Rear Window Saver
Submitted: Thursday, Jun 01, 2006 at 20:15
ThreadID: 34515 Views:4256 Replies:6 FollowUps:3
After one of these for the cruiser,the ones that have velcro tabs that you can remove quickly when not in use.Thought they were sold on here but couldnt find em.Also what prices do they go for.
Cheers All Nick
Reply By: Old Scalyback & denny - Thursday, Jun 01, 2006 at 20:19
goodday nick
i had mine made up a couple of pieces of thick felt and some velcro sewn on
need somebody who makes boat covers or bits like that as the guy who did mine was in that trade and just used some leftovers
steve
AnswerID: 176190
Follow Up By: Member - Julie P (VIC) - Monday, Jun 05, 2006 at 10:30
Look for a perspex company - there is a product called "Tuffek" which is impervious to uv rays - the guy I got mine from sold me a sheet,(cost was only $50 cash) we made a template and cut it to shape bought good quality velcro attached to window and tuffek - works a dream - this was AFTER we paid out $895 for new rear window last year. We got the thinner sort as it was flexible - not many rear windows are dead flat after all.
Warning though, remove it when you are not towing especially if you are in hot weather - the glue on the velcro (no matter what brand) will melt and your protector will slip off. Doesn't happen when you are travelling.
And if you want one professionally made - "obies outback" is the site to see - do them for all standard vehicles I believe. The cost (usually under $200) outweights the replacement cost of rear windows - check them out - some are over $2000 - especially the ones with wipers in the window itself!
FollowupID: 432820
Reply By: Motherhen - Thursday, Jun 01, 2006 at 20:22
A well known member made some for us from heavy duty sheet plastic, with self adhesive Velcro tabs. When it got hot, a couple of stickers on the window came lose - just needed watching and pressing back on. Took them all off easily when we got home. Not too hard to come by more Velcro for next trip. For fitting stuff to the dashboard etc in the car, we have found that Velcro brand stuff stood up to the heat better than the cheaper alternatives. Try your local Spotlight store for plastic, Velcro and a pair of scissors.
AnswerID: 176192
Follow Up By: Willem - Thursday, Jun 01, 2006 at 22:09
You can mention me.. I aint shy as you know.....LOL
Glad to hear it worked. Mine worked very well and saved my windows on a number of occasions
FollowupID: 432250
Follow Up By: Motherhen - Friday, Jun 02, 2006 at 00:06
Hi Willem - Now there's an opening for a business for you. Make them - your first customer is waiting!
FollowupID: 432265
Reply By: Richard Kovac - Thursday, Jun 01, 2006 at 20:54
Nick
We have one and works well
www.obiesoutback.com.au
www.obiesoutback.com.au/
Richard
AnswerID: 176208
Reply By: Sand Man (SA) - Thursday, Jun 01, 2006 at 21:27
Yes,
Also have an Obie's Outback Rear Window Saver. (two atually, large door & small door)
After about 6 months or so, the original velcro strips as supplied "wrinkled" due to contraction and expansion and lost some adhesion due to water/dirt entry.
Simple and cheap solution.
Replaced the velcro strips (hook surface) on the glass with general purpose Velco 20mm Dots (hook surface) and have had no problems at all during the past 12 months or so.
The strips (loop surface) originally attached to the Window Saver are showing early signs of a similar "wrinkling" and I will eventually also replace this with the Velco Dots (loop surface).
My theory is that due to the relatively small surface area of the 20mm dots, they are not affected by changing weather conditions. In any case, it has worked for me.
The Velcro Dots (hook & loop) in either black or white colours are available at most hardware retailers.
Bill
AnswerID: 176215
Reply By: Garbutt - Friday, Jun 02, 2006 at 19:13
Get yourself some corflute, which is the corrugated plastic cardboard, I got some from the local recycler for nothing, cut it to shape and fix with velcro or duct tape, I spaced it out from the window about 5 mm with some stick on pads from Mitre5 for about $3, total cost about $10. Works well for me towing CT with Hilux.
GB
AnswerID: 176423
Reply By: Member - Nick (Kununurra) - Friday, Jun 02, 2006 at 20:14
Cheers everyone,will see what I can come up with.
AnswerID: 176438
