Can 'Di-San' replace 'Napisan' as replacement in portaloo?
Submitted: Tuesday, May 19, 2015 at 20:23
Kathy M
a newbie here!
I read an archived thread from 2009 about using napisan to replace the expensive chemicals used in porta-potty cassettes.
Everyone mentioned using
home brand napisan from coles or woolies, but I can find that brand.
Has anyone used ALDI'S 'Di-San'? Its active ingredient is BENZALKONIUM CHLORIDE and also contains 'natural eucalyptus oil.
Does anyone know if these ingredients are safe for a porta-potty
toilet cassette?
look forward to your thoughts,
Many thanks,
Kathy
Reply By: Pete Jackman (SA) - Tuesday, May 19, 2015 at 21:43
Hi Kathy,
The chemical in Napisan or the
home brand equivalents is Sodium Percarbonate. We currently use the woollies brand called "Laundry Soaker and Inwash Booster".
Woollies Brand
While a little lower in the active ingredient, it works
well and is septic tank safe so can be dumped in our hi tech waste water system at
home without any problems and is safe for long drops, but dumping in those is frowned upon these days.
There is some good info on the threads you have looked at in this
forum and a detailed explanation here:
Chemical Toilets
If you google BENZALKONIUM CHLORIDE it looks like a quite agressive biocide that may not be welcome in a lot of sewerage systems.
553983
Follow Up By: Pete Jackman (SA) - Tuesday, May 19, 2015 at 21:46
The coles equivalent is called "Coles Ultra Booster Advanced Oxy." I guess with everyone using disposables there is no call for Nappy Soakers anymore!
839908
Reply By: Nomadic Navara - Tuesday, May 19, 2015 at 22:23
Reply By: Member-Heather MG NSW - Wednesday, May 20, 2015 at 06:38
Hi Kathy,
We are using Odour-B-Gone quick release tablets which have similar ingredients to Nappy soaker and they work
well. Available in RV accessory shops. All that is required is to place the tablet and half a cup of water into the cassette each time after it is emptied.
Although they aren't a cheap alternative to Thetford chemicals they are safe for the environment.
regards,
Heather
553991
Reply By: OBJ - Wednesday, May 20, 2015 at 07:27
To answer your question, and not offer you a bucket load of alternatives ... Yes!
We use it and find it very effective.
OBJ
553993
Reply By: Sand Man (SA) - Wednesday, May 20, 2015 at 07:40
Hi Kathy,
While most of the "Napisan" type products will work, some work better than others.
The
Home Brand Napisan product used to be the go but now has less sodium Percarbonate, which is the active ingredient.
I have changed to Coles Ultra Booster Advanced Oxy which has about 34% active ingredient.
Here is a link to Member Motherhen's excellent Blog on the subject.
Motherhen's Blog
553994
Reply By: Racey - Wednesday, May 20, 2015 at 09:08
Kathy, Use the Aldi Di-San OXY in the purple container. It active ingredient is Sodium Perbcarbonate, same as Napisan. It used tobe slightly stronger, not sure of current strength. Don't use BENZALKONIUM CHLORIDE products
Jon
553999
Reply By: MARIC - Wednesday, May 20, 2015 at 10:31
Hi Kathy, digressing a little..
We have given up on any type of additives and installed a 'SOG' system, basically it works on the principle of when the slide on the cassette opens a fan operates on the outside through a carbon filter. No smell and your contents decompose quicker
Hope thishas been some help
554004
Follow Up By: Member - Rod N (QLD) - Wednesday, May 20, 2015 at 12:09
I agree with Maric. The SOG mechanically introduces more oxygen into the cassette via the fan, where as the sodium percarbonate products introduce more oxygen by chemical means.
839937
Reply By: Kathy M - Wednesday, May 20, 2015 at 15:04
Thank you to all of You!
what a speedy response to my quandary!
found the soaker at woollies and i know if i ever get stuck there are a couple of options!
most grateful!
Kathy M
554009
Follow Up By: Pete Jackman (SA) - Monday, May 25, 2015 at 11:50
Hi Kathy,
I asked Aldi for a MSDS for their DiSan product:
"Di-San Oxy Laundry Soaker and In-Wash Booster 2kg"
According to the MSDS the ingredients are:
COMPONENTS CAS No. Proportion (% w/w)
Sodium Carbonate 497-19-8 30-60
Sodium percarbonate 15630-89-4 30-60
Surfactants 68081-81-2/68131-39-5 <10
Citric acid 77-92-9 <1
Protease enzyme (subtillisin, lipase) 9014-01-1/9001-62-1 <0.1
Other ingrediants classified as not hazardous according to NOHSC To 100
So it also should be fine.
Pete
840194
Reply By: Kathy M - Monday, May 25, 2015 at 20:26
Wow, that's incredibly considerate of you to go out of your way to
check up on the ALDI product!
The product I bought with the Benzalkonium is a 'laundry sanitiser' not a soaker--but i have since purchased their 'oxy' booster which is what I think you are referring to--AND i've got the woollies soaker as
well--so I'm pretty stocked up; just won't use the laundry sanitiser in the porta-loo.
thanks again
Kathy ;-))
554222
