Saucepan Handle
Submitted: Wednesday, Mar 01, 2006 at 11:14
Member - John A (SA)
I am intending to cut handles off a few old aluminium saucepans so that they can nest inside each other & save space when packing.
What ideas do other EO Forumites have for a clip on handle that will grip the rim of the saucepan for putting on & off the fire/stove etc.
Is there an off the shelf unit from one of the
camping stores or have you made something up yourselves?
Thanks in anticipation
John A
Reply By: Peter McG (Member, Melbourne) - Wednesday, Mar 01, 2006 at 11:17
good
camping shops will sell the TREGA (Swedish) one. Don't trust the cheaper aluminium versions. Very handy.
157785
Follow Up By: Member - Tony G (ACT) - Wednesday, Mar 01, 2006 at 11:33
Trangie have one as
well, and can be purchased seperately.
412096
Follow Up By: spliney - Wednesday, Mar 01, 2006 at 14:19
Spondonicals - (can't be sure of spelling)!!
412147
Reply By: fozzy - Wednesday, Mar 01, 2006 at 11:19
there is one available off the shelf-aluminium one that clamps sides and very easy to use-just a matter of finding -try
camping stores.
think i got one from big w here in melb-was a while ago
fozzy
157787
Reply By: Member - Bradley- Wednesday, Mar 01, 2006 at 11:44
what about a $ 2 long handle pair of multi grips from bunnings / supercheap.
many many uses.
157790
Follow Up By: bombsquad - Wednesday, Mar 01, 2006 at 12:27
Multigrips are my choice as
well, the locking type also work
well and have a lot of uses.....these are also handy for cracking macadamia nuts without chushing the good bit in the middle
412113
Follow Up By: Goughy - Wednesday, Mar 01, 2006 at 12:31
I carry a good set of cresent fencing pliers & they will handle just about any job you point them in
412116
Follow Up By: Member - Andrew W (SA) - Thursday, Mar 02, 2006 at 17:46
hear hear - multi-grips are the go.
412510
Follow Up By: Pajman Pete (SA) - Thursday, Mar 02, 2006 at 17:50
I use a large set of slip joint (
water pump?) pliers that a have a nice offset head. The beauty of the pliers option is that you have a multi purpose tool rather than another one use item.
412511
Reply By: Wayne (NSW) - Wednesday, Mar 01, 2006 at 13:18
John,
Belinda has a saucepan that has the handle screwed on.
Easy to take off when transporting.
Check before you go cutting and see if it is a screw on handle. Most would be, it would be easy to ship from the factory if the handles were attached at the point of sale.
Wayne
157823
Reply By: Member - Davoe (Widgiemooltha) - Wednesday, Mar 01, 2006 at 20:21
got one beat up old alu fry pan with a fold up handle that I was given. It is both my frypan and plate
157911
Reply By: Sand Man (SA) - Thursday, Mar 02, 2006 at 02:58
I have a set of Coleman stainless steel cookware that fits inside each other and is enclosed in a drawstring bag. The lid for the largest pot doubles as a frypan and can be fitted with a removable handle.
They are lightweight and thin walled, but providing the heat is controlled, work
well without the contents burning.
The cost was about $30.00 about 6 years ago and have served us
well. Don't know if they are still available.
I steer clear of aluminium for cooking. Not good for you apparently.
157986
Reply By: Member - John A (SA) - Thursday, Mar 02, 2006 at 14:52
Thanks everyone for your replies; as usual many good ideas.
I will investigate the purpose designed one's from the
camping shops as
well as long handled multi grips.
John A
158099
