willow jerry cans
Submitted: Wednesday, Jul 13, 2005 at 01:04
ThreadID: 24675 Views:4398 Replies:8 FollowUps:21
I see supercheap has willow plastic fuel cans on sale. Red 20ltr "fuel cans" are $20 and yellow "'diesel' fuel cans" are $23, both are plastic. Does anyone know what the diff is between each? I was of the impression that if a plastic container was suitable for petrol it was also good for diesel?
Reply By: Member - Davoe (Widgiemooltha) - Wednesday, Jul 13, 2005 at 01:50
hope so i keep diesal in a red one BTW I paid alot more than that!!
AnswerID: 120083
Follow Up By: Member - iMusty (VIC) - Wednesday, Jul 13, 2005 at 13:17
What IS that THING in your rig pic?
FollowupID: 375177
Follow Up By: See You - Wednesday, Jul 13, 2005 at 13:54
What is that "THING" on YOURS
FollowupID: 375185
Follow Up By: Member - iMusty (VIC) - Wednesday, Jul 13, 2005 at 14:13
lolol
What happened to the N & the T in your signature?
Was very subtle.
FollowupID: 375186
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Jul 13, 2005 at 16:12
Have you tried clicking on it for a close up??? dont you get them in vic??
I will be back on the net this evening if you havnr guessed I will give you a hint
FollowupID: 375213
Follow Up By: See You - Wednesday, Jul 13, 2005 at 20:05
Dunno what happened to the NT after my name. Must be the right wing conservatives that run this site. All of my web stuff is logged on as See You NT. It has never been removed by any other sites at all. I guess that they dont recognise the wonderful state that I live in. Doesnt matter too much. I spend more time on other places than here. this is a bit conservative for me althoug a few of the reads are pretty good.
FollowupID: 375262
Reply By: Mike Harding - Wednesday, Jul 13, 2005 at 08:20
Don't quote me on this but; I have it in the back of my mind that there is something about diesel and static electricity - I have a feeling that it either generates more when you pour it or is more susceptible to than petrol... or possibly the other way around? That was helpful and clear wasn't it? :)
Either way stay with the appropriate container for the product. And make sure that when you fill them up in the service station REMOVE THEM FROM THE VEHICLE AND PLACE THEM ON THE GROUND BEFORE STARTING TO FILL in order that there is no potential difference between the container and the pump. It's actually not a bad idea to earth the vehicle before starting to fill, either with one hand on the vehicle and the other on the pump or touch the filler nozzle to a wheel nut etc before placing it in the petrol filler hole. There have been enough issues with fire/explosion in the US from people filling there cars that the static problem deserves to be taken seriously.
Mike Harding
AnswerID: 120098
Follow Up By: Member - rengatt (VIC) - Wednesday, Jul 13, 2005 at 10:33
Excellent advice Mike,
don't know if many people watch Mythbusters on ABC but they attempted to test the refuelling fire scenario with mobile phones.
Their conclusion was that the actual fires are not caused by electrical devices but by people not discharging static electricity when they get out of their cars.
They use their automatic fuel hatch button and then remove the plastic fuel cap. Then whilst refuelling they make contact with the car body generating a little spark which ignites the fuel vapours.
Refuelling containers whilst in the vehicle could also cause the same type of events due to the fuel creating static electricity in the container and in most instances the person will be supporting or resting on the container and be conducting the static electricity themselves. As the fumes gather in a semi enclosed area touching the car body then could create a spark.
I wouldn't take the Mythbusters findings as gospel as they don't have a what you could call a controlled environment during their experiments but it is food for thought.
FollowupID: 375149
Follow Up By: Mike Harding - Wednesday, Jul 13, 2005 at 11:02
Hi rengatt
Tried it once but decided the target audience was 15 year old boys :)
>mobile phones.
