FollowupID: 412626 Submitted:
Thursday, Mar 02, 2006 at 22:46
Mainey (WA) posted:
Some “precise” information about Exide Extreme Cranking batteries and also Exide Endurance Deep Cycle batteries.
It can be clearly seen without and doubt at all, the Exide ENDURANCE is definitely rated by Exide as their DEEP CYCLE battery.
The information below is COPPIED direct off the Exide web site:
Passenger Vehicles | 4wd | Marine | DEEP CYCLE |
http://www.exide.com.au/products/deep-cycle.php
"Built strong to withstand the pounding and vibration of marine, 4wd or heavy vehicle use, Exide ENDURANCE DEEP CYCLE battery is developed for long-running
power and low amperage drain"
____________________________________________________________
It also can be clearly seen without and doubt at all the Exide EXTREME is definitely rated by Exide as ONLY a passenger vehicle battery, yes it’s a Cranking battery.
PASSENGER VEHICLES | 4wd | Marine | Deep Cycle |
"Extreme Vibration is one of the most common cause of damage to batteries. With this in mind, Exide designed the EXTREME to withstand conditions much harsher than most vehicle owners would ever want to encounter"
The Exide Extreme is classified by it’s manufacturer as a 'passenger vehicle' battery, or said another way it’s NOT rated as a Deep Cycle battery by Exide, but as a Cranking battery, sure some may claim it will recharge faster than a similar wet cell Deep Cycle battery and the simple reason is because it’s a Cranker battery and NOT a Deep cycle battery because the two batteries are built differently with different characteristics to do two very different jobs.
If you look closely at the Endurance Deep Cycle range of batteries made by Exide you will see they are similar in shape and size to the Fullriver Deep Cycle range and the Cranking battery range look like conventional Cranking batteries, they are different looking batteries and made for different purposes.
To suggest Exide Extremes are 'successfully' used as Deep Cycle Storage batteries is a bit risky as the actual
technical specifications of the two batteries (Endurance & Extreme) are totally different, if they were the same Exide would only make either a Deep Cycle or a Cranking battery and just change the labels depending what the customer asked for L0L
