Polyairs
Submitted: Friday, Nov 25, 2005 at 20:36
rickwagupatrol
hiya guys and gals. allready looked in archive but can't find the answer.
what is the minimum pressure to use in these things for around town running, and what is the maximum i can use when loaded?.
thanks in advance.....
rick.
Reply By: joc45 - Friday, Nov 25, 2005 at 20:46
Hi Rick,
I recall that it's 4psi min (I think it's just enought to keep them pressed against
the springs to avoid pinching them).
The max is 30 psi.
Gerry
141031
Reply By: Sand Man (SA) - Friday, Nov 25, 2005 at 20:54
Did a google search and found the following:-
Polyair Springs - Red Series - minimum 5psi (to stop chafing) & maximum of 45psi.
Polyair Springs - Black Series - minimum 5 psi & maximum of 100psi.
reference url
141034
Follow Up By: Sand Man (SA) - Friday, Nov 25, 2005 at 21:03
Another reference site that gives the minimum psi of 5.
4wdworld
394697
Reply By: rickwagupatrol - Friday, Nov 25, 2005 at 21:06
thanks for that.....
rick.
141037
Follow Up By: rickwagupatrol - Friday, Nov 25, 2005 at 21:29
just pumped them up to 28.5psi and they lifted the back of the patrol 25mm. gotta be happy with that :):)
combined with the rancho 5000's, the ride is much better,,,,just hope they do the job when we load up and put the van on..
rick.
394706
Follow Up By: rickwagupatrol - Friday, Nov 25, 2005 at 21:34
and our's are a real purdy blue colour...:)
394707
Follow Up By: Member - Trevor R (QLD) - Friday, Nov 25, 2005 at 21:58
",,,,just hope they do the job when we load up and put the van on.."
They will, there a great product.
394715
Follow Up By: Member - Jeff M (WA) - Friday, Nov 25, 2005 at 22:07
If yours are blue, I'd say you have Firestone bags, no bigger, that's what I have and they are very similar (if not better, depending on who you talk to).
My installation manual for my Firestones says 5psi min 35psi max. They are a brillant product. Enjoy.
394718
Reply By: Outbacktourer - Friday, Nov 25, 2005 at 22:22
Sounds like you need to get your hands on the instruction booklet.
The trick with these is to run them at the lowest pressure possible to achieve the desired result. 5 PSI is indeed the maximum. 30 PSI the max.
The procedure is to put 30 PSI in, load the vehicle and then let air out of each side until it begins to sag. Pressure may be different side to side if load is uneven. Do not load the vehicle and then inflate the bags.
The bags are not designed to give you a lift as such, more to prevent a sag.
I have found that with big loads in a Jack and Patrol I have never needed more than 15 PSI to level the vehicle. Too high a pressure does not let
the springs work and will simply transfer road shocks directly to the upper spring mounts and chassis.
141051
Reply By: Member - Banjo The First (SA) - Saturday, Nov 26, 2005 at 09:59
If you go to
http://www.truckspring.com/airsprings/airlift/app/alappmain.aspwhere I bought
mine, you can navigate through to the model you want, then download a factsheet on specs and maintenace etc. My Airlifts are 5psi to 35 psi.
You gotta hand it to these yanks on mail order - you could not want for more information - and they land them here, all up delivered for less than we can buy them locally, AND they still make a profit. BTW, it seems that the Polyairs we buy here are just rebadged Airlift kits - identical. Some forumites here have bought the Firestone version.
141086
