Tyre for outback touring
Submitted: Saturday, Feb 26, 2005 at 07:29
jackablue
Whats everyone opinions on the best type of tyre for outback touring?
Jackablue
Reply By: Wayne (NSW) - Saturday, Feb 26, 2005 at 08:08
Jackablue,
You will get a lot of different answers on this one, and they will all be what drivers have experienced of the last few years.
I have been running BFG Muddies for about 10 years and have found them to be good. Even the bad batch that came through were still not that bad.
However, I am waiting to fit a set of the new Cooper STT, (aka Bubble Gum Doughnuts).
The trips that I have planned for the next 6 months will cover just about every track condition that is out there, this will give them a good work out.
Regardless of what tyre you run, I think that tyre pressure is more important, and what tyre pressue to run will depend on a lot of factors and again a very personial thing based on experience.
Wayne
100222
Follow Up By: jackablue - Saturday, Feb 26, 2005 at 08:51
Thanks Wayne, I have BFG AT at the moment but they have 55000kms on them & I would like to start a trek to the centre with new tyres. Just wondering about AT/ MT in regards to noise & picking up stones.
358401
Follow Up By: Bonz (Vic) - Saturday, Feb 26, 2005 at 09:15
Jacka, I have BFG AT's on
mine too with 65000 on them, and am heading up across the Simpson in a months time, I have gone for Cooper ST-C's, due to the same noise considerations you state. I have BFG MT's in the shed which I use for High Country stuff as
well as Otway mud plugging, and I reckon the ST's are a excellent all purpose tyre with a slightly more aggressive stance than the BFG AT's.
That said the AT's have been excellent,
mine still have 10-50k left in them at least.
358402
Reply By: Footloose - Saturday, Feb 26, 2005 at 09:53
If its only the usual dirt track then you can use whatever you fancy. If it's the CSR then don't use "wide" tyres. If doing any cross country or serious off track work use a L/T tyre with as many ply in the sidewalls as you can get.
Arguements about which tyre are a bit pointless in the bush. If you are unlucky then even the most expensive u beaut tyre can become a pile of junk very quickly indeed. There's more advertising hype about 4wd tyres than almost any other part of your vehicle. Yes, some are better at this and that but your choice should depend on what you drive, and the kind of driving you do and how much you're carrying.
The trick is to run lower pressures and slow down.
100232
Follow Up By: Willem - Saturday, Feb 26, 2005 at 13:19
Footloose
I am interested to hear your reason behind ". If it's the CSR then don't use "wide" tyres".
We ran 750x16 on the CSR with out too much grief at 15-20psi. Now I run 265x75x16 and find them better in dune country than 750x16
358416
Reply By: Footloose - Saturday, Feb 26, 2005 at 14:01
Hi Willem That comment was based on the ply rating of the sidewalls of wide tyres vs L/T tyres. Staking is a major problem as you'd know. Now maybe I'm a bit out of date, but when you let a wide tyres pressure down it may not produce a larger footprint than a narrow tyre from what I've read. And as you know its all about floatation, tyre pressures (heat buildup) and staking.
There's a couple of great articles on this topic. Ron Guard (CSR Travellers guide pp14-15) and an excellent web page on Beadel's bush tours site. (sorry forgot the url...will be on Google).
100251
Follow Up By: Footloose - Saturday, Feb 26, 2005 at 14:09
Availibility in the bush might be another reason.
358421
Reply By: Member - Davoe (WA) - Saturday, Feb 26, 2005 at 15:13
Its all a comparamise somewhere hence all the different answers if you want sheer puncture resistance then the tyres we use at work are great dunlop dr2 12 ply rag tyres but they are crap in mud and dont float as
well as tyres with thinner sidewalls
100256
Follow Up By: V8Diesel - Saturday, Feb 26, 2005 at 15:31
Davoe is dead right. I worked in mineral exploration (WA Goldfields and
Pilbara) and we had 5 or 6 Landcruisers doing solid bush bashing 7 days a week. LT 12 ply (or more) rags are the only way to go for rough work in this type of country. Hi-Milers are good. Skinny is better because is offers less of a 'target'. Grip is totally irrelevant went you don't have sidewalls remember. Look what Len Beadell used and how far he got on razor blades in an old, underpowered Series 1.
Best advice is to look at what people who earn their living everyday use in the terrain you want to drive over and talk to them.
358433
Follow Up By: Footloose - Saturday, Feb 26, 2005 at 20:20
I totally agree. The problem of course is that to get to
the desert regions of WA from the eastern states there's a lot of uncomfortable k if you have "stiffies" on. Put a heavy duty 7.50X16 on the tar and you soon wish for something a bit more exotic.
But you can't beat em in stake or ripper country, and WA has some interesting experiences in store for tyres in that country :)
Some of the blokes up here use two sets of totally different tyres, one for the city and one for the bush. Ideal if you can afford it I guess.
