wednesday, Mar 30, 2011 at 18:57
Tonyfish#58
Cost of this unit is around the $350 Mark - The list of 4wd Tracks is not bad and covers a lot of the outback
treks including the
Simpson desert.
List of tracks 4wd covered
When you go to this site you can open a link to the PDF showing all tracks covered
Thought I would give it a go (From Dick Smith)..Anyone have any comments on this product?
Regards Tony
Reply By: Member - Leigh (Vic) - Wednesday, Mar 30, 2011 at 20:05
Hi. Not familiar exactly with what they are offering but I do run Oziexplorer off a Navman MY55T. Have all the Hema maps and more loaded to a micro SD card and for under $200 it was a viable option. Not prepared to pay $1,000 for the Hema Navigator particularly when I already had the software and maps operating on the laptop. Hopefully the package you are looking at offers you some flexibility to load more maps and has sufficient utility to perform the functions you require. Would be interested to see how it performs c/w Oziexplorer. Cheers
449743
Follow Up By: Tonyfish#58 - Wednesday, Mar 30, 2011 at 20:39
So you would have to purchase Oziexplorer @ 200 and the Hema Maps as
well?
Cheers Tony
722157
Follow Up By: Isuzumu - Wednesday, Mar 30, 2011 at 21:37
It looks like it is the Hema 4WD Maps 2011 which is sold here and it includes the Oziexplorer soft ware. If it is not then all you need to buy is a GPS from E.Bay which runs Windows CE 6 and buy the Hema 4WD maps here and away you go. Just make sure the GPS you buy has good screen res.
722167
Follow Up By: Isuzumu - Wednesday, Mar 30, 2011 at 21:39
First go into Dicky's and ask for a demo see what is on it.
722169
Follow Up By: Tonyfish#58 - Thursday, Mar 31, 2011 at 18:33
Finally set a trip from
Birdsville to
Alice springs for a preview - Its just like a street navigator - all you have is a line on the map to follow with no features.
But hey at least you know you are on the track :-)
So very basic, but if I can work out how to unlock it to put other Maps on -
well it may be OK :-)
Cheers Tony
722266
Follow Up By: Isuzumu - Thursday, Mar 31, 2011 at 19:48
A mate said that the Navman can be unlocked, do a google and see what you come up with mate
722281
Reply By: Member - Tezza Qld - Wednesday, Mar 30, 2011 at 20:57
Tony
The site say's optional hema map download. Does this mean that nothing in the way of 4x4 maps is supplied with the unit and is the download free?
Also is the 4x4 mapping a touch screen in raster map format? I know very little about this type of gps as I only use a mapping gps which shows topo's in vector format. This format is much clearer and comes down to 35 feet without distortion
Would'nt mind something similar in raster format as to follow a track in vector you continually change pages.The touch screen and raster mapping in the Hema seems ok but I wouldn't use the street stuff. I realalise that raster mapping gets a bit blurry when zoomed in lower than about 500 mtrs.
Also I'm not interested in carrying the computer bit. Haven't even mastered cut copy and paste yet so computers are definately not my forta.
Would be interested to see how your Navman goes
Cheers Teza
449752
Follow Up By: Tonyfish#58 - Wednesday, Mar 30, 2011 at 21:07
This Model has them already loaded (Thats what it says on the box and has a function on the unit to switch them Off/On) - have no idea what they look like as yet - still trying to find my way through it?
Will post later when I do one of the roads up near
Cooktown - The
Creb Track is one of them, aslo Battle
Camp Rd
Regards Tony
722160
Follow Up By: Member - Tezza Qld - Wednesday, Mar 30, 2011 at 21:17
Ah Two of my favourite roads. Will be back there in June to wet a line, probably near the mouth of the Jeani before returning to
Cooktown and taking the tour to the top and back
Cheers Teza
722161
Follow Up By: The Explorer - Wednesday, Mar 30, 2011 at 21:36
"I realalise that raster mapping gets a bit blurry when zoomed in lower than about 500 mtrs."
Hi - not true - depends on what scale and/or resolution the raster image (map/airpohoto) was made at. Digital photos are in "raster" format. If you take a photo of an object, load it on your PC and then zoom in it will get progressively worse. If you need better detail then the solution is to get closer or use a zoom lens to capture the image.
Solution with maps is get a larger scale map or higher resolution airphoto (if available). You can get airphotos for some areas of Australia that are much less than 1m per pixel which allows you to see individual branches on trees which is a much lower zoom level than "500 mtrs".
Also be careful when interpreting the accuracy of vector images - they may appear "without distortion" when zoomed right in but the actual accuracy may or may not be way out as the data used to create the points, lines and polygons may have been captured at a less detailed scale.
722165
Follow Up By: Tonyfish#58 - Thursday, Mar 31, 2011 at 18:35
Tezza - It is very basic - just a line on the screen to follow - will have to see if I can put other Maps on it as
Cheers Tony
722267
Follow Up By: Member - Tezza Qld - Friday, Apr 01, 2011 at 18:24
Ah
Cheers Tony Thanks for the update.
Teza
722463
