Monday, Aug 04, 2014 at 20:19
Amy,
What I would do in your case, is to start with a sound setup, to which you can add to if you need to.
Sidewinder (a business member on this site) provide a very good "flyer" battery box, to contain an AGM type battery in
the tub of your Hilux. The Flyer can be purchased in two configurations, one with a built-in battery isolator and one without the isolator. As you intend to utilise a
solar panel array to provide a charging source while stationary, I would suggest the Flyer without the isolator as a cheaper option, then include a Ctek D250S Dual dc-dc charger which has an alternator input port, a
solar input port and a built-in MPPT
solar controller. (you will need to bypass any on-board
solar controller on the
solar panels which are usually not all that good anyway)
So, you can maintain a charge from the vehicle alternator into the Battery (installed inside the Flyer box) when driving, then when setting up
camp, connect the
solar panel array to the
solar input port of the Ctek. If circumstances prevail where insufficient charge is being received from the
solar source, you can simply start the vehicle (without the need to disconnect anything) and the D250S will automatically determine the best input source, which in this case would no doubt be the vehicle alternator.
A run of half an hour or so may be sufficient to boost the battery level to an adequate level to maintain operation of the fridge.
The Flyer box has both cigarette style and Merit style sockets to plug the fridge into.
One other addition I would add, is a Battery Protector (also available from Sidewinder) to connect between the output port of the Flyer and the input to the Fridge.
This will stop excessive drain of the auxiliary battery to the extent that it may be permanently damaged if drained down too far.
Sidewinder
With this setup you could easily add another panel to the
solar array if required, to eliminate the need to run the vehicle at all and without replacing anything else.
A 120Ah AGM battery should be big enough for this setup.
537177
Follow Up By: Member - bbuzz (NSW) - Monday, Aug 04, 2014 at 20:29
Why are people afraid of 3 way fridges?
You buy the fridge and a 4kg gas bottle and it suits all situations. Its the cheaper option that always works.
3 ways can be fridges or freezers and on gas, when sitting for a week or 2, work extremely
well, for a fraction of the $ output.
bill
821437
Follow Up By: Andrew D7 - Monday, Aug 04, 2014 at 20:29
A substantially superior setup can be made up with assistance to the OP than buying a setup from Sidewinder.
821438
Follow Up By: Andrew D7 - Monday, Aug 04, 2014 at 20:53
Bbuzz people are not afraid of 3 way fridges, they don't cut it in temperatures over 32C. Travelling the 3 way fridges flood. Small chest type 3 way fridges need to be 100% level and stationary.
When away putting a lot of warm food into a 3 way, the 3 way can take 48 hours to reduce the temperature to 4C which is essential for food safety. If in areas with warm/hot nights a 3 way can seriously struggle.
40L Chescold is $800 so not cheap. Gas usage is 375gm/day so 1kg+ every 3 days. If remote camping buying LPG refills is often impossible. 9kg swap n' go are EXPENSIVE.
In the 3 way chest fridges the only units that are reasonable are the 40L and 50L Chescold.
Personally I would never ever own a 3 way fridge of any type ever again.
821440
Follow Up By: Sand Man (SA) - Monday, Aug 04, 2014 at 21:17
Andrew,
I have no idea what you are referring to when you say "assistance to the OP" and I think other folk may also be wondering what you are referring to.
It is obvious from your reply that you are anti Sidewinder.
I recommend to others, what I have tried and proven myself.
I own a Flyer and it is an excellent product to contain a battery in a safe and secure manner, provide a status of battery level and supply output sockets of various styles to connect fridges, etc to.
It comes with all the necessary cable and connectors to enable vehicle alternator charging without guesswork.
I also utilise a battery protector which as
well as providing a cheap means of low voltage cutout protection, gives a ready indication of functional operation by way of the green/red indicator. (I did replace the standard ciggy plug with a merit style plug, which I use for all my low voltage 12v devices).
So maybe you could elaborate more on what your practical solution may be?
821444
Follow Up By: Member - Frank P (NSW) - Monday, Aug 04, 2014 at 21:36
"A substantially superior setup can be made up with assistance to the OP than buying a setup from Sidewinder."
So, Andrew, tell the OP how to do it. Without that info your post is less than helpful.
821446