358465
Reply By: Crackles - Saturday, Feb 26, 2005 at 15:53
Wrangler MTR. Excellent traction, good road holding, brake
well on the tar, the tread compound resists chipping & the has one of the toughest side walls in a radial. Some all terrain patterns may last longer & be slightly quieter but I rate the MTR as the best all round off road tyre available at the moment.
Cheers Craig................
100259
Reply By: desert - Saturday, Feb 26, 2005 at 16:06
Well, there ar'nt all that many wide section tyres on the market that have a load range'E', which I have to use to carry the weight of the Nissan when loaded up for a 4 week desert jaunt. Skinnys just won't float the weight, even though they generally have stiffer walls to option from. As for availability, stick to a 32" tall tyre on a seven inch rim and you will be able to use a range of replacment tyres from 750x16(at a pinch) through to 275/70x16. Remember, uncommon sizes are hard to source in the boon-docks, but just about any store will carry a 750x16 to get you home. 265/75x16 is so close to the same height as a 750 that it doesn't matter.All this is pretty academic if you are driving a Diahatsu F10 and have to run 650's!
100260
Reply By: Member - Phil G (SA) - Saturday, Feb 26, 2005 at 21:41
Most people have said my usual line - its not so much what brand tyre, but how you treat them that matters.
Run low pressures,
don't speed,
don't overload,
use tyres with plenty of tread,
LT construction with a high load index;
Like desert said, 750R16, 235/85R16, 265/75R16 are all same diameter, and are the common sizes out bush.
Tubeless tyres give you much less hassles; can simply plug them if punctured.
I'm very happy using 265/75R16 on 16x7 rims. Been happy with most brands - MTRs are going
well at present.
100302
Follow Up By: Member - Phil G (SA) - Saturday, Feb 26, 2005 at 21:56
And just noticed from your name, you probably have a Jackaroo with 16x7
wheels; Common replacement for outback use would be the 245/75R16 as they usually come with a high load index (120 or E or 10ply in the old language). The other sizes I mentioned would probably touch a bit.
358480
Reply By: madlee - Sunday, Feb 27, 2005 at 19:47
Just thought I would tell you about the tyres used on the 3 vehicles used in my party's simpson crossing.We also travelled the
plenty highway and the old ghan.My car,toyota bundera,had31x10.5x15 bridgestone deuler 604(old pattern).I put new ones on for the trip.I was carring about 600kg of gear.tyre pressure,36psi.After 6000km trip,tyres were still in very good condition.Next vehicle,96 model troopy carring upto 1000kg,using 235/85x16 bfg AT about 60% worn before the trip,not much tread left at the end.Lugs were ripped off.(about 60psi)Third vehicle,96 patrol,about 600kg,had 31x10.5x15 dunlop grandtrek AT2,about 60% tread,He had put 2 new tyres on after the
plenty highway due to sidewall damage.the tread survived ok.Tyre width didn't seem to matter greatly.We all had a little difficulty at some stage in the sand.Being a mechanic,I see a large range of vehicles and types of tyres.My personal choice of tyre is the bridgestone mainly for the reason if they are your general use tyre ,in my experience,they grip so much better in the wet.A problem I have noticed and heard about with dunlop's is delamination.Over all the decion is up to you.listen to what other people say.If a tyre is going to be damaged it will probable happen regardless of what tyre you have.Also ,the 235/85x16,we needed to replace one due to a puncture on a sealed road after
the desert,could not get areplacement until we got back to
brisbane.
100389
Reply By: snailbate - Sunday, Feb 27, 2005 at 20:11
jackablue
The tyre of choice for the
Sydney club scene is the BFG alterain which has 3 ply on the side walls and more on the tread but evan these tyres can sustain cuts on the side wall when they are below 18 or 20 psi
mine have 45000 ks and i am thinking about changining them
Snailbait
100394
Reply By: Member - Sand Man (SA) - Monday, Feb 28, 2005 at 09:55
Jackablue,
How much money do you wish to spend?
I run Bridgestone Dueller 694's on the Jack at present, cost is about $218 per tyre.
But as value for money, you would find it hard to beat the Bridgestone Desert Dueller. Have recently bought 3 for the Camper Trailer and the going price was $168 per tyre, from a Bridgestone Outlet.
A mate runs the DD on his Rodeo. Only got 70,000 from his first set:-))
100455
Follow Up By: Patrolman Pat - Monday, Feb 28, 2005 at 15:30
A mate of
mine has just replaced his DDs after getting 100 000kms in his HiLux on a set. Got to be happy with that.
358663
Reply By: Member - Chrispy (NSW) - Monday, Feb 28, 2005 at 15:20
One of the magazines (4x4 Australia - I think) just did a large expedition following Lean Beadel's route around the CSR area. I seem to recall that they mentioned some of the group were using Indian-made "MRF" tyres ( website here ) and found them to be generally stronger than any of the BFG/Cooper/Goodyear tyres because the MRF's run steel bands right around the whole tyre section including the tread. Apparently much harder to stake. Might be worth a look.
100508
