house of 12 volt
Submitted: Monday, Mar 06, 2006 at 12:12
gonebush SA
Just wanted to pass on what we think to be a good honest business. On the weekend we went to the open day at the 'House of 12 volt' at
Strathalbyn SA. My hubby was thinking that we would need to spend around $300-$400 on what he thought we needed at their store and when we spoke to the people there it turns out we only needed to spend $90. It’s so nice these days to have a business that’s not only out to make a quick buck and explain things correctly.
$29 of that $90 is for a gadget that we haven’t seen before, it plugs into the power pack then into whatever your running off it and if the
battery power is getting too low it automatically turns off whatever is plugged into it to save the battery, a $29 insurance for your battery must be a good thing considering the price of battery packs.
And no I’m not getting anything for writing this just to pass on a good business.
Good luck to you all.
Reply By: simple - Monday, Mar 06, 2006 at 14:30
is there a web link maybe?
158885
Reply By: Sand Man (SA) - Monday, Mar 06, 2006 at 17:21
"House of 12 Volt???
The "Home of 12 Volt" (Blue Apple) does not have a Web Link.
Their address is 7 Rankine Street
Strathalbyn SA 5255 (08 8536 8211)
When I was talking to the owner during last year's 4WD Show in
Adelaide, he was indicating that they were planning to open an outlet in
Adelaide, but don't believe this has happened yet.
They are not pushy and give good advice without flogging something you may not need.
I was looking at a Solar Panel solution for the 75AH Thumper I had bought the previous year. The advice they gave me was to buy one panel (40 watts) and try it out first. If the 2.5 amp (approx.) output wasn't sufficient to maintain an adequate capacity in the portable battery system, I could buy another one at any time and couple it to the existing panel and controller unit to double the output.
Have only had the fridge running off the Thumper for 4 days straight, with the solar panel connected. I will probably buy another panel eventually, to ensure I am putting back in a sufficient charge, but I'm in no particular hurry at the moment.
158918
Reply By: Patrolman Pat - Monday, Mar 06, 2006 at 18:35
They gave a talk at our 4WD club's last meeting. You can buy their gear through Darren at Total Traction Tyres at Lonsdale.
Darren is a fellow club member but one I'm glad to endorse.
158929
Reply By: gonebush SA - Monday, Mar 06, 2006 at 19:34
hi again i went into Google and did a search and came up with this page;
http://www;homeof12volt.com.au/
but i did try to use it and it didn't seem to work, i'll put it on here incase it's just having a down time.
just a note if you want to try a search through Google i found i needed to write the 'house of 12 volt
strathalbyn'.
good luck with it.
158946
Follow Up By: Sand Man (SA) - Monday, Mar 06, 2006 at 20:56
Change the ; to a . and you will get to a "placeholder" Website.
But no active Website at the moment.
413481
Reply By: Member - Mike - Monday, Mar 06, 2006 at 21:09
We have in Vic a company called Home Of 12 Volt there website can be found here
http://www.bitdistribution.com.au/ I have just purchased from them a car pc - there knowledge & advice were invaluable
Mike
158966
Reply By: SA_Patrol - Monday, Mar 06, 2006 at 21:11
