Aussie Camp Shower questions
Submitted: Thursday, Sep 09, 2004 at 11:34
ThreadID: 16157 Views:9517 Replies:9 FollowUps:21
I have had a look at the three main shower options & have decided the Aussie Camp Shower suits us best.
Has anyone used one in conjunction with a 'pop up' shower tent? I presume the unit would have to stand outside the tent. Even then, is there a risk of the tent nylon melting from the rising heat?
When using the tent is water heat control a problem or does it not fluctuate when set?
Can it be connected direct to a 9 kg gas bottle?
Is it easy to light?
If I place the unit next to a river and place the pump in the river, is it powerful enough to get the water up the extra bit of height to the shower head?
Is the current draw minimal? - My intention would be to power it from the car battery.
Thanks everyone.
Reply By: Truckster (Vic) - Thursday, Sep 09, 2004 at 11:40
What were the 3 main ones you looked at?
Twine, Glind, McPauls?
None connect to gas bottles as far as I know...
AnswerID: 75774
Follow Up By: Dave - Thursday, Sep 09, 2004 at 11:57
In addition to the Aussie Camp Shower, I looked at the Primus and the Coleman, which has just been released in Australia.
These three connect to gas bottles.
FollowupID: 335598
Reply By: GUPatrol - Thursday, Sep 09, 2004 at 11:43
Never place it next to a river, all the soap would be washing down the river!!!
Please look after our environment....
Never wash by the river, collect the water and take it away...
AnswerID: 75775
Follow Up By: Dave - Thursday, Sep 09, 2004 at 12:01
All I ever use is a small glob of shampoo and it is 100% bio-degradable.
Where I shower there is a constant large number of ducks all the time. I figure they create more polution than I ever will.
FollowupID: 335599
Reply By: Member - Raymond - Thursday, Sep 09, 2004 at 12:04
Hi Dave
I looked at this type of shower as well as the ones that work from the 4WD's engine, all around $400 + $100 for shower tent.
Thought about how we camp and decided that we normally have a camp fire, we carry a couple of big billy's for cooking and hot water (coffee + tea) so the easiest way was a 10 litre bucket, 12 volt shower unit, shower tent and heat up one large billy of hot water to 10 litres of cold for two showers.
Cost $120 the lot. Very little to break and only 10 minutes to heat the water
Ray
AnswerID: 75783
Follow Up By: Vince NSW - Thursday, Sep 09, 2004 at 12:17
What 12V shower do you have.
I have tried the yellow ones that you see in all the outdoor shops. So far we are on our 5th unit. The switch stops working after a few showers and I have to take it back. Am looking at the garden spray unit and will try it over the OCT long weekend.
Vince
FollowupID: 335601
Follow Up By: Dave - Thursday, Sep 09, 2004 at 12:19
Thanks Ray,
I have used the system you outline for quite some time. I have also used the hang up type solar bags.
Circumstances now make it necessary to spend the cash and get one of these gas heated ones.
FollowupID: 335602
Follow Up By: Mike Harding - Friday, Sep 10, 2004 at 09:15
Hi Vince
mike_harding@fastmail.fm
The switches on those yellow showers can be a bit useless. When they
start to play up activate them firmly in both directions 20 or 30 times
that will often clean up the contacts and make them work again. I don't
use the switch much, usually I use the flow lever on the shower head
to reduce or stop the flow, providing you don't leave flow cut off for
a long time the pump doesn't seem to mind.
Another possibility is to visit a boat shop and buy a cheap bilge pump
and make a shower from that. The pump will be much better quality.
Mike Harding
FollowupID: 335740
Reply By: Vince NSW - Thursday, Sep 09, 2004 at 12:09
I back up GUPatrol. You should always wash well away from a watercourse.
The ducks crapping in the water is one thing, BUT even "BIODegradable" shampoo has Phasphate in it. It will break down and add to the load in the water system. Australia is naturally low in Phosphate and the natural eco system is not built to take added loads.
Vince
AnswerID: 75784
Follow Up By: Truckster (Vic) - Thursday, Sep 09, 2004 at 12:25
I agree and disagree with the argument of shampoo etc..
Considering it would be 1 part per billiontrillion, I cant see it being an issue.
but then theres the arguement of if every1 did it would be a massive change, 1 part per trillion..
Remembering it will be diluted down from pure shampoo being lathered up, and if your doing it 20+foot from the waterline, not directly into the water, It would absorb into the ground - wouldnt it?
FollowupID: 335604
of course it depends on the size of the watercourse/river/creek/stream etc.
FollowupID: 335605
Follow Up By: GUPatrol - Thursday, Sep 09, 2004 at 13:43
But if we all did the same it would quickly become polluted....
FollowupID: 335626
Reply By: Dean - Thursday, Sep 09, 2004 at 12:44
Does anyone use the old type canvas bag shower with a shower head. Ive never used one but seem to be a reasonable option.
Are there any glaring problems with this set up?
Most of the bush TV stars seem to use them, for the camera anyway.
