Pajero 2.8 diesel
Submitted: Wednesday, Sep 07, 2005 at 20:58
ThreadID: 26247 Views:17744 Replies:4 FollowUps:8
I am having trouble starting the motor when cold.I have had the injectors cleaned & new glow plugs fitted. Once warmed up, starting is excellent.I have been reading the fuel system section of the workshop manual which mentions "cold start device".Any info on this item would be appreciated.
Reply By: Member - Ian B - Wednesday, Sep 07, 2005 at 21:26
I've also got the 2.8 t.
I've just had all new injectors, all new glow plugs, and the small manual primer pump checked over.
I've just copied this from another forum, and it describes my problems to the nail. Starts dead easy any weather, but then after say 1 0r 2 minutes idling, starts faltering, then stops.
Real hard to start afterwards.
Here's the stuff I copied...
Subject : Pajero
Hi can anyone suggest why my 2.8 n reg pajero cuts out first thing in the morning after 1-2 miles. It then starts with some difficulty but then runs fine all day. A mechanic has suggested it is the fuel pump drawing in air and that this will need to be taken off and sent to be refurbished at a cost of £6-700. If this is the case surely it would be cutting out continually, not just from cold. I have had a new cold start rely fitted it but still cuts out.
robert clarke
- UK - Wed 12th January 2005 10:38pm (GMT)
Subject : Re : Shogun
Hi mate, I have the same problem with mine. Apparently it is a common fault in 2.8TD, the seal on the fuel pump goes. I am booking mine in at a cost of around 500, dear but i need it done, please let me know hoe you get on with urs
Irfan
Rochdale, Lancashire, UK - Mon 17th January 2005 12:11am (GMT)
Subject : Re : Re : Shogun
I have the same problem and have changed the rubber fuel lines and cleaned out the tank. Is the Fuel pump you are talking about the injector pump or the primmer pump Please let me know
Paul Penney
Larne, Co. Antrim, UK - Tue 01st March 2005 04:00pm (GMT)
I too would like to get mine sorted out.
When we do get it started, it blows out clouds of smoke, we keep wondering when the CFS is going to arrive.
As my wife says...
It's economical alright, 'cause she gets me to take her to work, 'cause it won't start some mornings.
Ian
AnswerID: 128957
Follow Up By: Member - Vince B (NSW) - Thursday, Sep 08, 2005 at 18:09
Hi Ian.
Thanks for your help.
It would appear that my problem could me in the pump afterall. Now to find a good diesel tech on the Gold Coast!!
Vince
FollowupID: 383617
Reply By: Member-Neil & Margie-Cairns - Wednesday, Sep 07, 2005 at 21:33
G'day Vince B ,
had the same problems with ours , we have had the pump and injectors done up , a short while it didn't want to start when cold ,, off i went and got a new set of glow plugs , wife droped it into the machenic , did a few tests , was the relay , have the injectors setting on the puter desk in front of me , didn't see him myself to ask where it is on the car , but shouldn't be to hard to find ,, can't find the invoice to say how much ,, but wasn't too bad ,, hope this helps , all the best ,
Neil .
AnswerID: 128961
Follow Up By: Member-Neil & Margie-Cairns - Wednesday, Sep 07, 2005 at 21:40
WOOPS ,
that should have read , have the "glow plugs" sitting on the puter desk !!
Neil .
FollowupID: 383480
Follow Up By: Member - Vince B (NSW) - Thursday, Sep 08, 2005 at 18:07
Thanks Neil & Margie.
I had an auto tech check out the relays & wiring, no problem apparently.
When I changed the glow plugs before, the problem disappeared for a short time. It looks like tike to change the plus again.
Vince
FollowupID: 383615
Reply By: Trevor W(Brisbane) - Thursday, Sep 08, 2005 at 07:16
The Relay is mounted on mine,directly behind the Battery on the Batery Box,Also their is a large fuse to the right of the Battery Terminal just inside the Right guard.
Put a multimeter on the Glow Plug Bar and check Voltage to the glow plugs(you can buy Multi Meter form supacheap for $12.00. Listen at the same time while someone operated the glow plug with the ignition key.You will notice that the Power to the glow plugs is on a lot longer than the glow plug light is on at the dash.
I purchased new plugs and they only fixed the problem for about 2 weeks,I removed them and checked resistance accross each plug and they were all over the place. A mechanic then told me that many of the cheaper brands are rubbish and I then bought a Better Quality set and now everything is fine. However this does not fix your problem of after starting,cutting out.
AnswerID: 128997
Follow Up By: Member - Vince B (NSW) - Thursday, Sep 08, 2005 at 18:02
Hi Trevor.
Thanks for the info. I have manual control for the glow plugs & will certainly retest them again.The motor does not cut out, only idles very rough at first. If I use the hand throttle to assist the problem is less obvious.
Perhaps I should go back to use genuine glow plugs instead of aftermarket ones.
FollowupID: 383610
Follow Up By: Trevor W(Brisbane) - Friday, Sep 09, 2005 at 07:20
I didnt go genuine ,first lot were from packets that had chinese writting over them, second lot were Bosch and are working fine (around $32.00 each) This fixed starting problem.
You mentioned running rough- mine is much the same
After starting it does idle a liitle rougher than time gone by
My thoughts are
1.fuel may not be as good as it use to be - I not sure.
2.My motor has 275,000 kms on it so there would be some worn bits.
3.I did up the idle revs just a tiny bit and it makes the car feel better.
4.I have had the fuel pump and injectors done up just having returned from the Canning ($800.00) and it didn't make a great differance to the rough idle. That s why I think the fuel is not being produced and burning as well. If do come up with a resollution I would like to know,but this post tells me that the Engines have a similar feel about them.
Hope this helps a little.
FollowupID: 383683
Follow Up By: TDBTriton - Friday, Sep 16, 2005 at 23:05
Similar problem with my Triton diesel.
As Trevor said above: "You will notice that the Power to the glow plugs is on a lot longer than the glow plug light is on at the dash."
I find if I leave it for an extra couple of seconds after the glow plug light goes out, it makes a difference. You can actually hear the switch click off (providing the kids aren't in the car).
FollowupID: 384933
Reply By: prado_95 - Thursday, Sep 08, 2005 at 21:01
Check ALL of your glow plugs. Just a couple being off spec can make cold starting difficult.
Next check you are getting the appropriate voltage at the glow plugs on cold start (some engines use voltages otehr than 12V)
ENG-TEK
Melbourne
AnswerID: 129160
Follow Up By: Member - Vince B (NSW) - Saturday, Sep 10, 2005 at 09:45
Hi Dave.
I checked the volt reading to the plugs this morning.The reading is 11.3v.
I will rewire & measure again.
Thanks for your advice.
Vince
FollowupID: 383897
Follow Up By: prado_95 - Tuesday, Sep 13, 2005 at 20:16
11.3v should be adequate when they are on.
Some manufacturers use a 6v glowplugs, with a dropping resister. Obvoiusly not on your car.
Next is to check each glowplug I guess, assuming there is adequate fuel when cranking form a period of inactivity. My step father had that problem, and it turned out to fuel syphonning out of the injector pump (due to dodgy non return valve).
FollowupID: 384388
