Getting water - Flinders Ranges
Submitted: Monday, Feb 28, 2005 at 09:37
Marko
Greetings again, I hope you had an enjoyable weekend. Excuse my ignorance but with the Flinders trip now only 2 sleeps away the 80series is all ready to go. I am carrying 50lt of
water with us. Now seeing this is my first 'outback' experience how do you go getting more
water? Obviously petrol stations and the like would have
water and we will be passing one every second day probably. But if Im not filling up with juice it doesn't feel right filling up with
water. What do you do in this situation?
Thanks in advance again...
Marko
(im not going to be sleepin real
well the next two nights :)
Reply By: Squizzy - Monday, Feb 28, 2005 at 10:05
Marko,
Depending on where you are
camping, there is
water available at
Wilpena Pound,
Rawnsley Park, and there is good spring
water at Aroona Valley from a standpipe.
There is also
water at
Blinman, Parachilna, Willow Springs,
Arkaroola, Grindells Hut, etc.
Have a great trip, (no need to tell you that 'cause I know you will)
Geoff.
100458
Follow Up By: Nudenut - Monday, Feb 28, 2005 at 11:19
Grindells Hut is a long way to go get some
water
358613
Follow Up By: Squizzy - Monday, Feb 28, 2005 at 12:24
I was only giving alternatives, Marko may decide to give the northern Flinders a visit.
And he did say the Flinders which covers that area anyway.
Most other points I mentioned are in the central Flinders area.
Geoff.
358622
Follow Up By: Member - Mike H (VIC) - Tuesday, Mar 01, 2005 at 00:10
Hi there.
I always used to replenish my
water from the standpipe at Aroona. A bit of lime, but good drinking.
However when I was there last November there was none. It either was turned off up at the spring or the level was too low.
Enjoy the Flinders,
Mike.
358757
Reply By: Member - Sand Man (SA) - Monday, Feb 28, 2005 at 10:08
Marko,
50 litres of
water should be heaps. Within the confines of the National
Park, most
campsite areas have a "central" outback
toilet. (very good design too)
At the rear is a rainwater
tank, fed from the roof of the
toilet block which should be sufficient to supplement your own supply.
In addition to this the chances are that you will find running
water in the creeks, which is of drinkable quality. If you wish, you can "sterilize" this by boiling first.
Depending on your location, you will probably find you will visit
places like
Wilpena Pound, or
Blinman, so additional
water supplies will be available here.
I'm sure you will enjoy your Flinders Trip as your first outback experience, so just relax mate and "soak it up".
100459
Reply By: Member - Pesty (SA) - Monday, Feb 28, 2005 at 10:35
Hi Marko,
Is your
water 50 L in one container?, if so take a 20l plastic container as some
water may not be so palitable and this will give you the chance to fill anywhere and us it for washing etc, to save tainting you
drinking water.
Have a great trip we try to get up there as much as we can, great place.
100462
Reply By: Marko - Monday, Feb 28, 2005 at 11:07
Hi all,
Thanks for the tips. Doesn't sound like
water will be any problem. With the current weather up there were going to need alot of it ... supplemented of course with some Boags for medicinal purposes...
Chat again in 3 weeks or so...
Marko
(this time next week... let me see...
camping around willow waters i reckon)
100467
Follow Up By: Member - Rick (S.A.) - Monday, Feb 28, 2005 at 18:14
Here's my suggestion:
As you travel, buy several 5 L or 10 L
water from the shops along the way.
For example, last'major' stop for retail purchases in the Flinders is at Hawkerat the grocers, over the road from Teague's
Mobil Servo.
Have your 50 L 'in reserve' as it were. Use it after you have used the 3 x 10 L you are gunna get. For budgeting purposes, remember 5 litres/head/day in these temps
A 10 litre generic brand cardboard box of
water will only cost a few small $'s. Easy shape to pack on the floor, behind your
seat etc.
Recycle cardboard box & bladder when consumed.
have fun
358696
Reply By: Member - Banjo (SA) - Monday, Feb 28, 2005 at 13:27
Marko - others may have said this but for safety and convenience (in that order) consider taking the
water in several containers (if not done already). If one springs a leak, all is not lost - also, if you can only obtain inferior
water at certain
places, you can put all the good
water into one of the containers. Options with storage are a great assett. And one of the best rules I've learned is to keep filling them up as opportunity arises - don't assume you can get quality
water "later on". Have a good 'un.
100486
Reply By: Marko - Tuesday, Mar 01, 2005 at 08:00
Greetings everyone,
This is what I have decided to do. 2 seperate
water tanks (20lt and 25lt) plumbed seperatley. 2 casks of
water 10lt for drinking. I'll mainly use the 45lt for washing/showering etc.
By the way I will be up near Grindels Hut around day 9 or 10. Sounds like
water is not going to be a problem. Thanks for your input everyone.
Regards,
Marko
(this time tomorrow, somewhere between
Melbourne and
Broken Hill)
100633
