Calling the battery experts
Submitted: Friday, May 06, 2005 at 13:09
boogum
Afternoon all; Sort of an off-road question. We have just bought a second hand tipping trailer. The hydraulic ram works from a 12v battery under the trailer. I think the battery is on its last legs.
Have been following the previous
forum discussions on different battery's for different jobs.
This battery is supposed to last long enough for 6 or 8 tips and then needs recharging. There are external points to apply the recharger (between the tandem tyres on one side). The tipping part won't be used all that often.
Which battery - normal, deep cell, marine etc. Thank you, Philip.
Reply By: Member - Jeff M (WA) - Friday, May 06, 2005 at 13:17
Can only assume that the Hydraulic ram is going to take a fair amount of current. If this is the case a cranking battery would be my recommendation. If you are using a cranking battery just keep it charged (don't run it down all the time) and it will be excellent for the job.
Have you thought about changing the trailer connections and running some 4g or 8g wire from the vehicle to the trailer. That way you could be charging the trailer whenever it's hooked up. May some of these trailer plugs people are using for their campers/caravans. I'm sure someone here would be able to help you out with those.
110020
Reply By: Truckster (Vic) - Friday, May 06, 2005 at 13:18
Why can you not charge the battery from the car alternator?
I would think very heavy duty if your going to drain it regularly.. it wont have a long life span which ever you go with
110021
Follow Up By: Member - Jimbo (VIC) - Friday, May 06, 2005 at 17:26
And keep the motor running whilst using the Ram and it'll never go flat.
366634
Reply By: Sand Man (SA) - Friday, May 06, 2005 at 13:39
You can also run a Deep Cycle battery "deeper" without killing it.
If you continually "drain" a normal starting battery you'd stuff it up in a short period of time.
A starting battery (rated on CCA) is designed to be drained "slightly" and then topped up" by a vehicle alternator.
110028
Reply By: phil - Friday, May 06, 2005 at 16:46
I would use a cranking battery and just charge it after use and occasionally when not in use to maintain it at full charge. Don't wait for it to get near flat. Batteries do not like this and reward you by diieing early.
I can see no reason to do anything complicated for something which is just used occasionally. If you were using it daily it would make sense to arrange some form of charging system from the car system to avoid having to connect up a separete charger.
Phil I
110048
Reply By: GaryInOz (Vic) - Friday, May 06, 2005 at 17:03
The logical question to ask is what type does it have in it at the moment?
Google the manufacturer and model number to bring up some specs.
110049
Reply By: Crackles - Saturday, May 07, 2005 at 13:23
A gell cell deep cycle battery would probably be the best but are expensive. Good vibration protection, about the right capacity (55amp hour) & most importantly low self discharge which is probably the biggest killer of batteries left sitting around like most tippers would be. Certainly importantant to fit a charge circut from the car but ideally for long battery life we now use small solar panels on our intermittant plant. Batt life has jumped from 6 months to 3+ years. Additional benifit of running a circut from the car is that if you keep the motor running you'd get 20 to 30 tips+
Cheers Craig.........
110152
Follow Up By: boogum - Saturday, May 07, 2005 at 13:43
Thanks for those replies. I bought it from the manufacturer but thought the best advice would come from the
forum. I will look into hooking up a wire from the vehicle for constant charging. Auto elec I suppose.
Philip.
366729
Reply By: tonysmc - Monday, May 09, 2005 at 16:46
Philip,
If you are running a wire from the vehicle to constantly charge your trailer battery, why do you need a trailer battery at all ? I would just leave the car running and plug the trailer into the back of the car and not have a battery on the trailer at all. I and friends of
mine do this all the time with electric boat
winches without a problem. I plug into the fridge socket inside the back door. If you are using another car you could always make up an extension lead that clips straight onto the cars battery for those times. May save alot of money on a battery.
Tony.
110478