Dean
AnswerID: 75795
Follow Up By: jolls - Thursday, Sep 09, 2004 at 14:03
Mate,
been using them for 20 years in the Army. They are the ducks guts. cheap from the disposal store and easy to use. Just need a tree limb.
Jolls
FollowupID: 335635
Follow Up By: Truckster (Vic) - Thursday, Sep 09, 2004 at 14:38
what about the solar bag $9.99!
[ View Image]
The canvas one. $32.95 Sounds good to me.
[ View Image]
FollowupID: 335636
Follow Up By: jolls - Thursday, Sep 09, 2004 at 14:44
The canvas one Truckster put up looks to have a very small shower head. If you shop around you can find some great canvas ones.
FollowupID: 335638
Follow Up By: Member - Melissa - Thursday, Sep 09, 2004 at 15:37
Never owned one but friends of ours used one daily for several years and we regularly stayed with them so we had to use it too. They were living in a caravan on a 5 acre block and had no running water but had the shower set up in their shed. Worked a treat. The shower head gives a good spread of water which is nice and steady until the back gets close to empty. Then being gravity fed the pressure drops off a little but still a great unit.
Solar showers...used one for several years and they heat the water really well when there's adequate sunlight around. Problem we had with them was you couldn't really get them warm when travelling and also, once the sun starts to dip they cool off pretty quickly. So you really had to have showered by mid-afternoon at the latest or you ended up having a cold shower.
Got a 12V unit now and we've found it extemely useful. The little pump has also come in handy on a couple of occasions to pump some water out of a bore tank.
:o) Melissa
FollowupID: 335649
Follow Up By: Truckster (Vic) - Thursday, Sep 09, 2004 at 16:15
Melissa,
can you put warm water into the bag of the solar one? or is it a PITA?
I like the canvas idea, but if you somewhere where theres no trees, or place to hang it up, what do you do?
FollowupID: 335655
Follow Up By: flappan - Thursday, Sep 09, 2004 at 16:41
You can Truckster , but it can be a PITA.
For a Once off , you would probably live with it , but if you had to do it a couple of times (we used to set out 3) , it really IS a PITA.
Thats why we went to the McPauls
FollowupID: 335661
Reply By: flappan - Thursday, Sep 09, 2004 at 12:49
Does the Aussie Camp Shower have a Heat cut out ?
My info is , that it doesn't , unlike the Coleman & Primus.
What this means that if the water stops , but the heating doesn't , it cooks the Heat Exchanger , and its all over.
AFAIK , Both the Coleman & Primus have this cutoff facility , which I believe IS required to be approved by the Aussie Gas Association
AnswerID: 75796
Reply By: Baz (NSW) - Thursday, Sep 09, 2004 at 13:12
We looked at the units you mentioned and talked to people who had them also looked at the stories in this forum about them too, thats why we went for the heat exchange the heat is controlable and no gas and you don't have an extra item to carry around and you don't have to shower next to the river, [ View Image]
Baz.
AnswerID: 75803
Follow Up By: Wombat - Thursday, Sep 09, 2004 at 13:18
Your unit comes with its own water supply Baz? Amazing!
FollowupID: 335619
Follow Up By: Baz (NSW) - Thursday, Sep 09, 2004 at 13:44
The river is about 15mtr's to the left or i use the water tank in the trailer.
FollowupID: 335627
Reply By: Wizard1 - Thursday, Sep 09, 2004 at 14:40
At that price I'll stick to heating water on the stove or fire................
AnswerID: 75826
Follow Up By: Truckster (Vic) - Thursday, Sep 09, 2004 at 16:18
I must admit $300-600 for a shower that will be used 10-20 times a yr is a bit over the top!
FollowupID: 335657
Follow Up By: flappan - Thursday, Sep 09, 2004 at 16:40
Not when it involves 5, 6 or 7 people . . . .
Its a BLOODY lot of water to boil/warm.
FollowupID: 335660
Follow Up By: Member - Luxoluk - Thursday, Sep 09, 2004 at 19:22
You aint lived yet Truckster! Nothin like ending a dusty day in the desert and hooking up to a Glind shower...pure heaven! Remember you only need spend the money once......but not much ROI if you're an 80yo!
FollowupID: 335678
Follow Up By: Truckster (Vic) - Thursday, Sep 09, 2004 at 23:23
Theres only 3 showers in our car.... thank god, yes for 6-7 I would dish out the coin.
For $39.99 I can get the canvas one, boil few billys and have same result.. and $500 towards a locker!
IM working on how often it would be used.
FollowupID: 335707
Follow Up By: flappan - Friday, Sep 10, 2004 at 09:04
Rather then boiling the water , one of those Hot Water Donkeys , could be the go.
Of course that relies on a fire to work .
FollowupID: 335736
Reply By: SunMan - Friday, Sep 10, 2004 at 07:57
Bought a Coleman to try and after trying sold the Aussie camp shower
Used the Coleman 2 times and lot better unit
you can switch water on and off one button no messing around
waiting for the hose for Coleman so can use off big gas bottle
the hose will be available next month
SWMBO likes the Coleman hot water for cooking and dishes
for kids the Coleman is much safer unit
AnswerID: 75902
