Maree Man's map position
Submitted: Monday, May 29, 2006 at 21:06
ThreadID: 34395 Views:5625 Replies:5 FollowUps:12
Hi, We have been trying to find the "Maree Man" on Google Map sat , but the info on the Net only say's that it is 60ks from Maree, does anyone know which direction, or is there some landmarks that we can use to see if you can still see it, they said in the Sunday Mail that it is getting overgrown etc . Any info muchly appreciated. Cheers Des.
Reply By: Member - Brad S (SA) - Monday, May 29, 2006 at 21:24
Googled it!
Longitude: 137°27'59"
Latitude: -29°32'2"
Brad
AnswerID: 175518
Follow Up By: DesF - Monday, May 29, 2006 at 21:28
Hi Brad thanks for that but I 'm not sure how to convert that in to English, I only have normal maps . can you put those coordinates into Google maps?.
Cheers Des.
FollowupID: 431576
Reply By: Member - Brad S (SA) - Monday, May 29, 2006 at 21:43
It's on a plateau SSE of Lake Eyre South
Brad
AnswerID: 175529
Follow Up By: Member - Brad S (SA) - Monday, May 29, 2006 at 21:44
Actually directly below Lake Eyre South
Brad
FollowupID: 431583
Follow Up By: Rick (S.A.) - Monday, May 29, 2006 at 22:09
As Brad says, SSE of L Eyre South.
Altough not accessible from the made road, it is north of the Oodnadatta track: - N of Hermit Hill, which is about 60 K west of Marree. You cannot possibly see it from the road.
Please do not attempt to go there. Firstly, there are no tracks or roads, and the Tread Lightly morals would suggest we should not make any in such a fragile environment. Secondly, it is in an area particularly special to the locals. If you want to know more, ask Reg Dodd at the Marree Arabunna Peoples Center in Marree. Reg is a true gentleman and a great caretaker.
FollowupID: 431594
Follow Up By: DesF - Tuesday, May 30, 2006 at 14:53
Hi, thanks fellows , I had just found it by working the Longs & Lats on a map that I found with them on it.
I am only looking on google maps as I don't have broadband ( yet), but it is still visable as when it was filmed.
I was looking to the north but I can see how they would have been able to get there as it seems only 10-12ks from th Track.
Well thanks again , the Forum has saved me again.
Cheers Des.
FollowupID: 431708
Reply By: Sand Man (SA) - Monday, May 29, 2006 at 21:48
Des,
Copy and paste the following into the search field at the top left corner of Google Earth screen. Exactly as is.
29 32.0138 s 137 28.0172 e
Bill
AnswerID: 175532
Follow Up By: Sand Man (SA) - Monday, May 29, 2006 at 21:50
Note,
the image in Google Earth is from a sat. photo probably taken a couple of years ago. It's probably much less noticeable now in real time.
Bill
FollowupID: 431589
Follow Up By: Member - DickyBeach - Monday, May 29, 2006 at 22:32
Brilliant - thanks
FollowupID: 431596
Follow Up By: DesF - Tuesday, May 30, 2006 at 14:56
Thanks Sandman , I have saved the co-ords untill I get on to Google Earth ( broadband). Thanks again Des.
FollowupID: 431709
Reply By: agsmky - Monday, May 29, 2006 at 21:52
If you are talking Google Maps (http://maps.google.com), follow this link ==> Site Link
AnswerID: 175533
Follow Up By: Scoey (QLD) - Tuesday, May 30, 2006 at 14:20
G'Day Andrew,
I've never heard of this Maree Man but am now very intrigued! What, exactly am I looking at, on that aerial photo on your link??
Scoey.
FollowupID: 431697
Follow Up By: Neil & Lynne - Tuesday, May 30, 2006 at 14:53
This Site Link should tell you all about it.
Neil.
FollowupID: 431707
Follow Up By: Scoey (QLD) - Tuesday, May 30, 2006 at 15:18
Ahhhh, ok so I have heard about it! Thanks for the link Neil. That's amazing!
Scoey!
FollowupID: 431715
Reply By: DesF - Tuesday, May 30, 2006 at 15:00
Just a point for anyone only using Google Maps, there is a site which uses Google and the view is much bigger (3/4 screen ) than On Google Maps.
it is a 4x4 site which you join ,its not bad .
try www.frappr/overlander.com.au . Cheers Des.
AnswerID: 175638
Follow Up By: Member - Gomax (VIC) - Tuesday, May 30, 2006 at 19:04
Mebbe
" target="EOF" class="lbg">www.frapper.com/overlander
FollowupID: 431756
Follow Up By: DesF - Tuesday, May 30, 2006 at 19:25
That's the one I should have put in the address myself ????"D"
FollowupID: 431761