Given the output power of mobile phones the chances of it generating enough field strength to cause a spark is probably less than being struck by lightening whilst filling up. Although it is just possible that poor battery contacts in a mobile might (on a good day with a back wind) generate a spark.
The US has had quite a few fires/explosions at filling stations where there is very strong circumstantial evidence to indicate static as the cause. And almost everyone has first hand experience of the energy produced when their car get a decent build-up of static - it's enough
to give an unpleasant shock to the human body and more than enough volts to produce a spark which is all petrol vapour needs. It's a subject which is not getting enough exposure but as it's one most non technical people will not naturally understand there really needs to be more education about it.
Mike Harding
PS. Apparently diesel does produce a lot more static than petrol when you pour it but because it has a lower flash point it’s not a big issue.
FollowupID: 375151
Follow Up By: Mike Harding - Wednesday, Jul 13, 2005 at 11:06
Harding puts brain in gear:
Diesel has a _higher_ flash point than petrol!
FollowupID: 375153
Follow Up By: Member - Tonester (VIC) - Wednesday, Jul 13, 2005 at 12:58
"Tried it once but decided the target audience was 15 year old boys"
cmon Mike! We all have a little boy inside crying to get out. I reckon its bloody halarious. (that is, in between the static that is usually the reception I get on that channel)
FollowupID: 375174
Follow Up By: Member - Jeff M (WA) - Wednesday, Jul 13, 2005 at 13:18
I wouldn't worry about earthing if your dealing with Diesel, that's the whole point with diesel. It doesn't ignite like petrol does (doesn't leave the same kind of vapour trail). Why do you think the diesel bowsers still let you lock the pump on and not hold the pump handle while filling, because if you get a small spark (Static) when you earth yourself to the handle again it's extremely unlikeley it will cause a problem, that's also while trucks etc (and me) keep the motor running while filling up as it's not a drama (no spark plugs for a start) but also because the fuel is a lot less volitile.
As to why there is a different container (and a more expensive one) for diesel stuff knows, I use my black plastic jerrys for both, changing between fuels all the time with them, never had problem.
FollowupID: 375178
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Jul 13, 2005 at 21:42
You tried finding a bowser that lets you lock in the diesal pump? Drove me crazy filling the 250l tanks on the work utes. Then I figured it out, go to servos with truck filling stations and use those as they usually do lock in but most of the car type ones dont (truck ones fill faster 2)
FollowupID: 375297
Follow Up By: Ted (Cairns) - Wednesday, Jul 13, 2005 at 23:25
Hi Davoe
On the work ute I used the fuel tank cap wedged in the handle to lock it. Then again one overzealous pump guy saw me washing my windscreen etc while filling up and turned the pump off and told me off(!) I guess it's his job, but I didn't fill up there ever again. Time's too valuable to hold the diesel pump for ages.
FollowupID: 375316
Follow Up By: pjchris - Thursday, Jul 14, 2005 at 09:59
90% of the normal Diesel pumps I use here in Vic and Southern NSW you can click on and I haven't ever seen a high flow at a truck stop that couldn't be clicked on...
FollowupID: 375352
Follow Up By: Member - Jeff M (WA) - Thursday, Jul 14, 2005 at 10:59
Yeah Davoe, gotta admit that I've notice a few of the "pleb" standard flow pumps with removed locks but I try not to use them, I'd much prefer fast flow as long as I don't have to wait for someone else using it. I might only have a 65L tank but it's cool to put the pump in, lock it on, turn around on the spot and have your tank full LMAO! The Fast flows even in the undercover'd bowsers all have locks still. I've also been known to use the petrol cap as a wedge as well, it does work but it's a pain if the handle is all diesel greasey as it keeps slipping out!
I feel sorry for the poor bastrds that have to fill Prado's up with ULP... You see them there putting 170L of ULP in, I get impatient filling up the 40L tank in the Echo with those painfully slow ULP bowsers!!
