Engel fridge readout
Submitted: Tuesday, Jan 24, 2006 at 20:11
Member - Ray (SA)
Hi all,
I've got an Engel MT35F fridge and having not used it for a couple of months, I've noticed the temp. readout has gone blank.
Does anyone know if there's a battery which powers the readout in the fridge and if so, how/can it be changed?
Is there an Engel service centre in
Canberra. The fridge was bought in
Brisbane just over a year ago so I think it's out of warranty.
Reply By: Sand Man (SA) - Tuesday, Jan 24, 2006 at 20:13
Mate,
Seeing as Engels don't break down, there has to be another reason.
Tried plugging it in??? :-)
150631
Follow Up By: Member - Ray (SA) - Tuesday, Jan 24, 2006 at 20:15
Yeah, I have plugged it in, I imagine the readout runs of an internal battery of some sort as it used to run when the fridge was unplugged.
Just wondering if there is one, is it a rechargeable?
The fridge is running fine, just no temp readout.
404143
Reply By: scottp - Tuesday, Jan 24, 2006 at 20:17
yep they have a watch battery or simmilar in them. The instrucrion book that came with
mine has directions on how to change it. From memory it requires removing the back grill. Pretty simple.
let me know if u have any trouble i will get the book out and give u an accurate decription
150632
Follow Up By: scottp - Tuesday, Jan 24, 2006 at 20:18
the battery is expected to last 2 to 2.5 years from memory
404144
Follow Up By: Member - Ray (SA) - Tuesday, Jan 24, 2006 at 20:21
Maybe my fridge was sitting in the store a mite too long. :-|
404146
Follow Up By: Member - Ray (SA) - Tuesday, Jan 24, 2006 at 20:23
Scott, if it's not too much trouble, could you give me a run-down on how to change the battery? I'm meant to be heading off tomorrow and would like to fix it ASAP.
I can't seem to find the manual for
mine.
Unless someone knows of one online?
Thanks.
404147
Follow Up By: Stoo - Tuesday, Jan 24, 2006 at 20:45
Ray, I have a 60lt and had the same prob. the 60 has a grille on the top with the readout inside, just unscrew the part that contains the readout and behind it you'll find a battery compartment. As mentioned above it's like a watch battery, surely your size fridge is the same. Dick Smith sell every kind of battery like this.
Good luck
Stu
404155
Follow Up By: scottp - Tuesday, Jan 24, 2006 at 20:48
yep!!
Here goes.
1= remove fridge door
2=remove 4 screws which hold hinges
3=remove 2 screws and washers which secure compressor cover
4=take off and turn compressor cover over
5= turn the cap in an anti clockwise direction. Remove the cap and replace the battery (LR44)
404156
Follow Up By: scottp - Tuesday, Jan 24, 2006 at 20:52
instructiuons say battery life around 1 year
The display should show " b A " when the battery is needing replacement
When the display reads " C b L " the instructions say open the wiring and Replace indicator.
WHAT THE !!!!!!!!!!!!!
404158
Reply By: Shaker - Tuesday, Jan 24, 2006 at 20:24
I had to change
mine after a couple of years, must admit I was surprised that it isn't a 12v display.
150635
Reply By: gramps - Tuesday, Jan 24, 2006 at 20:24
Just curious, but why would the temp readout be powered by anything but whatever powers the fridge? Is it just a cost saving exercise?
150637
Follow Up By: scottp - Tuesday, Jan 24, 2006 at 20:54
because that way when the power to the fridge is disconnected you still know the temp inside the fridge????
404160
Follow Up By: gramps - Tuesday, Jan 24, 2006 at 21:08
That sounds reasonable enough. Better than anything I can think of anyway. Thanks scottp.
404165
Follow Up By: Mad Dog (Australia) - Tuesday, Jan 24, 2006 at 22:39
Thats not cost saving gramps. Magic touches like that cost us more money :)
404219
Follow Up By: gramps - Tuesday, Jan 24, 2006 at 22:55
Hahahaha Ray. As we know, cost savings for the manufacturer sometimes (?) don't get passed on to the consumer LOLOLOL
404236
Reply By: Member - Ray (SA) - Tuesday, Jan 24, 2006 at 21:23
Dare I say it, but after doing it the hard way (by taking the back cover off). I found the instructions stuck on the lid!!!
Surprised no-one's pointed it out yet. Maybe they're being polite. :-)
Thanks guys.
150656
Follow Up By: scottp - Tuesday, Jan 24, 2006 at 21:30
those guys at engel think of everything!!!!!
404174
Follow Up By: gramps - Tuesday, Jan 24, 2006 at 22:56
Are you seriously accusing anyone on this
Forum of being polite? That'd be a first :))))))
404237
Reply By: Member - Phil G (SA) - Tuesday, Jan 24, 2006 at 22:00
Also Ray,
the engels come with a 3 year warranty. Both my Engels haven't had an issue in 14 years, so you probably won't need to know that.
phil
150674
Follow Up By: Mad Dog (Australia) - Tuesday, Jan 24, 2006 at 22:43
hahaha, theyy coomme witth a wwarrantty...hahaha
for a doctor you're a funny bugga.
404227
Reply By: Member No 1- Wednesday, Jan 25, 2006 at 19:04
leave it as is if the beer is cold...or if using as a frezzer...if the ice cream is cold...these are the best temp gauges yet
150863
Reply By: disco_cox - Wednesday, Jan 25, 2006 at 21:56
Batteries are available from ARB or even the
supermarket...should be an LR44 battery.
regards,
disco_cox
150897