FollowupID: 375359
Follow Up By: Member - Tonester (VIC) - Thursday, Jul 14, 2005 at 12:21
Yep, poor bastrd petrol prado owner here. You got it spot on Jeff.
FollowupID: 375379
Reply By: Member - Norm C (QLD) - Wednesday, Jul 13, 2005 at 08:47
I've used a red one for diesel for years. Have used my own colour code. Red for diesel, black for ULP.
Just did a google search. Found that in the USA, Gasoline (ULP) cans are red; diesel are yellow; water are blue. The cans are exactly the same, but are colour coded for easy identification.
Interestingly, I found that in the UK, black is for diesel; green is for UPL and red is for lead replacement. Again, the cans are the same except for colour.
Couldn't find any 'standard' for Australia except for a reference to all fuel containers should complu with AS 2906 and have this stamped on them.
So, I think the cans are made the same. Just the colour is different.
AnswerID: 120104
Follow Up By: Member - Jeff M (WA) - Wednesday, Jul 13, 2005 at 13:20
Sounds like supercheap are just jumping on the "rip the diesel owner blind for no reason" bad wagon then eh? Ba$#$%#@@#$#%##@#!
FollowupID: 375180
Reply By: timber - Wednesday, Jul 13, 2005 at 09:17
..........and don't forget Blue is for water ONLY.
Buggerlux
AnswerID: 120109
Reply By: hoyks - Wednesday, Jul 13, 2005 at 09:24
But I put my water in Green ones....how will I cope with all these new rules?
I just have black willow containers. If it is in a 20L drum, oily looking and smells like vegie oil then it is diesel, 5L are chainsaw/mower fuel .
Easy system.
AnswerID: 120111
Follow Up By: timber - Wednesday, Jul 13, 2005 at 10:15
...not wishing to hijack the thread, but my understanding of the idea of blue for water is that that colour has something to do with slowing down or stopping the growth of those little bugs that live in water, i.e. water in a clear container will go off quicker than water in a blue container.
Buggerlux
FollowupID: 375147
Follow Up By: hoyks - Wednesday, Jul 13, 2005 at 11:18
Maybe I should have included a big TIC in my post.
FollowupID: 375157
Follow Up By: Member - Jeff M (WA) - Wednesday, Jul 13, 2005 at 13:21
Timber, if that was the case then the black Jerry's would be best for water as no light would get in at all! ;-)
That's why my water tank is black, and all my hoses are not translusant. (spelling??)
FollowupID: 375181
Reply By: Member - Karl - Wednesday, Jul 13, 2005 at 10:46
As far as I know it is only for packaging/easy identification purposes and nothing else. As long as they are rated for the carriage of fuel they should be OK.
AnswerID: 120119
Follow Up By: Morrie - Wednesday, Jul 13, 2005 at 14:26
One of the resons why they are color coded is that they match the color of the fuel that goes in them eg, dieso yellow , the old leaded was red .Same as the tags you can buy for steel gerry cans.
...........Just my opinion
Catchya
FollowupID: 375187
Reply By: warthog - Wednesday, Jul 13, 2005 at 20:59
Thanks for the replies, never thought of the colour identifiing the fuel, think I'll buy the red and use my nose if I forget what fuel is in it. Cheers
AnswerID: 120229
Reply By: gforse - Wednesday, Jul 13, 2005 at 21:17
HI WARTHOG I USE a couple of supercheap yellow for diesel had a look at the containers the holes for filling are a different size the yellow ones have a large hole to take larger diesel nozzels best things i ever bought apart from the lux garry
AnswerID: 120237
Follow Up By: Member - Jeff M (WA) - Thursday, Jul 14, 2005 at 11:01
Can you not fit the fast flow nozzle in the red ones?? My black ones are a snug fit, it just slides in touching the sides (we are talking about fuel here!) ;-)
If the red ones can't take the fast flow, I'd go the yellow too as it'd be a pain in the but having to always use std flow...
FollowupID: 375361
